Question about LG Televison & Video
I have LG Plasma 42PC50 that will not turn on? The red light turns to green when I hit the power button but then flips back to red. I have unplugged the tv and plugged it back in but nothing happens.
lightnbaby
  • 36 Answers
SOURCE: LG 50PC3D PLASMA WILL NOT TURN ON
Unplug power cord- safety first!
open backcover
check powersupply- top center right is p.s.
top left side of powersupply you'll see 5 capacitor 3300uF 10V.
see any pop up on top? replace it All with same rate or 16v is O.K.
do not use temperature rate 75c. Use 105C.
if you know how to solder. you save $300 least!
Posted on Mar 15, 2009
SOURCE: LG Plasma Monitor MU-422PM11 Red Light Problem
Your unit is in protect mode a short circuit has occured either at x,y z board.Check fuses F52 on y Board,FS1,FS2 on Zboard.Remove P1,P2,P3,P4 if power supply voltage is normal replace right x-board.Remove P6,P7 if the power supply voltage is normal replace left x-board
Posted on Feb 12, 2008
jerryg50
  • 1667 Answers
SOURCE: Insignia 42 inch TV won't turn on
The power supply is in the protect mode. There are many things in the set that can cuase this. Most likely there is a short on one of the circuit boards, or the power supply itself has failed.
You will have to have the set serviced in order to get it going again.
Jerry G.
Posted on Jun 03, 2008
SOURCE: No picture, have sound ( think husband hit some X button)
Did you find the problem I have the same
Posted on Apr 25, 2009
SOURCE: My panasonic 42" plasma wont turn on, but the power light blinks
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of anly a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
Posted on Apr 17, 2010
Sylvania plasma tv will not turn on
power supply board has defective components,check for swollen capacitors and replace them,if problems still not solve email me at rspoliah@gmail.com .for further instructions
Aug 14, 2014 | Sylvania 6842THG 42 in. Plasma HDTV
My lg plasma tv when we turn it on blinks green 2 times then goes back to red
check for shorted components on YSus board and Y Driver boards (the boards on the left with the back off) This job is for a tech type person.
May 16, 2014 | LG 42PC3D 42 in. Plasma Television
TV can not power up. Power button flashing, turns in green but no audio & video
I have a PDP 50 V8 plasma TCL tv
Turns green and back to red
Ive been told its the power board
Dec 13, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
hope this helps...
Jul 02, 2010 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
I have an LG plasma TV, model: 50PC1DRA. We had a
Defective power board. Maybe best to call local service man.
Sep 28, 2009 | LG 50PC1DRA 50 in. Plasma Television
Philips 42PF9956/37 Plasma TV - Looking for y sustain board
it isnt the Y-SUS board, it is the Power supply, iv fixed this exact problem twice in the last month, try turning the tv on, and when it turns green, unplug it real fast, while light is still green, after 15 seconds plug it back in, then hit the power button, if it dont come on, hit the power button again, this time, as soon as it turns off, hit the power button again to turn back on, sometimes you can trick the tv and it will turn on, at least i was able to do it, and once it comes on, it should work fine, untill you turn it off again.
Jan 10, 2009 | Philips 42PF9431D/37 TV
Planar PDP42BK Plasma TV
It is the power supply. Replace the C97, C19, and C16 Capacitors with 2.2 uF ones.
Jul 10, 2007 | Planar PDP-42BK 42 in. Plasma HDTV
Televison & Video Logo
284 people viewed this question
Computer Repairing
Computer Repairing
