Question about Whirlpool Washing Machines
Whirlpool wfs1071aw. the appliance has no or insufficient water supply and the tap is open. indication light is still on
  • bear090909 Jun 19, 2008
    Just bought whirpool WFS1071AW on weekend. Light on "water tap closed" lights up even though cold water tap is open. The only time we could get the machine to wash was to reset the program to cold wash. Does all the other wash program require hot water?
  • dianejanerow May 11, 2010
    I have a front loading whirlpool machine WFS1071AW and a red light has come on indicating that I need to clean the pump. Could you tell me where the pump is because we were only givena basic chart when we purchased the machine.
I had same problem I needed to make sure the hot water was attached and turned on as it would not work unless both taps were on. can any one hep me with my problem my machine is washing in hot water even though ive had the hot water tank that goes to the laundry disconnected (as I have two H W systems)??? I begining to think that this model has a built in heater of some kind?? can some one look it up for me?
Posted on Sep 14, 2009
CHECK HOSES FOR KINKS. EVEN THE SLIGHTEST KINK WILL ALERT THE SENSOR OF INSUFFICIENT WATER FLOW AND CAUSE INDICATOR LIGHT TO COME ON.
I HAD SAME PROBLEM WITH AN INSTALL AND A SLIGHT KINK IN COLD WATER HOSE WAS THE CAUSE
Posted on Dec 05, 2008
My WFS1071aw washing machine won't turn on. All
This video will show you how to open your WFS1071aw washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 16, 2013 | Washing Machines
Dishwasher is not working, FP DW60CSW1, three of five lights blinking
It is possible you have this error
First 3
programme
indicators
flashing
E5 Water tap not turned on.
Insufficient water supply pressure.
Water supply hose is crimped or
bent.
Drain hose is too low.
Ensure the water is connected
and turned on.
Check household water pressure.
Check hose and straighten if
needed.
Ensure that drain hose is
connected in accordance with the
'Installation instructions'.
For details refer user guide.
Apr 08, 2013 | Fisher and Paykel Dishwashers
I have a WFS1071AW-7.5kg. It is stopping mid cycle and showing a red "Clean Pump" light on the front panel. Where is the pump and how do I clean it? Your help would be appreciated.
The pump is hidden below the removable kick plate at the bottom of the machine. Hold the plinth on either side and pul it downwards and outwards to remove it. The filter is unscrewed by turning anticlockwise.
This is covered in page 11 of your manual, a pathetically poor scanned PDF copy of which is supplied by whirlpool Australia if you go to this web address:
http://www.whirlpool.com.au/app.cnt/whr/au_AU/pageid/pgsrvifuhome001/DOCTYPE/IFU/DOCLANGUAGE/AU
Enter WFS1071AW As the commercial code and select language ENGLISH
Note: This model has no drain hose to get rid of residual water, suggest you tip the machine back 45 degrees and have a towel ready to catch any leaked water.
Aug 23, 2011 | Whirlpool Washing Machines
Have a Whirlpool Dishwasher 6ADP 5540. Starts cycle - fills water then about a minute into it the start buttons flashes 6 times and will not continue on. Very rarely, the cycle does continue on. Have...
Hi Jodie,
An F6 fault code - indicated by the green light flashing in sequence next to the start button - is indicative of a water inlet problem.
First of all check that the water tap the dishwaher connected to is fully open. If this does not work check that the feed pipe from the water source to the appliance is not blocked.
If neither of these two things are the problem then you will need to order a new flow meter/ reed switch and this will sort your problem out.
The Whirlpool UK spare part number you'll need is 481241868368
Hope this helps
Alex
Jan 14, 2011 | Whirlpool 24 in. ADP6940 Dishwasher
Red light showing water tap closed how do i rectify please
This usually indicates a problem with the water supply to the washer.
Check the tap/s are fully turned on, check that there is no restrictio orr kinks in the hose/s.
Make sure you have good water pressure.
Jan 27, 2010 | Whirlpool Washing Machines
Hi my problem is that my whirlpool duet washer front loader model wfw9200sqa10 is giving me a code number F20 and i dont know what could be the problem please help.
i believe i ve already answered this query....
F20" is a water inlet problem. This indicatesthat you have no water or insufficient water supply. What Whirlpoolrecommends to do is unplug the washer and check your water inletscreens to ensure they are not clogged, check the inlet hoses forkinks, and to make sure your taps are turned on (duh! I know it soundsstupid, but I've seen it before).
To check the water inlet screens you will need to turn off the water supply and disconnect the hoses where they connectto the back of the washer. The inlet screens are located inside the tapfittings and sometimes will collect with sediment and rust depending onyour water source. Some hoses also have sediment screens. Check them aswell if you have them. Use cotton swabs to clean the screens,thoroughly.
Checking the hoses and taps is self-explanatory. Thewater supply coming into the washer should be at least 10-25 psi.Insufficient water pressure can cause problems with slow fills and/orerror codes due to insufficient pressure. If you haven't had anyproblems before, I would suspect dirty inlet screens and/or a inletvalve failure.
If you need to replace the water inlet valve,searspartsdirect.com carries the part. Just type in your model numberin the Search menu and look for item #1 under the "Dispenser Parts" The part runs about $52.00.
regards iversh
Sep 21, 2009 | Whirlpool WFW9200S Front Load Washer
WFS1071AW is my type of whirlpool front loader
Hello baud Welcome,
You said the water entry into the machine is fine with nothing blocking it. But you keep getting the red light on for "water tap closed". At one point the water did start flowing in but soon stopped and turn on the warning light again. Please suggest how to fix it??
I believe this sounds like the screens are dirty and stopping water flow so it shuts down!
Dry all of the below suggestions.
Washer displaying code message and or tone sounds
“F20” (Water Inlet Problem—no water or insufficient
water supply)
First:
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.Leave power off for 5 minutes. This will reset the system!
Check the following:
Are water faucets completely turned on?
*****Are screens at inlet hose connection to washer clogged?
Remove hose from washer an clean screens at water inlet!
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Let me know how you do.
Thank You Huuum
Please remember to leave a rating!
Oct 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing cycle starts and takes hours even for short cycle.
Try checking for good water supply.
Pull out detergent tray and check for good water supply during filling.
if poor filling-
Try checking the hoses.
Turn taps off, disconnect from machine, place hose end in sink, turn tap on and check for good water flow.
if the hose has a red indicator in the side of the hose (end which is fitted to the tap) - Red indicator is a failed hose.(for models with Water Stop hose type "B")
Oct 05, 2008 | Whirlpool AWM6120 Front Load Washer
Duet washer WFW9200SQ00 display F20
"F20" is a water inlet problem. This indicates that you have no water or insufficient water supply. What Whirlpool recommends to do is unplug the washer and check your water inlet screens to ensure they are not clogged, check the inlet hoses for kinks, and to make sure your taps are turned on (duh! I know it sounds stupid, but I've seen it before).
To check the water inlet screens you will need to turn off the water supply and disconnect the hoses where they connect to the back of the washer. The inlet screens are located inside the tap fittings and sometimes will collect with sediment and rust depending on your water source. Some hoses also have sediment screens. Check them as well if you have them. Use cotton swabs to clean the screens, thoroughly.
Checking the hoses and taps is self-explanatory. The water supply coming into the washer should be at least 10-25 psi. Insufficient water pressure can cause problems with slow fills and/or error codes due to insufficient pressure. If you haven't had any problems before, I would suspect dirty inlet screens and/or a inlet valve failure.
If you need to replace the water inlet valve, searspartsdirect.com carries the part. Just type in your model number in the Search menu and look for item #1 under the "Dispenser Parts" heading (part #8182862). The part runs about $52.00.
I hope this helps you. If you need further assistance, please post back with any questions/concerns you may have.
Apr 16, 2008 | Washing Machines
Washing Machines Logo
549 people viewed this question
Dan Webster
Dan Webster
Sal De
