Whirlpool AWO 10761
Hi Dutchman,
Sorry I should have mentioned that it is a Whirlpool AWO 10761 with failure code F11.
Many Thanks.
Phil
4 Suggested Answers
  • 114 Answers
SOURCE: I have a whirlpool washing
Your owner's manual may have a trouble shooting section which may include a list of fault codes. If not, the list of fault codes will be contained within a tech sheet hidden in the washer somewhere, either behind the backguard or on the inside of the front panel.
Posted on May 09, 2008
  • 343 Answers
SOURCE: my washing a whirlpool awo 10761 front loader,when
If you can still open the door when it's supposed to be locked it probably means that the interlock on the door catch is faulty.Easier to fix than if the door is locked shut!!...Not a big job but should be done by a qualified tech. See if you can find an independent, self employed tech...Generally cheaper and better than 'Brand Name' servicemen..Good luck..........Nomess
Posted on Apr 18, 2010
mc1bean
  • 3053 Answers
SOURCE: i have a whirlpool awo 10761 showing fault code
Hello, Mike
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved by the other fantastic great experts. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about washing machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Posted on Nov 09, 2011
What does F11 error message stand for on my Whirlpool awo 9565 washing machine?
The F11 fault code indicates a serial communication error between the Machine Control board and the Motor Control board. This can be caused by several different problems.
A failed Machine Control board could be failing to provide the Motor Control board with proper voltage. If this is causing the F11 code, then the Machine Control board would need to be replaced.
The Machine Control board could also be failing to supply proper voltage to the door lock assembly. The Machine Control board would need to be replaced for this failure as well.
Voltage flows from the Machine Control board to the Door Lock Assembly. The Door Lock then energizes and closes the Door Lock MAIN Switch. Voltage flows out of the Door Lock Main Switch to the Motor Control board. So if you have power into the Door Lock Assembly but not out of the Main Door Lock Switch, it will give you an F11. If so, you will need to replace the Door Lock Assembly.
You could have a bad Motor Control board that is causing this failure. A bad wiring connection between the Motor Control board and the Machine Control board could also cause this fault code. A bad wiring connection between the Motor Control board and the drive motor is also a possible failure. A failed drive motor could also cause the F11.
With so many possible causes for this failure, I recommend calling a service technician to diagnose and repair the problem in your washer. If you are able to unplug the washer and check the wiring connections, you may be able to find a loose wire harness connection that is causing the problem. Much of the diagnosis for the potential problems noted above requires live voltage checks. I do not recommend conducting these types of checks yourself. Unless you want to take a chance and replace the Machine Control board and the Door Lock Assembly,
Aug 15, 2014 | Whirlpool Washing Machines
Whirlpool awo 9663 wont start cycle
This can be due to failure of motor components or the control panel as there is no communication for the drive . Check the motor to panel wiring, check the panel for failed component
Jul 05, 2012 | Whirlpool Washing Machines
F12error on whirlpoolawo/d5716
'F12' decodes as 'element (heater) short circuit' on Whirlpool AWO series of washers.
Sorry but this probably means a service call unless you know someone else who could repair your washer ;-0(
If this has clarified the situation and/or assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Apr 25, 2011 | Whirlpool Washing Machines
Cant reset my f13 fault and wen i power on it takes its take to lite front panel up
Hi again,
Whirlpool AWO 'F13' decodes as 'dispenser circuit failure'. If you have tried switching off and back on again and it is still there I suspect it means that you will have to call an engineer. Sorry ;-0(
Good luck,
John C
Mar 29, 2011 | Washing Machines
Whirlpool AWO/D4305 Washing Machine. The "Water
Providing that the tap is turned fully on AND the hoses are not kinked or squashed at the back, this is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs a service call ;-0(
Good luck,
John C
Mar 27, 2011 | Washing Machines
Machine stopped showing F11 as fault on screen. No detail in the book as to cause or solution to this fault. Machine is a whirlpool AWO 10561
F11 Motor control unit internal failure MCU board failure or broken wire. Check that harness for loose connection to that white box on the left. That is the MCU. Get a tech manual for your machine HERE fe0b7a2.jpg4c1535c.jpg
This might just be a loose connection. The MCU pictured here is the white box on the left and above
The tech sheet is behind the kickplate also and it will give you the data you need for your codes.
Jun 02, 2010 | Washing Machines
My washing a whirlpool awo 10761 front loader,when i switch it on after 20 seconds the ''door locked'' light starts to flash and the programme goes no further
Apr 17, 2010 | Washing Machines
FP fault code on whirlpool washing machine
i have a whirlpool 6th sense awo 10761 and evrytime i start a cycle it stops and the door lock light flashes can any one help me
Nov 07, 2009 | Whirlpool Washing Machines
I have a whirlpool washing machine AWO 10761, yesterday while running through it's wash cycle it came up with a failure code of F11 and the start button was flashing, Switched appliance off at the mains...
May 08, 2008 | Washing Machines
Washing Machines Logo
173 people viewed this question
Top Washing Machines Experts
