Question about Sony PlayStation Portable (PSP) Console
Update version error code "DADADA"
  • 1 more comment
  • Anonymous Nov 15, 2008
    cant update my psp it says dadada
  • corne1ius Dec 28, 2008
    Tryin to upgrade PSP. Having the same error problem...what does it mean in layman terms and how do I solve it.. Thanks
  • dotanoob2008 May 20, 2009
    same here i tried downloading it a few times but it still has the same prob
How to modified psp version 4.01
Posted on May 21, 2009
You need to go online to update your psp
Posted on May 11, 2008
  • lukeboi May 11, 2008
    go online on your psp not computer
2 Suggested Answers
  • 134 Answers
SOURCE: dadada error
you can't update firmware from 6.2 to 3.5
you will really get error.
Posted on Mar 07, 2010
Windows Update won't let me do Updates Error Code D0000034
Hey friend you can go to https://plus.google.com/u/0/105276208727413473827/posts
to get one, you can find all versions of product keys for windows, it works well and the price is surprisingly cheap!
Feb 01, 2013 | Computers & Internet
Error code 20145 84555
Click this link and follow steps to restore a backup for use with an earlier QuickBooks version.
Prepare you file for updating.
Close the company file in the previous version.
Open the company file that has been rebuilt and update to the new version.
Rebuild the company file in the new version of QuickBooks to ensure the error does not occur.
For more help visit
QuickBooks Tech Support
Mar 29, 2012 | Intuit QuickBooks Pro 2008: Windows
Error Code 28
Hello
Unplug the AC power chord for about 10 minutes, and then replug it and see whether it helps you.
Confirm the current software version.
If the software version is updated, if the software update has succeeded. If not, try again.
Do not unplug the unit frm AC while the software is udating. All settings will remain the same even if you updated the sofrware with newst version.
Nov 13, 2011 | Televison & Video
Dadada error when trying to install update 6.20 from 3.52
Mar 04, 2010 | Sony PlayStation Portable (PSP) Console
These are the two errors I keep getting and I cant
Try reinstalling from scratch...remove all and install the oldest and update from there....if you have a problem then go back a step the last known working version.
PLEASE VOTE IF THIS WAS HELPFUL..THANKS AND GOOD LUCK.
Nov 22, 2009 | Audio Players & Recorders
Update KB946140 and Error Code 646
Sometimes MS update has compatibility issue.Better no to install cause sometimes it can create a bug (Blue Screen Crash) to your system.Try to restore yor windows 7 to an earlier point and the error message gone.Also try to turn off your automatic update so that you can choose your update to be installed.
Nov 09, 2009 | Microsoft Outlook with Business Contact...
Windows up date will not install error code 663
This is an error having to do with the .NET framework. You probably have version 2.0.
1. Before doing anything else, write down the .NET Framework versions which
are already installed:
How to determine which versions of the .NET Framework are installed and
whether service packs have been applied
http://support.microsoft.com/kb/318785
2. Now see Resolution Method 2 in...
When you try to install an update for the .NET Framework 1.0, 1.1, 2.0, 3.0,
or 3.5, you may receive Windows Update error code "0x643" or Windows
Installer error code "1603" (ignore the title, if need be)
http://support.microsoft.com/kb/923100
After running the appropriate/needed tool, (re)install all .NET Framework
versions manually using the download links on the page then run Windows
Update manually to install security updates for same.
NB: KB923100 references this page:
http://blogs.msdn.com/astebner/archive/2006/05/30/611355.aspx. Please read
ALL of it as well as the related page
http://blogs.msdn.com/astebner/pages/8904493.aspx before using the .NET
Framework Cleanup Tool.
Or see the "How to obtain help" section of
http://support.microsoft.com/kb/953297
Nov 04, 2009 | Office Equipment & Supplies
Error Code: 0x66A
It appears to be a Dot Net framework installation error related to the version or an update patch.
The likely solution that will work is to use add/remove programs to remove dotnet installations or updates (updates first) then reinstall dot net from Microsoft.
Usually this error is due to trying to install a wrong version or having two versions installed.
Oct 24, 2009 | Microsoft Windows XP Home Edition
Psp
You just connect the psp to your computer using a usb cable.Then create a folder in your Memory Stick Duo named “PSP“, under this folder, create a sub-folder named “GAME“, under this sub-folder, create another sub-folder named “UPDATE” (Note: all folders name must be CAPITALIZED).Download the PSP 5.51 update file via this link: http://du01.psp.update.playstation.org/update/psp/image/us/2009_0611_148d2a024741df54eacabbc79d9f3014/EBOOT.PBP.Save the file as “EBOOT.PBP” to your desktop then inside the UPDATE folder copy the EBOOT.PBP.Then go to games>memory stick and hit the x button there should be an game press x again to upgrade.The udpate process will take about 10 minutes.Thats all.
Aug 22, 2009 | Sony PlayStation Portable (PSP) Console
Psp version not updating
have you tried downloading the update not through the game but on the update software feature on the psp? it should be the first option in the system catergory, u will need to link it to urs or a friends wireless net first though just 4 a few minutes, or use mc donalds free wifi in shop, lol. hopefuly it will download succesfuly through a direct sony link download that way.
Apr 01, 2009 | Video Game Consoles & Games
Sony PlayStation Portable (PSP) Console Logo
458 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
