Question about Epson STYLUS CX5900 Printer
E-02 Error "Replace Ink Cartridge"
I haven't use my printer for months and I remember that there are still yellow, cyan and black ink and no blue ink when I stopped using the printer. Now, I will use it, it said that I need to replace all the ink. So, I replaced it with the original inks but the error still persists. I need to replace ink. Meaning, it did not recognize the ink I replaced. I tried to remove it and place it back again. But still the problem is the same. What will I do to fix the problem?
  • 1 more comment
  • Anonymous Jul 29, 2008
    clean the printer nuzzels[heads]
  • Elvandar Feb 06, 2009
    Same problem, cant find any solution, first time tried to replace cartridges, when i try individualy at a time i get to three cartridges recognized, but when i put the 4th one in all dissapear accept one. Now ive a got a printer that dont print.
  • rdomingos Feb 18, 2009
    I replaced the black ink cartrige and now the printer shows me an error E-02 as if doesn't have any ink cartrige instaled. I allready replaced that same ink cartrige twice and it didn't work.
    HELP.....
After you have installed the new ink, take it out again, and check that the hole has been pierced. Then, shake the ink by giving it a quick suck until some ink comes out, and then replace the cartridge into the printer. This worked for us anyway. Good luck!
Posted on Jul 25, 2009
  • cavide06 Jun 06, 2011
    MY EPSON STYLUS CX5900 CANT PRINT THE RIGHT COLOR, HOW TO FIX THAT TNX
There is a program called SSC Service Utility, but for me it didnt work, I still have the same problem. But, who knows for you work!
Posted on Oct 23, 2008
Estou enfrentando a mesma dificuldade , erro 02 cx5900 ate o momento não tenho nenhuma solução
Posted on Nov 26, 2009
  • 3 Answers
Any other ideas to try? I read I could download a reset but I can't find it.
Help, Printer not working.....
Posted on Oct 02, 2008
2 Suggested Answers
don_farr
  • 1018 Answers
SOURCE: Brothers MFC885cw can't recognize new cartridge
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Posted on Mar 08, 2010
Getting error message...the following cartridges red blue yellow appear to be missing or damaged. I removed the red and blue cartridge. There was no yellow,cartridge. The only cartridge I have in th
Hi. Most ink cartridges are cyan magenta yellow and black. You do have to have all cartridge installed for it to work. If it's been sitting for a while ink dries and can cause all kinds of little problems. The ink cartridges have little contacts on them you might have to clean these with a cotton swab and alcohol. But if the ink has dried in the print head you have to clean all the little ink ports on the head.
Feb 10, 2015 | HP Office Equipment & Supplies
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
Is it possible to use non HP ink in ths printer? Tried using "remanufactured ink", and concluded that this printer may be programed to block the use of NON HP INK.
It is always recommended to use genuine HP cartridges.
As if we will use the non HP or refilled cartridges, it will reduce the life of the printer.
And we will get an error "cartridge problem".
Plaese use the below cartridges, which are compatible with this printer.
HP 02 Black 660 pages
HP 02 Black Twin Pack 1320 pages
HP 02 Color Combo See single 02 inks
HP 02 Cyan 400 pages
HP 02 Light Cyan 240 photos
HP 02 Light Magenta 240 photos
HP 02 Magenta 370 pages
HP 02 Photo Value Pack 150 photos
HP 02 Yellow 500 pages
HP 02XL Cyan 600 pages
HP 02XL Magenta 555 pages
HP 02XL Yellow 750 pages
Apr 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
Only prints in green and blue
You are more than likely out of magenta (red) ink. That printer uses a tri-color cartridge, and it has cyan (blue) magenta (red) and yellow ink. Green is blue + yellow-therefore you do have those two colors; since it will not print anything red or black you will need to replace both cartridges.
Mar 05, 2010 | Dell 810 All-In-One InkJet Printer
What is cyan ink
It must be referring to the cyan color cartridge.
"Cyan" refers to the blue-green color cartridge.
Most printers have either 2 cartridges (black and multicolor), or 4 cartridges( black, magenta, yellow, and cyan).
See here:
http://en.wikipedia.org/wiki/Cyan
Hope this helps.
Jan 13, 2010 | Brother MFC-5440CN All-In-One InkJet...
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
My printer has a new ink cartridge but does not recognize the ink
What model printer do you have and can you list the print cartridge?
Also have you selected on the onboard printer menu that you have inserted a new cartridge?
Jul 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
Jul 18, 2009 | Epson Stylus NX400 InkJet Printer
I have error 29 on my 210c
!!!! Magenta ink error !!!!
The ink has run out or the ink cartridge is not set into place.
26: Black ink
27: Yellow ink
28: Cyan ink
29: Magenta ink
1. Reload ink cartridges, referring to the Owner's Manual.
2. Ink cartridge PCB defective Replace the ink refill ASSY.
3. Cannot detect ink cartridges.Main PCB defective Replace the main PCB.
I know your machine was not originally showing signs of main board fault or Ink supply issues, although main board can be killed by incorrect use of maintence mode.
Nov 14, 2007 | Brother MFC 210C All-In-One InkJet Printer
Ink Cartridge Error PIXMA MP830.
pleaz clean the cartridge sensor and also align cartridges by program in your manual
Sep 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Epson STYLUS CX5900 Printer Logo
8,488 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
