Question about LG Dishwashers
Dishwasher makes a lot of mechanical noise when running
    President:
  • 1,197 Answers
If your dishwasher seems noisy, check these:
Water-inlet valve
An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor
If it's the motor that's noisy, either of these may be the "culprit:"
As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan
If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump
Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
1 Look at the heater fan to check for rusty or squeaky parts. If defective parts are found, replace the fan. If not, go on to the next step.
2 Replace the water inlet valve, which is located at the bottom of one of the sides of the dishwasher, beneath the lower access panel. As a water inlet valve ages, it can sometimes slowly stop working correctly, switching between "on" and "off" every few seconds. This can cause a shaking and rattling noise. If this does not fix the noise, go on to the next step.
3 Remove the lower rack and the lower spray arm from the dishwasher, removing any screws as needed to do so.
4 Beneath the lower spray arm is a pump that contains a propeller. Check the pump for debris (like small bones, seeds, or fragments of glass) that might be causing the noise. If this does not fix the noise, go on to the next step.
5 Beneath the pump is the dishwasher's motor. Check to see if the plastic dish at the top of the motor has broken off. If it has, it may be rattling when the motor is on and causing the noise. In this case, replace the entire motor.
6 Check the bearings on the motor. If they are worn out, replace them.
7 If you cannot trace the noise to its source, try replacing the motor.
Posted on Sep 03, 2010
  • SAM JAYANTH CHANDRASEKAR
    If you do find my solutions helpful .. please dont forget to rate the Solution. they are our encouragement to Serve you folks better.
  • frank mohr Nov 25, 2010
    MINE IS A LG 3850DD3006A AND YES THE GARBAGE DISPOSER GETS STRAWS AND JUNK IN IT. OR THE SCREEN ON THE TOP IS COVERED WITH MACARONI AND CHEESE. OR TWICE IN 4 YEARS THE MOTOR RING SPLIT AND THE MOTOR STARTED TO GRIND THAT RING TILL IT STOPPED ALLTOGETHER.
    WHAT A PEACE OF JUNK!!
    I ADMIT THE STRAWS ARE THE USERS FALT!
    SO MY NOISES ARE STRAWS, THE MOTOR, AND TOO MUTCH FOOD COVERING SCREEN IN BOTTOM NEAR SPLASHER BAR, OR ONCE IT WAS GARBAGE DISPOSER UNDER SINK THAT WAS CLOGED FROM NOT RUNING IT AND FOOD HAD BUILT UP INSIDE, BLOCKING DISHWASHER DRAIN HOSE.
2 Suggested Answers
  • 23 Answers
SOURCE: My dishwasher is making lots
noise... if squeal, bearing on motor... if at start and end of cycle could be water restriction through pipe...
Posted on Feb 28, 2011
Why is my whirlpool dishwasher making a loud noise during drain, wash and rinse cycles?
They can be complicated to re-assemble. Best solution is to video the procedure (if you have a video camera) during disassembly and make notes and diagrams to orient things properly and make sure the correct screws go back where they shoud. Takes more time, but you'll be glad you did, it will save you a lot of aggrevation in the long run.
Aug 24, 2014 | Whirlpool 24 in. GU1500XTLS Stainless...
Hi, it make a loud grinding noise while it runs.
Hello pwturnbull, thank you for allowing me to assist you.
Typically, when a dishwasher is making a grinding noise during operation, it is because it may possibly have a faulty drain motor. This is not a typically DIY job. I would recommend reaching out to an experienced appliance tech just to ensure the precise issue to help narrow the precise issue. Parts are often costly and, it can save you a lot of time and funds. I hope these troubleshooting tips help you in some small way.
Sep 12, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
My dishwasher is making lots of noise when it is running.
Feb 28, 2011 | Dishwashers
My dishwasher is making a loud buzzing noise but otherwise is working ok. What could the noise be?
Check to see what is working or running when it is making the buzz...is it when the water is coming in ...then it would be the soleniod coil on the fill valve...
if it is when it is washing, then it would be the motor going bad...
if it is when it is draining, then it could be the pump if you have a separate one or it could be a soleniod that directs a flapper to run the water out...
lots of possibilities...
heatman101
Aug 15, 2010 | LG 24 in. LD-12BW5 Free-standing...
Washer makes a grinding noise while running in the wash cycle. I've confirmed the rotors in the unit are not hitting anything inside the tube. The noise seems to be coming from the drive mechanism...
You will likely have to remove the pump motor from underneath to solve your problem. Try removing the lower spray arm assembly down to the deck and check the pump impeller for noises. Make sure to note the position and placement of all parts removed. Hope this helps!
Jun 28, 2010 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher makes grinding noise when running
Sounds like you have debris like broken glass in the chopper assembly of your sump assembly. Best of to call a Certified Repair Company such as Sears if you are not mechanically inclined.
Mar 20, 2010 | KitchenAid Dishwashers
Top drawer is ok. Bottom drawer makes lots of noise, but finishes the cycle ok
Can you describe the noise:
Water noise,
Mechanical sound noise.
Motor noise
Rattle noise
Jun 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
HDA3400G020WW noise
dear sir the problem you have sounds like the solenoid that opens the drain actuater can be worn out open the bottom panel run tru a cycle observe when the solenoid open it may be that there is something causing the solenoid to buzz either worn out or a wire or something in the way causing not to close proprly thanks from gilles
Mar 10, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Dishwashers Logo
963 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
