Question about Philips GOGEAR SA6045 MP3 Player
My computer cannot detect philips gogear 6045/97, The device manager that I down loaded from net has also not helped me to solve problem. Kindly assist.
    Problem Solver:
  • 5 Answers
Install the latest version of Windows media player.
Posted on Sep 04, 2010
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
My model is Philip SA1MXX02W/97 GoGear Mix 2 GBMP3 Player.When I on it, it shows updating 20 percent, then updating 40 percent ; hang there for few seconds and suddenly off by itself. Pls help.
It shows there is some problem with the inbuilt device firmware.The only solution is to do a reset on your device.Please follow the instructions below to reset your Philips SA1MXX02W/97.
1.Insert a pen tip or other object into the reset hole located at the bottom of the GoGear Mix. Hold until the player shuts down.
If the reset option is unsuccessful, follow the steps below to recover the GoGear Mix with the Philips Device Manager:
1.On your computer, select Start >Programs > Philips Digital Audio Player > GoGear Mix Device Manager > Philips Device Manager to launch the Philips Device Manager.
2.Turn off the GoGear Mix before you continue.
3.Press and hold the volume button + while you connect the GoGear Mix to your computer.
4.Keep holding the key until the Philips Device Manager acknowledges the GoGear Mix and enters the recovery mode.
5.On the computer, click the Repair button and follow the instructions of the Philips Device Manager to complete the recovery process.
6.When the recovery is completed, disconnect the GoGear Mix from your computer.
7.Restart the GoGear Mix.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jun 26, 2011 | Philips SA1MXX04P/02 GoGear Mix MP3 Player
I ran the battery on my MP3 player completely down and it shut off. I charged it and now all the songs are gone... is there a way to recover the lost songs?
Try this:
1)Perform a system reset, which won't erase your files, to attempt to correct playback. Locate a thin object, such as pen tip or unfolded paper clip and insert it into the small reset hole on the bottom of your GoGear. Hold the thin object in place until you see the unit shut down completely. Your system has been reset. Power the device back on to see if the corrupted files have been corrected. If the reset failed to correct the issue, perform a file recovery on your GoGear.
2)Initiate a file recovery by first connecting your GoGear to your computer. From your computer's "Start" menu, choose "Programs," "Philips Digital Audio Player," "Area Device Manager" and "Philips Device Manager." The Philips Device Manager software will be activated. Inspect your GoGear to confirm that it is turned off. Plug the small end of the supplied USB cord into the bottom of your GoGear while holding down the "Volume Up." Insert the larger end into a free USB port on your computer. Hold the key as the "Philips Device Manager" reads your GoGear and activates recovery mode. Click "Repair" and follow the onscreen prompts as given by the "Philips Device Manager" to complete the process of memory recovery. Disconnect your GoGear from your computer properly after the process is complete and restart your MP3 player.
3)Reload and replace the files onto your GoGear by first connecting your GoGear to your computer. Plug the supplied USB cord's small end into the bottom of your GoGear and the large end into your comptuer's USB port. Initiate Windows Media Player by clicking on its icon if it doesn't start upon connection with your GoGear. In the left pane of the WMP, click "Philips GoGear Aria." Click the arrow on the top left edge of the WMP window, followed by "Music." Highlight all files, and click "Delete." Click the "Sync" tab on WMP, and drag and drop the music files you would like to replace and reload into the "Sync List" panel. Click "Start Sync." The files will be freshly loaded onto your GoGear.
4)Properly disconnect your GoGear from your computer to avoid memory corruption by first closing all applications in use by the GoGear (WMP). Click the USB device icon in your system's tray (located on the bottom right corner of your screen). Follow the prompts in order to safely remove your GoGear from your computer. When your computer tells you it's safe to remove your GoGear, unplug the USB cord from your GoGear.
Hope this helps!
Apr 08, 2011 | Philips GoGear ViBE Digital Media Player
HI, I am am having problems with my Philips GoGear Flash audio player SA2625. When ever I turn it ON, all it says is "Philips" then it turns off. When ever I plug it in it says "OK to disconnect", the...
I found a restore fix by pressing the return button while plugging into a PC with philips device manager open - the MP3 player then was restored to factory defaults :-)
Jun 16, 2010 | Philips GoGear SA2625/37 MP3 Player
My GoGear 8G wont come on
1. On you computer, ensure that Philips Device Manager is running.
2. Turn your mp3 player on (it should freeze at the Loading or GoGear Screen).
3. Plug in the mp3 player to your USB/Charger cable (ensure it is connected to the USB port on your computer), and then perform a soft reset (Power switch down and Volume up button simultaneously).
4. Let go of the other buttons as soon as the player resets. Hold the Volume down button until the player comes on. The player will be recognized by Philips Device Manager and will report a problem (and will allow you to repair it). Windows will also recognize it as a Mass Storage Device.
edit:
video: http://video.google.com/videoplay?do...56814975105076
Jan 15, 2009 | Philips GoGear SA5285/37 Digital Media...
FROZEN On NON SUPPORTED FORMAT DETECTED SCREEN
Reset the player by inserting a paerlcip into the reset hole. If that fails, go to Philips' website and upgrade the firmware on your player to solve the freezing issue permanently. Actually, don't go to Philips website - run the Philips Device Manager and select Update. If the device manager won't recognize the player, unplug the GoGear, hold in either the shuffle button or volume + and reconnect it to the computer until a Found New Hardware Wizard window pops up. Once all this is done, use the Philips Media converter to convert all your video files from now on.
-Tha Mp3 Doctor
Dec 08, 2008 | Philips GoGear SA5285/37 Digital Media...
Philips SA5225 Cannot loading.
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
-Tha Mp3 Doctor
Nov 17, 2008 | Philips GoGear SA3125/37 MP3 Player
Gogear 8gb
The HDD1830 is not Mac compatible. The database file has probably been deleted or corrupted. The player doesn't scan the hard disk on start-up, it only read the database file. Anything it doesn't read from the database file is ignored.
You will need to restore the player with the Philips Device Manager, and re-load your tracks.
Jun 20, 2008 | Philips GoGear HDD1830 MP3 Player
Device manager wont detect my gogear HDD1630/17 even though i recently updated the software and driver, also my device is frozen on "Please connect player to pc". I can't even get it back to the menu...
I was experiencing this similar problem, and from my research so were alot of other people, what finally worked for me was this:
  • Update all the software on your computer via Phillips site
  • Open the Philips Device Manager
  • With the device connected and the 'connected to pc' screen showing on the GoGear, do a 'soft reset' by holding the Power Off + Volume Up buttons for a few seconds
  • As soon as the device restarts itself, hold the Volume Down button, the computer should now recognize the GoGear
  • Follow the onscreen directions to Repair the device
  • Thank the intarwebs.
May 21, 2008 | Philips GoGear HDD6330 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
193 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
