Question about Whirlpool Washing Machines
The belt comes of when the machine goes into spin.
    President:
  • 1,932 Answers
This is because the belt might have become lose.When in spin mode the motor rotates really fast which slips off from the wheel in which it is mounted.Please replace with the correct size of belt and this wont happen again.Check with the previous belt there will size number printed on it.Get the same size belt and fix it.
Thank You
Posted on Sep 03, 2010
Toshiba washing machine model AW9770SB after rinse
Run A diagnostic and see what error codes u get? the lack of spin is usually a result of a bad clutch or tranny problem. Loose belt if its belt driven and not direct drive. Also on a direct drive the motor coupler may be bad ( which connects motor to tranny) may be defected but when it goes u usually dont get much agitation either.
Sep 27, 2014 | Washing Machines
Belt has come off
It may not be the belt. Hopefully it is though. Unplug the machine. Remove the 5 or 6 screws holding the back plate on and remove it. There will be a circular spindle in front of you (called a spider). The belt goes around this and the motor underneath it.
Nov 21, 2011 | Indesit W 123 Front Load Washer
My Frigidaire Crown Series top load washer was agitating but would not spin. It did drain the water. The lid lock did lock when it was in the spin position. It was smelling like burning belt so I...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 20, 2011 | Frigidaire Washing Machines
Drive belt on hotpoint wm56 keeps coming off when machine goes on fast spin. I have fitted a new belt but it still keeps happening.
Make sure belt is reasonably tight, and it is in the center of the drum pulley, if it still comes off, then I would suspect that the drum bearings are worn, or the drum is running out of alighnment, or the motor bearings are worn, if it is noisy when you spin the drum by hand, then the bearings have definately failed.
Please rate my solution.
Thanks.
Sep 22, 2009 | Hotpoint WM56 Front Load Washer
My kenmore won't pump out the water. what could
couple of possible reasons and this will vary by brand of machine...lid switch could be bad...some machines will wash or agitate with lid up but will not spin unless lid is closed..others will not do nothing with lid up....some brands will not spin if the water level switch can detect water in the tub...this means your machine didnt pump the water out of the machine so it could spin couple of reasons for this 1 bad pump or bad pump motor(some machines have a pump that is driven by a drifferent motor than the one that drives the transmission)usually these machines use the water level switch to activate(turn on/off) the pump when the machine goes into spin cycle... some machines the pump wil come on and stay on for the entire spin cycle...some machines the belt will be bad and you just need a new belt....first thing to do is see if raising the lid will turn the machine off when it is in wash cycle if it does not..then it will in spin cycle..if the machine will not work in spin cycle the lid switch will be the reason why..
Sep 13, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer Won't spin & smells burning when it goes on spin
Hi there.I think it could be that when the belt was changed the bolt wasnt tightened onto the flat side of the spindle.I am talking about the small pulley that comes off to replace the belt.It has one flat side in which the bolt needs to be otherwise it might just spin because the laundry weight. Quick question I have this machine and it needs a replacement belt.I cant find one anywhere!!!!Where were you able to find one???? Good Luck
Feb 19, 2009 | Danby DWM99W Top Load Washer
Washing Machines Logo
23 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
