Question about Kenmore Ovens
My oven takes up to 30 minutes to light - Kenmore Ovens
    Genius:
  • 1,416 Answers
what this indicate or what it means is that there has been a loose of wire connection from the element or weakness from the element
what you will have to do first of all is to unscrew the oven from the stroll with a screwdriver (technician tools ) the trace the wire down to the element (heater or heat provider) it is silver in colour at the lift or right Conner side of the oven to see if there is any form of loose of wire from the connection ,
if any then fix it up to the element , but if non then it meant that the element is bad which will need a replacement .
You can get the element from the below site
/www.maxoncorp.com directcaterparts.co.uk premierrange.com appliancedirectparts.com
all these site offer good service and price you can go shopping
Please note if you which to get the element your self make sure it same size from the weak or old one to avoid incompatible with the the panel .
thank you and thanks for using fixya.
Posted on Sep 03, 2010
Westinghouse oven model WFE946SA, purchased only 4 mnths ago. No lights display
main control board,take it back,its expensive,1 year warranty
Jul 26, 2015 | Ovens
My oven bakes, but it takes 30 minutes to preheat
Hi friend, thank you for your post!
I know from your post that your Frigidaire oven is working but the preheat takes 30 minutes. This does sound like lengthy amount of time for preheat to be completed. From what you are describing it could be an issue with the panel, element, or thermostat. Since it could be anyone of these underlying issues I would recommend having a professional come out to diagnose your refrigerator to determine the root cause to reduce the risk of unnecessary parts. -Matt
Aug 06, 2014 | Frigidaire 30 in. Electric Gallery Series...
Tried to do self cleaning on oven, about 10 minutes in got "f2 locked door" and it won't clean. what is that all about?
Error code F2 on clean cycle is indicating that the maximum permissable cleaning temperature has been exceeded. (or it's got too hot!)
However it seems unlikely that that would happen in just 10 mins. more likely it is a problem with the oven temperature sensor which should be checked over as should the lock switches..
Dec 14, 2010 | GE JRP24 Electric Double Oven
Hello, i have a stoves q720 grf do double oven and the problem is with the lower oven, after about 20 minutes the oven switches itself off and the lights on the front of the oven flash on and off. van...
I have the same problem. After anywhere from 5 to 30 minutes the oven(s) switch off and the light and clock start flashing - I have to switch the cooker on and off to start using the oven again.
Any resolution please?
Oct 07, 2010 | Stoves 720EF Electric Double Oven
Have a viking professional oven and it takes too
A weak oven ignitor will cause this problem. even though it eventually lights the temp has dropped considerably so you don't get consistent temp. turn the oven on and listen for the burner to light. should light within about 2 minutes. if not replace oven ignitor(s)
May 20, 2010 | Viking 27" Professional Select Built-in...
Can't get pilot light to stay lite in oven
make sure the thermocouple is positioned above pilot light this part needs to be heated up by the pilot light to keep gas going to the pilot light. if the thermocouple is positioned above pilot light and it doesn't stay light, replace thermocouple.
Apr 04, 2010 | Stoves Premier 600GRa Gas Single Oven
Oven takes 5 minutes to come on (ignite).
Replaced the igniter. The parts guy told me that the amperage changes with age and use; thus the igniter still glows, but it takes much longer to operate the gas valve with the reduced amperage. Cost - $70.14
Oct 18, 2009 | Tappan 30IN ELEC IGNa Oven
The lock on self cleaning oven door will not release
Once the cleaning button on the oven is pressed it take 15 minutes for the uven door to unlock.
Jul 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Gas oven not keeping temp consistant
Hi. this is a failing oven temp sensor. the sensor probe is not responding to the oven control. this will cause erratic temps in this oven. it will also damage the control board if the sensor isn't replaced soon.
May 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Slow oven lighting....bakes for 20 minutes than stops heating
Hi, The oven should ignite within 20 to 30 seconds. The most common problem is that the ignitor gets weak and will not open the gas valve like it should. This would be my first part to change.
May 09, 2009 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
32 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
