Question about Refrigerators
Whirlpool FRBB2VAF20/0 side by side fridge freezer derosting
Problem started last week when freezer defrosted, and alarm bleeping.
switched power off for 10 minuits and reset. freezer seemed to be ok but after 12 hours it defrosted again and was bleeping.also noticed strip between doors was hot.
removed front plinth and back cover and found radiator full of dust , gave it a brush down and hoovered as much as i could get at , also emptied the drip tray , which was only half full..switched back on but after 2 days problem has reoccurred
would apreciate any help/advice with this fault.
  • johnl2 May 12, 2008
    problem started last week when freezer defrosted, and alarm bleeping.
    I have checked both door seals, same as new.
    there are no other appliances or air conditioning affecting room temperature.
    The temperature controls are an lcd display and push buttons mounted externally on the freezer door water/ice dispencer unit,they are factory set at 5c and -18c and have not been adjusted.
    There is no build up of frost/ice internally.
    I can hear the comressor running and if i open the freezer door and press the door switch the internal light goes out and the freezer fan runs.
    Freezer is defrosting approx every 8-12hrs now and display shows '--'flashing.
    Any ideas?
    The fridge freezer is only just over 12months old and like new.
    I'm already regretting my service strategy and i must admit i was supprised at how much dust had collected on the condenser/evaporator.
    How do i check if i have a clogged cooling system?
    Genius:
  • 3,587 Answers
Sounds to me like you may have a clogged line for your cooling system. You have a good service strategy in your neck of da woods, mon?
Posted on May 12, 2008
  • Patrick Michaels
    Patrick Michaels May 12, 2008
    you don't..takes a special set of equipment, usually used to support a recharge of the coolant..checks for blockages, leaks, etc.
  • Refrigerators Master
  • 19,396 Answers
If the door gasket is weared, that can be the cause for this problem, check if it is in need of replacement.
Posted on May 11, 2008
  • Ginko
    Ginko May 11, 2008
    Here is also a list of general troubleshooting on freezer not cooling.
    Check first the gasket, and also check that you do not have another appliance (eg an air conditioner) pumping hot air on the fridge.
    Check also thermostat settings.
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
On normal operation my freezer alarm will not stop bleeping.The only way to silence alarm is to switch to Fast Freeze ,however the compressor runs contually ,even after 24hrs and switching back to normal...
Have you cleaned the condenser grill and made sure you have plenty of air flow around the unit? It might also be time to take the food out and completely defrost your freezer! Since you do have an ice build up on your evaporator grill.
Jul 31, 2011 | Whirlpool Freezers
Hi We have a whirlpool side by side no ice maker in the past week the freezer is cold and frosty fridge is warm up to 15degrees at the top bottom of fridge is 5 degrees. Top vent from freezer is not in...
3 things
If you have ice on the freezer side.
1. defrost timer not working
2. blower fan failed, if it has one
3. defrost limit switch failed..
i dont think it is #2 but 1 or 3
last but not least your defrost heat coil has failed
Dec 18, 2010 | Refrigerators
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Whirlpool Refrigerators
Fridge not getting cold
you have a defrost problem.when you open your freezer door and look at the back panel look and see if their is frost built up.if so that means you do have a defrost problem.you will need to pull panel off and defrost coils.then you can check your defrost thermostat which is round and has 2 wires that go to it.it sits at the top of coils.see if it seperated.if so that is your problem also check defrost heater see if any breaks in it.if those check out then could be defrost timer which is located in ref.side.it would help to know what brand it is.it sounds like a side by side ref,but dont know what brand.
Mar 24, 2009 | Freezers
Whirlpool side by side refrigerator not defrosting.
take back panel off inside freezer. check continuity thro heater and thermal fuse in series with heater
Nov 17, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Leaking Whirlpool fridge
Thanks for the question When this happens if the evaporator is all frosted up you have a derost problem could be your timer or your defrost thermostat which is located on the coils of the evaporator you can check this with a volt meter these meters are cheap you dont need a very expensive for ahout 20 dollars or the defrost timer one of the two is your problem thanks for the question The appliancedoc
Sep 11, 2008 | Whirlpool ET8WTKXK Top Freezer...
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
 if posible try turning off over night, if its ok when you start it back up after 24hours, defrost not happening, ice builds up air flow is restricted
Oct 18, 2007 | Whirlpool ED2FHEXN Side by Side...
Alarm Flashing Red & Bleeping
Did the RCD tripping have anything to do with the freezer? You could have a faulty defrost heater, which means the freezer will not defrost at all.
May 26, 2007 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
Refrigerators Logo
439 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
