Question about Hamilton Beach 31197 120 Watts Toaster Oven with Convection Cooking
Cannot find temp control switch 901b-r anywhere..if you know where to find this switch I would appreciate your help.
The oven does not heat up when I turn it on. what is wrong with it?
could be one of several things or several ,timer , switch ,element, fuse and on and on
Mar 17, 2015 | Toaster Ovens
Our toaster oven smokes and smells like insulation while in the oven mode. It does not do this in the toaster mode.What might be wrong?
Hello, jcsizma
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about toasters andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances1.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Sep 20, 2011 | Euro-Pro 0.7 Cu. Ft. Convection Toaster...
I need a Timer/Toaster selection knob for my toaster/oven model To289. Mine broke off.
Hello, toddross
Thanks, Mike
Aug 19, 2011 | Euro-Pro EuroPro 6Slice Toaster Oven with...
All three knobs on my toaster oven that I purchased for Christmas have broken off.... Help...... Oven is great , but i have to use a knife to turn the oven on and control the temp.
First check for a Euro Pro website. If that doesn't work then here is an address that you and copy and paste into the address bar. This will give a list of sites that carry oven parts.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 01, 2011 | Euro-Pro Toaster Ovens
I need a new timer switch for my Oster oven, model 6297.
If your part # is DKJ/1-60 you won't find one anywhere. There is a switch made for Delonghi ovens that will work. The part # is 05XDE5218104600. The Gourmet Depot website has them. If you have a different switch, look on smallappliance.com or search "small appliance parts" for a few other places that may have your switch. You will need the make and model # of the oven if you do not have a part #.
Jun 18, 2009 | Oster 6297 Toaster Oven with Convection...
Toster Timer Switch Broke
I had the same problem with the same exact switch DKJ/1-60. This part cannot be found anywhere but the factory and you'll have to buy 5,000 if you want one. There is another switch made for Delonghi that will work but it only has timer for toast. No 60 min. timer. The part # is 5218104600. This switch works the same way as the original but you will only have about a 13 minute timer. There is another one that has a 120 min. timer. The part # is 5218101800 for Delonghi. These switches look the same as the DKJ/1-60 but you may need to use parts from your old switch to mount these switches. Another solution to the problem is to replace the bad switch with a single pole single throw toggle switch that will handle 20 amp's on 120 volts AC. You will no longer have a timer and you will have to turn the oven on and off manually but at least you will be able to use the appliance. The above switch can be purchased at Gourmet Depot website for $10.98.
Jan 28, 2009 | Black & Decker CTO649 Toaster Oven with...
Instruction Manual and Recipes
Try manuals.com they may have what your looking for there . Good luck .
Apr 24, 2017 | Black & Decker TRO6100CT Toast-R-Oven Plus...
Broiler element
Its an on or off thing. No way to control the flow of electricity.
The elements are bigger than necessary to heat the unit quickly, the problem you have is a bad thing with food that burns easily but a good thing that makes these units come up to temp so quickly after turning on.
Unfortunately the only thing you can do is put more space between the element and your food or use aluminum foil (not suggested, its too close to the burners).
Eventually the contacks will fail (unless you are one of the lucky ones).
Good Luck
Feb 03, 2008 | Cuisinart TOB-30 Toaster Oven with...
Oven does not turn on
These ovens have a timer switch that lasts just about a year. Mine did the same thing and you cannot find the timer switch anywhere in the USA. The switch is likely a DKJ/1-60. There is a switch made by Delonghi that will work. The part # is 05XDE5218104600. You can get one at "The Gourmet Depot" website for $10 + shipping.
Jan 23, 2008 | Black & Decker CTO6300 Toaster Oven with...
Hamilton Beach 31197 120 Watts Toaster Oven with Convection Cooking Logo
88 people viewed this question
Top Hamilton Beach Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Steve F
Are you a Hamilton Beach Toaster Oven Expert? Answer questions, earn points and help others
