Question about Philips HD1500U System
Not connection betwen Headphone and Base Station
Headphone lost connection with Base station. When I turn on Base Station led from right speaker blinking 1-2 second (I don't known what this mean). And Headphone can't find signal.
  • Anonymous Jun 02, 2008
    I have the same problem , anyone can help ?
I have the same problem since yesterday , pls help
Posted on Jun 02, 2008
My docking station for my ipod classic does not seem to be working anuymore
If your docking station has an AUX IN port, connect the iPod from the headphone on the iPod to the AUX IN port on the docking station using an audio cable.
Jan 09, 2015 | Audio Players & Recorders
I just bought a used jvc rx9010. it powers up but no sound from any speaker and shows headphone all the time what should a layperson check???
No speakers are selected if just headphone is displayed. Press the speaker button just under the power button. No station is tuned when auto muting is displayed. Hook up an antenna to the receiver or use a different source like a cd player.
Apr 07, 2013 | JVC RX-9010V Receiver
What does the orange light mean on your sony pulse headset? And why doesent make noises when its turend on?
check the cables to the base-transmitter station. If they are firmly connected or try to replace them. Most of the wireless headphones of some more advanced design detects incoming signal and switches to mode on wich indicates with another color when the sound dissapears the headphones detects no sound and goes into a powersaving mode. Usually the headphone itself doesn't fault very often, cause they are battery powered and the powersupply isn't wavering like the powertransformer to the base-station due to the irregular power from the ac outlets, wich is why any electronics should be connected to a surgearrester list.
Another thing to check for is there any sound coming from the tv/game connector, try to connect a nother speaker assembly or headphone or if the connector is of a low signal type, a amplifier with speakers or headphone make sure you don't have to much between where the sound comes from and the headphones. Let me know if some of my advice helps you!
Jan 25, 2013 | Radio Communications
I changed batteries and forgot how to reconnect. It is plugged in via USB, batteries are birght. I have pressed the connect button on the base. It flashes but the mouse does not work. I have pressed the...
This is from the manual for the Logitech MX700 cordless optical mouse.
1. Press connect button on Base Station.
Its LED blinks green. 2. Press connect
button on mouse bottom. Base Station LED
turns solid green, and then off.
I hope this helps
Mar 07, 2010 | Logitech MX 700 Mouse
I've had my phone for about 15 months. It still works people can ring me and I can call out. However, I have totally lost sound. The keypad sounds and ringtone do not work and I can not hear anyone on...
Its internal speaker (not the earpiece speaker) is dead. I dropped a phone handset of mine and the little speaker snapped off of the circuit board internally.
You don't say if the unit (model ???) has a base station or is wireless. My base station would still ring.
Jan 26, 2010 | Samsung 500w Rrss Rear Reflecting Surround...
I have the swatch cordless II phone with base station however I have lost the instruction manual for the base station and therefore cannot register the handset with the base station. Has anyone got a...
To register a handset with Cordless 2 base: Keep pressing call button [loudspeaker icon] on base for 5sec. then press [right pointing arrow in a diamond] twice. Then 9 0 1 then the system PIN if required. Choose internal number 1 to 6 for this handset and then the designation of the base station A=2, B=5, C=8, D=0, followed by [right pointing arrow in a diamond].
Hope that helps!
Jan 17, 2010 | Lands Phones
Only noise from PC to monitor through docking station
I have the same problem and tried down loading the lates drivers without any change. It was working fine. I was in the middle of listening to music when it started.
Aug 22, 2009 | Toshiba Dynadock Port Replicator, Docking...
ADDING A BUZZER TO A CHAMBERLAIN BASE STATION
I have never worked with that unit beofre, but I can take a shot. Visit your local car audio dealer, and pick up a LVT (low volatage trip)..Open up the base station, and disconnect the signal wires to the buzzer/speaker. Use those wires to feed the low voltage turn on in the LVT. THe LVT acts just like a relay, but requires much less voltage to trigger. So in theory if you use the LVT it shopuld power up your external speaker properly when the station is triggered, and is a fairly simple install.
Aug 07, 2009 | Chamberlain Wireless Perimeter Alarm
Loosing Connection between MN500 & MN520
If you are using XP, and installed the proprietary WiFi software (not the built in XP software), did you turn off the Zero Configuration Wifi SERVICE? Running both will cause issues with your connections..
Start > Run > services.msc (ok)
Dec 22, 2007 | Microsoft Broadband Networking MN-500...
Sound - one speaker broken
I suggest try updating the firmware of the player. Have you tried listening to the FM station to see if it is only the songs that are being affecter? Also try to use another headphone.
Jun 04, 2007 | SanDisk Sansa e250 MP3 Player
Philips HD1500U System Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
