Question about Kitchen Ranges
Cant get oven door back on - Kitchen Ranges
  • hadafarm May 22, 2008
    Hi I have a whirlpool super capcity 465 model # SF360 BEEW 0....
    the B in the model number above might be an 8 i can't tell for sure...
    Anyway the door was off the hinges i got it back on but the door does not close all the way, ieven removed it more then once and was able to get it back on several times thinking that would help. but no luck i cant see an obvious hinge adjustment anywhere.
    any help would be great
    Thanks
    kyle
    Genius:
  • 1,073 Answers
What is the model number of the range
Posted on May 11, 2008
How to reinstall oven door for model 968 64799
Look your make and model up on the web and get an online copy of the manual
Sep 12, 2014 | Kitchen Ranges
Remove door
I recommend calling either the manufacturer or the place you bought it from. Quite likely need a new door.
Jan 29, 2014 | Candy FP855 Electric Single Oven
Took the oven door off and now cant get it back on
Typically one cannot fight the hinges while putting the door on.
USUALLY you can move a hinge down/open and there is a hole to put a nail through to hold each hinge down while you get the door in place.
Nov 20, 2009 | Whirlpool SB160PEE Gas Single Oven
I cant get my self cleaning oven to unlock... what do I do, I cant find my manual
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Oct 10, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F90 code flashing and i cant reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Cant get the oven door back on
Use a wrench to lower the hinge arms down. There is a hole in the arm that you can put a nail into through to the frame of the oven/ This should leave the arm in an outward position. Do this on both sides of the oven, or both hinges
Pick up the door, and slide the door onto the arms until they stop.
Press down on the top end of the door lightly so that you may remove the nails inserted above.
Lift the door to close. If you didn't slide the door onto the hinge pieces far enough, then repeat the procedure.
Jan 24, 2009 | Frigidaire GLEB27S7A Electric Single Oven
Whirlpool oven door
The metal bars go under the top door handle part, put them under the part you need to screw back in.
Sep 15, 2008 | Whirlpool RBS245PDS Electric Single Oven
Smeg se375mfx5 / stainless steel
i suspect you took the door off without locking the hinges
you will have to put the hinges in the lock position before putting back.
lay door on a blanket with hinges upwards. force the hinges back and bring the locking arm up to lock the hinges.
this requires considerable strength
Jul 05, 2008 | Smeg SE399X/5 Stainless Steel Electric...
DCS gas oven locked
I let the door stay open, hold the switch closed with my finger, activated self clean. Let it run for a minute then hit cancel, the stove heating element shut off and the locked door blinked for 5 seconds then finally stopped. Back to normal.
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven Door
http://www.repairclinic.com/0088_13_1.asp.... good luck
Aug 06, 2006 | Kenmore 30169 Electric Single Oven
Kitchen Ranges Logo
135 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
