Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
My Poulan Pro 42" riding mower (HD1842 - 2005) starts and runs for about 10-15 minutes then chokes out. It won't re-start until about 10-20 minutes later. Then it does the same thing. I've replaced fuel & air filters, plug and solenoid. I'll loosen the gas cap next and see. Any other suggestions welcomed.
SOURCE: Need lawn mower manual
need manual for pb195h42lt
Posted on Apr 24, 2009
  • 71 Answers
SOURCE: Craftsman 42 inch riding mower. Runs great
how old is your plug? try cleaning and regapping it or replacing it at any rate make sure it is gapped correctly also make sure there is no rust dust or debris is on flywheel or coil also the flywheel keyway does more than hold the flywheel in place it servs as a timing pin and sometimes the slightest wear on it can cause the machine to start hard but otherwise run great good luck hope you find the problem.
Posted on May 02, 2009
  • 376 Answers
SOURCE: Poulan Riding Mower won't crank, battery OK.
Forget the safety switches for now.The first thing I would check would be the fuse. It will be located on the battery side of the solenoid. Follow your positive battery cable to the solenoid. There will be a small red wire coming off of that post with an inline fuse. If the fuse is good, check your solenoid. There are two wires plugged into spade terminals at the bottom of the solenoid. Unplug the one that is insulated, the other one is a ground. Hook a test light from that wire to ground. When you turn the key to start (with the brake pedal held down), it should light. If it lights, your solenoid is bad. If not, then you can start looking at switches. Probably will be one of the two. Hope this helps. Dwain
Posted on May 21, 2009
  • 4 Answers
SOURCE: Hard to shifet my poulan pro and wont go into reverse
Try loosening the belt tension to the transmission a little bit. Some of these are just stiff and you have to slip the clutch a little to rock them into gear.
Posted on May 25, 2009
SOURCE: POULAN 42" 19HP RIDING LAWN MOWER
42 inch poulan belt broke on mower deck diagram to replace new belt
Posted on Aug 10, 2009
My poulan pro 500ex runs until I try to go forward or backward then it shuts off
did you check the seat switch ???... unhook the kill wire at the engine ( for testing purposes ONLY ) and then try to move... if it works check you safety system... if not, check your safety system
Aug 30, 2014 | Garden
Poulan Pro 42" with 17.5
you need to find out if there is spark at the plugs
pull the plug put the wire back on hold it away from the engine then crank it over, you should see a nice blue spark arking from plug the engine body
If not then you need the start checking pug , wire , coil, or magneto wich ever your machine has
Jul 23, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan riding mower starts and runs for a few minutes then "chokes out" and stops running, why? If I let it sit for about 30 minutes I can restart it and finish the lawn. Now it runs for a few minutes...
If you have already changed your fuel filter and spark plug, look at your fuel tank cap. The breathing holes may be clogged with dirt or debris preventing good fuel flow. I happened to spend $150 bucks for this $5 fix. Hope this helps.
Aug 26, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a craftsman 20hp Briggs motor, it turns over but wont start.
Make sure it is choking the engine like it should. If it is not choked it wont start for several minutes.
Sep 28, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
131 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
