Question about Car Audio & Video
My kenwood head deck kdc-mp6036 shows on the screen protect what's wrong with it
My head deck often resets for no reason
Posted on Aug 09, 2008
    Brigadier General:
  • 6,966 Answers
A "PROTECT" message/display normally indicates a problem with your speaker or your speaker wires. Pls check for any open or shorted (busted speakers) or if any of the wires are touching the chassis/ground.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 11, 2008
KDC-MP4032 head unit wont turn on
hi, seeing that your kenwood showed up "protect" you may have an audio circuit/amplifier fault within the unit. try resetting the unit to see if unit comes "on" again. if the unit comes on and protect flashes again, then you definitely have an internal audio circuit fault. if not then check all power connections(yellow and red wire voltages, as well as ground connection), as well as the condition of the face pins!
May 31, 2012 | Kenwood KDC-MP4032 CD Player
I wired up my kenwood kdc-mp336 stereo nd it keeps flashing on the head deck protect how do i get rid of that
It is going in to protect mode(check that no wires are crossed or hooked up wrong)
Aug 30, 2011 | Car Audio & Video
My Kenwood KDC-X493 deck is flashing "Protect" ,
You can unplug the unit for 10 minutes. This will clear this.
Jan 19, 2011 | Kenwood KDC-X493 Car CD/ MP3 Player
MY kenwood KDC-W3044 is showing protect on the screen....... what should i do to remove??????
Dec 11, 2010 | Audio Players & Recorders
I have a Kenwood KDC-MP442U Deck and protect will not come off
check speakers for a short protect means one of the speakers are shorting so check all the connections on speakers or if you have a multimeter put the black to ground and put it on contanuity and check from the plug at the unit and it will beep if one is shorting then you know which one to check instead of pulling your whole car apart:)
Apr 26, 2010 | Kenwood KDC-MP442U
My kenwood kdc-mp53u flashes PROTECT whats wrong with it?
Protect indicates that there is a short or a grounding problem usually within the speakers2_bing.gif or the speaker wiring. Locate and press the reset button (pinhole). If protect comes back then disconnect all speakers, reset and connect them back one at a time until protect shows up again. This will help you find out where the unwanted DC signal is coming from. If protect shows up when all speakers are disconnected, then it may need service.
Apr 11, 2010 | Kenwood KDC-MP538U Car CD/ MP3 Player
Protect message on screen
When 'Protect' shows up when you turn on a kenwood deck it means there is a speaker short somewhere that it is detecting. Make sure all connections are insulated and that none are accidentally touching the chassis of the vehicle.
Jul 06, 2009 | Kenwood KDC-MP638U Car CD/ MP3 Player
Kdc-mp6036 kenwood cd player jus cant find the code
Today i brought a 98 ford and the dealer replaced the cassette player with a Kenwood KDC-MP6036 from a trade in they had. It was fine for 30 min approx then music stopped and "PROTECT" was displayed and now nothing works ???? what can i do
Aug 07, 2008 | Kenwood Audio Players & Recorders
Flashing PROTECT
This is often caused by a problem with the speakers or speaker wiring. A speaker wire that's pinched behind the head unit will cause this problem if it's shorted to dash metal or the deck chassis. The first thing to do is remove the head unit and inspect all the speaker wiring for bare spots or pinched spots. If everything looks okay, disconnect all four speakers from the deck and switch it on. If it still shows "protect" then you have a defective head unit. If not, then turn it off, re-connect one of the speakers, and turn it on again. Continue until you find the speaker output that puts the deck into protect mode.
Jun 25, 2007 | Kenwood KDC-MP4032 CD Player
Car Audio & Video Logo
139 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
