Question about Garden
Hi! I have a problem related to my Garden Water Pump. I m an expert here as well (Information Technology). The problem: My water pump which is a foot valve one, stopped pulling water. It just runs. I think it has pulled air due to a leak which had been repaired. Now its the time to re prime it. I want a detailed description on how to accomplish that. As I know the suction and pump casing should be filed with water. The problems I am having: 1. It has a plastic screw which is near the suction area (on the top of the pump). Is that the prime plug? However after opening this I saw that the inside was empty. It has to be filled with water if its primed. And how do I know whether its primed properly? Image of the motor http://www.jinasena.com/images/centric_pump.jpg The plastic screw is in red. 2. How to prime? Should I replace the prime plug before start the pump? (after filling the water) 3. Do I have to fill the discharge also (the connected pipes have been removed at the moment which takes water to the tank)? 4. After priming I want to check whether the water pumps out of the discharger. After proper priming does it start automatically or do I have to do more stuff? I want to clarify. Additional Details: Pump type: Foot (Deep) valve. Voltage: 220V Thanks Lasitha
4 Suggested Answers
falspet
  • 438 Answers
SOURCE: We have an 1hp jet pump pulling water from a
depending on the motors style of start-up, if you have a centrifugal type of start winding switch, your motor may be trying to start on the run winding due to a defective contact on the centrifugal switch, if it is a capacitor type starer, you might have a defective capacitor once again the motor is trying to start on the run winding, a way to find out is to be there and listen to the motor when it tries to start and trips the barker, if the motor emits a loud humming noise you have a fault with the start-up winding control device, if the picture supplied with your post is correct the capacitor is the long cylindrical thing at the top of the motor, you can remove this and bring it to a motor shop, they can test this for you
Posted on Apr 28, 2010
john224
  • 1378 Answers
SOURCE: Hello,\r\n I'm running a 3 year old 1.0 hp
Thank you for posting your question here on Fixya.com.
Check the stator for a ground-fault using a megger or a ohm meter. If it smoked it is likely even an ohm meter will show a ground; if it is not grounded check for resistance across the line connections. A typical single phase motor will be about 1 ohm. If it is zero ore some number below .5 the winding is shorted.
A winding that smokes is nearly always best to be replaced. Even if you get it running again it is only going to be for a short time. I would not change the horsepower if the pump had been keeping the pool clean prior to the mechanical and/or electrical trouble. If you do you'll need a new impeller too since changing one without the other is pointless.
Was the pump leaking as you began to have these troubles? Have you confirmed the incoming line voltage is 220V and stays at least 208V or more under load? You may have had an underlying problem with voltage drop or a leaking seal that caused the failure that you will want to address to prevent this from happening again.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Posted on Mar 21, 2011
MOTORWIZJ
  • 1383 Answers
SOURCE: Septic effluent pump loses prime
DONT TRY TO EMPTY THE TANK, RAISE THE FLOAT LEVEL. THIS STOPS THE PUMP FROM SUCKING AIR WITCH CAUSES THE PUMP TO LOSE PRIME,
WOW THAT WAS A EASY ONE. ....NEXT
OH AND YOU MIGHT NEED A CHECK VALVE ??
JAY THE POOL PUMP MOTOR REPAIR GUY LONGWOOD FLORIDA
Posted on Sep 15, 2012
Can anyone recommend commercial water well pump Repair Company for my business?
When you are looking for a commercial water well pump repair Spring TX Company, you should definitely go for 77 Water Well as they regularly work with various business firms and companies in the local region. As a company that handles submersible well pump Spring TX systems on a regular basis, 77 Water Well is thoroughly equipped to manage even the most complex cases. By diagnosing your pump problems, the experts at 77 Water Well can resolve all critical issues with ease in relatively little time.
Feb 21, 2018 | Water Computers & Internet
Davey XJ70 pumps bore water but flow dwindles when garden hose attached thus requiring pump to be turned off to stop burn out. Marc
possible it is a jet pump that has a return hose back to the foot valve to assist the pump to lift the bore water higher to work the pump
if that is the case ,when you turn on the tap on the pressure to the lift jet is reduced and so the pump cannot lift the water from the bore --it runs out of water
the fix here is to restrict the flow out of the tap so that jet pressure is maintained--- don't turn the tap on more than 1 turn
the reason is the lift height is too great ,indicating that the bore water level is lower than it normally is
Feb 22, 2017 | Water Garden
Utilitech 1 hp lawn pump runs for awhile, then shuts down. After a few minutes, the process repeats. It's pumping water from a lake, but must be overheating. Is it fixable? How do I fix it?
when pumping from a lake you will be pumping uphill
centrifugal pumps are susceptible to over loading because operators do not realize that water has mass and weighs a lot and the pump has to things to contend with
first lifting the water from the lake ( lift height)
the volume of water in the suction pipe will load the motor
now that it successfully lifts that water mas up it now has to push it up hill to a receiving tank of some sort
now distance to that tank ( friction in the pipe ) and height up to the tank inlet ( head pressure and it is measured as the height the discharge pipe is above the pump level --not ground level) have to be considered
unless you are a hydraulic engineer or have the equipment installed by irrigation experts all of this information will be foreign to you and that will result in too small a pump and yes it will overheat and in cases the water in the pump will boil as energy from the impeller of the pump has to go somewhere if the water is not moving
what I am suggesting here is to get pump experts involved to design a proper system with sufficient hp motor and pump volume to do the job
Oct 28, 2016 | HP Plumbing
Water wont fill up in pump when priming on a sta-rite shallow well pump
Make sure that you have a good foot valve in the well.. if that is bad the water will run right down and out the bottom...
Click here for a tip on well pump priming...
heatman101
Sep 20, 2011 | Garden
Blew a fuse, when i put new fuse in you can hear it turn on and then it starts to pump but does it for a second then stops a second repeatedly
You posted under water heater, but talk about blowing a fuse to the pump.
For the do-it-yourselfer to get best results from fixya, please re-post question with exact information about what you are working on.
Include as much brand and amperage information as possible.
Where is fuse located? Is it part of the pump?
If this is a pump, then say what pump goes to, and what age the pump.
If this this is a HVAC unit, then include that information.
If this is heat-pump water heater, then include age and brand and model number so we can possibly access the manual.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 12, 2011 | Water Heaters
What does it do? allow only so much hot water time? what do you set it to , to have untimed hot water?
Following link explains water heater recirculation pumps and how they relate to your plumbing pipes and budget, and illustrates how to set timer.
http://waterheatertimer.org/Water-heater-recirculation-system.html
For a price, expert speaks with you over phone while you work on pump/timer or any do-it-yourself project.
Dec 23, 2010 | Laing Thermotech Laing SMT-909-BSW-14...
Can I use a 200 gal. water tank that is not pressurized for my dewalt dp3900 3750 psi pressure washer? the manual says that you should use a water source that has a minimum of 20 psi 5 gallon per miniute....
My name is Dane and I am going to help you solve your problem.
A pressure washer pump is lubricated by the water running though it. You never, ever even start one when not connected to an approved water source. If the manual says that it has to have that presure, don't risk it. I would get an auxillary pump and install on your tank.
Well, I hope I've helped. If you found this information useful, please leave me some THUMBS UP if you think I'm deserving! :-) Thank you! Dane
Dec 05, 2010 | Garden
I have a lg front loader mod-wd-1025fb washer, i moved the other day & i have just connected the machine up to wash & it fills up with water but wont spin it out & just stands still has a OE...
The OE code appears because the machine is not fully drained after 10 minutes to start the spin cycle. The machine cannot spin with water still not drained due to clogged/kinked drain hose, blocked pump filter, or pump not working. Remove the drain hose from where it is installed and drain the water from the machine into a basin that is enough to hold the water. The drain hose or the pump filter is indeed clogged/blocked if the water does not drain/flow by gravity into the basin.
Check to make sure that the drain hose is clear and not kinked. Open the pump filter cover then remove and clean the filter. Reach in the pump impeller with your finger and turn it to check whether it is stuck or not.
Make sure the pump wire harness is snugly connected and intact. Replace the pump if no issue is found with the drain hose, pump filter, impeller, and the wire harness or after all issues are addressed and the fault code still appears.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Aug 29, 2010 | LG WM-2277HW Front Load Washer
How to change the water pump on a 2002 kia sportage
Hi:
Once you get the timing belt removed, the water pump is relatively easy to remove. It has approx 5 bolts.
Oct 28, 2009 | 2002 Kia Sportage
2001 lincoln ls v8 i have a rattling noise coming from the water pump or its a componant real close what could this be
hi if it's coming from the water pump then it's the water pump but to be sure you can use a piece of garden hose and put it close to where you hear the noise and listen to it through the hose
Sep 10, 2009 | 2001 Lincoln LS
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
