Question about Yamaha Audio Players & Recorders
I am having trouble with the setup of the yamaha RX-v2056 Amp. TV is connected via HDMIout1 Sky + hd box is connected via hdmi4 Blue ray dvd is connected via hdmi1 The TV Sony KDL-40V3000 recognises both boxes With sat box switched on and blue ray switch off then switch TV on the amp powers up. After a short period it goes straight to bddvd, problem one? I then select the TV button and it goes to the Sky + hd box, I get the sound but the picture flashes on and off. After several selection of the TV on and off I get a steady picture. Problem two?
SOURCE: Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Posted on Jun 02, 2008
SOURCE: no zone 2 sound coming from yamaha amp rx-v861
Had same problem. A and B speakers are basically connected together, and there is no way to get the same volume out of each speaker. This is not a multi-source receiver like Onkyo. Zone 2 needs to go to a seperate amplifier and select teh correct source on the fornt,
Posted on Jul 12, 2008
  • 7 Answers
SOURCE: Compatibility issue: Sony BDPS350 Blue-ray & Yamaha RX-V1700?
HDMI compatibility issues continue to plague the industry and this more than likely is the problem. There are a couple of ways around this.Some people insist on "hot rodding" the dvd and tv by hooking up directly to each other avoiding the receiver all togeether (I do this).But you lose functionality and it makes things more complicated for other family members. Your best bet is to use RGB and Digital audio cables.You won't notice any quality loss and there is a possibility it will look better.
Posted on Jul 07, 2009
  • 127 Answers
SOURCE: I have a Yamaha RX-V863 receiver connected to a
Do you have all 5+1 speakers connected? You need to go to the Setup menu of yamaha and set which speakers you have and which you don't. For example if you don't have the Center speaker connected, receiver will redirect and mix the sound to the other speakers.
Blue-ray film over HDMI should automatically output via all your configured speakers (nothing to be configured).
Posted on Mar 02, 2010
ProColorTV
  • 25 Answers
SOURCE: need an drawing showing hou to connect yamaha rx-
Hell Fixya customer,
Here are two links for the Yamaha receiver, and the Sony user manuals.
Please look through them concerning your specific hookup. If you still have questions or need help, please let me know.
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V430e.pdf
http://www.sony.com.au/support/product/kdl-52z5500
Thank you for using Fixya
Posted on May 01, 2010
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
Yamaha rx-v663. Want to watch cable tv while listening to cd (blue ray).
Don't think there is a way to make that happen with your setup
Dec 31, 2012 | Yamaha RX-V663 Receiver
I have skyhd connected to Lght-805sh via optical connection but when i turn sky over from a hd channel to normal channel there is no sound
Not sure what you mean by "optical connection" but you need to connect your SkyHD box to your TV using both HDMI and SCART cables. Your Sky HD box will then send the signal via the HDMI cable for the HD channels and the SCART cable for the SD channels.
Hope this helps
BElectric
Nov 06, 2010 | LG Televison & Video
Nov 26, 2009 | Yamaha RX-V863 Receiver
I would like to hook up my components without having to turn on the receiver to watch tv from DVR or Cable if possible. I have Scientific Atlanta Explorer 8300 HD Cable DVR w/HDMI out, Samsung TV w/HDMI ,...
You should not lose any picture quality from the DVD player. I am currently having the similar setup with PS3 as the Blu-ray DVD player with HDMI and a Samsung DVD as regular player with component cable to a Samsung LCD TV. Remember the quality on Blu-ray is better than normal DVD so don't expect more than what it is.
Oct 07, 2009 | Yamaha RX-V463 Receiver
The Yamaha RX-V463 AV does not playsound from the blue ray player
"I am also having difficulties in try to display the yamaha set up menu on the tv."
According to the manual the display menu for TV will not work with HDMI hook up.
I also have a Panasonic HD TV and can't get TV sound through my Yamaha AVR on "TV Sound" mode.  Trying to use HDMI cable for this also.  Do I need a digital optical cable or do I not have something set right?
Apr 07, 2009 | Yamaha RX-V463 Receiver
Hookup diagram for Yamaha avr-863 receiver
It's the other way around.
Hook up the Cable box to the Amp; and the blu-ray to the amp, then connect amp to LCD.
you want to use the best available options for audio:
HDMI > Digital Optical > Digital Coax > standard RCA
And the similar for video:
HDMI > Component > SVideo > RCA cables
I would connect Blu-Ray via HDMI to Amp, and Cable box via HDMI to Amp. If your cable box does NOT support HDMI, but you have an HD package, ask your cable company for an upgraded box.
Mar 19, 2009 | Yamaha RX-V463 Receiver
Dec 29, 2008 | Yamaha RX-V1700 Receiver
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
