Question about Sony Handycam DCR-DVD108 DVD Camcorder
Touch panel won't function.
My touch panel won't activate when I touch it, at all. The display is perfectly fine, but when I try to touch one of the options nothing happens at all, and I can't configure as it says you should do in the manual because to do so I have to touch the screen.
Please if anyone can help me I would greatly apreciate it!
Thanks
  • 1 more comment
  • Scubastisti May 11, 2008
    How would I reinstall the firmware?
    I bought the camera as new off ebay a while back, and since I had it, it has had this problem, so I have been unable to install any programs on the computer. I can't send it back to the seller as the seller has already told me that because I have already bought it I can't send it back to the US, and because I am in Australia they can't fix it here as it has a US only waranty and they charge $88AUD just to give a quote. I know it was a long shot, but I was hoping someone would have an idea of how to fix it as I am desperately needing it fixed, but the price they are charging for a quote is rediculous, imagine what they would charge to fix the problem ontop of that!
  • Scubastisti May 12, 2008
    Yeah, I've tried to calibrate many times, but still to no avail. The buttons on the side of the panel such as the home button etc all function, it is just the ones on the screen I cannot access and without them the calibration procedure is useless.
  • Sony Master
  • 19,396 Answers
You may try reinstalling the firmware and configuring afterward. If this does not work the touch panel may be defective.
I will see if I find a download and further info.
Posted on May 11, 2008
  • 2 more comments
  • Ginko
    Ginko May 11, 2008
    To reinstall firmware you need to have the image file , sometimes this is available for download, depends if Sony does distribute it. You update it using computer connection and software, but first we must be sure it is not a different problem.
    First reset the camera by removing disk and battery for a couple of minutes, and see if the touchscreen works, did touchscreen even worked?
    If it is just a matter of settings you could use the remote to adjust settings, but I am afraid you cannot fix this with settings adjustment.
    Check first if you have a C or E message at the upper righthand corner of display. If you have an error message it may be an hardware fault, in this case post error code.
    Here is manual for refence
  • Ginko
    Ginko May 11, 2008
    Sony does not distribute firmware, they will tell you to go to an authorized repair service.
    I enquired Sony on this problem here is their answer:
    "If the buttons on the touch-panel LCD
    screen do not respond correctly or do not work at all, adjust the LCD
    screen calibration. Consult the instruction manual if specific
    information is required to perform this procedure; instruction manuals
    are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
    NOTE: The touch-panel LCD screen cannot be calibrated if it is rotated.
    If the issue is still unresolved after
    calibrating the touch-panel LCD screen, service may be required. The
    Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer."
    The problem may be beyond repair with a small amount or a rather silly problem.
    If it is just a matter of calibration I need to find out calibration procedure, as the touch display had just been "moved" and is out of place. If it is faulty instead, then you have been scammed and you need a repair shop, let see what I find.
  • Ginko
    Ginko May 11, 2008
    Check also if the home button below display is working, if not even buttons are working then is an internal problem, probably with ribbon cable connecting display and commands.
  • Ginko
    Ginko May 11, 2008
    Go to page 105 of manual and do calibration procedure, this can fix the problem, if it does not work, then camera is defective.
    Here is manual again, go page 105 and do calibration.
How to unlock the child lock on the AEG L98690FL washing machine. Thanks
5.18 Child lock function
This function prevents children operating the control panel.
• To activate this function, touch button 12 and button 11 at the same
time until the display shows the symbol .
• To deactivate this function, touch button 12 and button 11 at the
same time until the symbol goes off.
You can activate the function:
• Before you touch the button 6 : the appliance cannot start.
• After you touch the button 6 , all the buttons and the programme
knob are deactivated.
untitled-rq2y3fnvghvfrpvxa33jafnd-5-0.jpg Display:
untitled1-rq2y3fnvghvfrpvxa33jafnd-5-6.png Dado
Apr 19, 2017 | AEG Washing Machines
How to change display from Japanese to English
4-2. User’s Choice Function Setting Procedure
<Setting Procedure>
1. Press the User Mode key on the control panel and then touch the “User’s Choice” key.
2. Select the page number key that contains the desired function from among 1/6 through 6/6 shown YOURS WOULD BE 1/6
at the bottom of the Touch Panel.
3. Select the function to be set and make settings as required.
4. After the settings are complete, touch the “Enter” key to validate the settings.
NOTE:
The function selected is highlighted.
<Exiting the Mode>
Perform any one of the following steps to go back to the Basic screen.
 Press the Panel Reset key on the control panel.
 Touch “Exit” on the Touch Panel.
Language Selection
English
Select the language of the Touch Panel messages.
French
Dutch Italian Spanish
Portuguese Danish Norwegian
Swedish Finnish Greek
–Metric Areas–
English German French
Japanese Chinese Portuguese
Mar 18, 2010 | Minolta Office Equipment & Supplies
How do i set the flash on my vivitar cam. model 8025
Touch the lightning bolt icon in the function area until the flash icon and the letter A appears on the left side of the display. This activates the automatic flash.
Touch the lightning bolt icon again until the letter A disappears. This forces the manual flash mode.
Touch the lightning bolt icon again until the eyeball appears on the left side of the display. This activates the red-eye reduction feature.
To turn off the flash function touch the lightning bolt icon repeatedly until the no-flash symbol (lighting bolt in a circle with a line through it) appears on the left.
This is all described in the manual.
Jan 23, 2010 | Vivitar ViviCam 8025 Digital Camera
How do I turn on the flash on 8025
1. Touch the flash function area (lightning bolt with downward-pointing arrow) until the flash icon with the "A" shows up on the left side of the display. This activates the automatic flash.
2. Touch the flash function area again until the flash icon shows up. This activates manual flash.
3. Touch the flash function area again the eyeball icon shows up on the left. This activates the red-eye reduction mode feature.
4. To turn off the flash, touch the flash function area repeatedly until the flash icon insie a circle shows up.
This is all explained on pages 13-14 of your manual.
Jan 05, 2010 | Vivitar ViviCam 8025 Digital Camera
My iphone 2g touch screen not functioning
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clean the screen, if that doesn’t work. Reset the phone or use iTunes to restore the phone to the factory defaults. If that doesn’t work you will need to take the phone by the Apple store and have them check it out. The touch screen component of the iPhone is like a second screen under the display; it can break and you can still have a perfectly clear picture but no touch response.
Oct 02, 2009 | Apple iPhone Smartphone
Unable to unlock my phone
Your device might have a problem in the touch screen.
In iPhone 2G the touch panel and the LCD screen are one unit that cannot be separated.
You shoud try to replace the iPhone screen with a new one and the problem should be fixed.
Aug 28, 2009 | Apple iPhone Smartphone
SCREEN WON,T STAY LIT UNLESS I TOUCH IT
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
Blackout Mode On and Off
When Blackout mode is turned on, the monitor display will turn off to
reduce power consumption.
This additional power enhances the sound quality.
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
To make the setting, set to “Setting the VISUAL Touch Button” (page
34).
If any button on the unit is pressed during Blackout mode, the
function will be displayed for 5 seconds to show the operation before
returning to Blackout mode.
While the backlighting is turned off, the function indicator
Jan 24, 2009 | Alpine IVA-D310 Car DVD Player
Sony pc 101 camcorder
Weird.. same with mine! Seems perfectly fine with exception to this problem. No obvious damage, camera still functions as expected, but yes, not responsive to touch. Could it be a date issues (2008.. lead year ?).
Karlo
Jan 01, 2008 | Sony Handycam DCR-PC101E Mini DV Digital...
Lighting the oven
Control Lockout (on some models)
Your control will allow you to lock out the
touch pads so they cannot be activated when
touched or cleaning the glass panel.
To lock the controls:
Touch the 9 and 0 touch pads at the
same time for 3 seconds until the
control beeps twice. The display will
show LOC continuously and the time
of day if not blacked out.
NOTE: All cooking and timing functions will be
cancelled when locking out the control.
To unlock the control, touch the
9 and 0 touch pads at the same time
for 3 seconds until the control beeps
twice, and LOC will be removed from
the display.
NOTE: Some models have a Control Lockout
pad. Touch and hold it for 3 seconds to
lock/unlock.
Gas/Control Lockout (on some models)
surface burners, oven burners and control
panel so they cannot be activated.
To lock/unlock the controls:
Turn all surface burners off.
Touch and hold the Gas/Control
Lockout pad for 3 seconds until the
display shows LOC ON.
To unlock the control, touch and hold the
Gas/Control Lockout pad for 3 seconds
until the display shows LOC OFF.
When this feature is on and the touch pads
are touched, the control will beep and the
display will show LOC ON.
 The control lockout mode affects all
controls. No controls will work when this
feature is activated.
 The adjustment will be retained in memory
after a power failure.
Nov 30, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Sony Handycam  DCR-DVD108 DVD Camcorder Logo
126 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
