Sharp Linytron TV - Model 13SB50 / Turns on with "White"/"Snowy" Raster, Retrace Lines from top to middle of screen observed with No Video from any TV Channel selected & ("White") Noise heard from Speaker. TV Remote functions OK, including Channel Tuner & Audio Volume Adjustments
ctf1800
  • 4402 Answers
SOURCE: white horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Posted on Dec 03, 2007
  • 208 Answers
SOURCE: HDTV Sharp- Input select to watch Cable tv
On the sharp remote you will find an input button. You depress the input button and a menu will appear and highlight the input you are presently on. Hit the input button again to select the next input. If you wait to long to depress the input button it will not work and you have to begin again. This unit will only hightlight inputs have a component hooked to that input.
Posted on Feb 05, 2008
  • 124 Answers
SOURCE: using remote to play video DVD
You need to bypass your A/V tuner for your video connections (if possible). Plug your video directly into the TV and audio into the tuner. This will also give you a cleaner signal/picture as it does not have to processed by your tuner BEFORE it goes to your tv. Think of it as cutting out the middle man. Your tuner is best left for powering your speaker and not controlling your video despite all of the available connections in the back of it.
I would also get rid of your VHS and cassette players as they are dead technology. Clean up your system and remove the clutter. This will lessen your chance of getting interference. Good luck!!
Posted on Oct 01, 2008
salsaurbana
  • 56 Answers
SOURCE: mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Posted on Nov 20, 2008
  • 3 Answers
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Posted on Dec 31, 2008
Tv showing with lines, screen blank but hearing clearly.
its white retrace fault, check video section or crt internal short problem
Apr 23, 2014 | Sharp 25J-M100 TV
Tip
White Raster with thin lines; Sound Ok.
White raster with retrace lines: No picture, Sound OK
(picture tube based telivisions.)
It is a common fault to occur in most of the CRT based telvisions, regardless of which brand it is. There will be sound OK, and a bright screen with thin white horizontal lines across; at about an inch space, all over the screen area. This fault may occur along with colur shades also, like blue screen with white retrace line, red screen with white retrace lines, green screen with white retrace lines. Let us take the first case. A white raster with white thin retrace line acorss the screen. These are call vertcial retrace lines technically. To make it mor understand, we have to go to some picture tube electrode details. There are three colour cathodes for a colour picture tube, Red, Blue and Green. Two girds are there called Focus and Screen. Focus grid is supplied with focus voltage which in turn determine the cocus of picture, and screen grid is supplied with screen volrage which determine the emission of the picture tube; in short. There is a final anode to all the picture tubes, which supplied with Extra High Tension voltage, can be located at the top side of the picture tube, to which the EHT voltage from LOT is connected with the help of rubber ****** and clip. Without these three voltages, EHT, Screen and Fcous, no raster will be produced. Therefore in our case, there is a raster, so, horizontal output section including Line Output Transformer [LOT] is functioning well, and as far as sound is there, tuner and video IF section are working well. In fact, all other section except, video output section is working properly.
There are three cathode points on the base card, marked as Bk, Rk and Gk. Check the voltages of these three cathodes. In our case, it will be very low or approximately equal to zero. When cathode voltages goes low, emission of the CRT increases, is the reason. There must be a voltage between 120 and 135VDC at these points. Find out the reason for this voltage drop is the next step. The video drive voltages in most TVs comes from LOT windings, after rectification and filtering. There will be one reisitor of low value, say one Ohms or so, will be connected series with this winding, in between diode and winding. Check the voltage at the cathode of this rectifier diode first. If found low replace the diode and the smoothin capcitor. The smoothing capacitor will be between 33 and 47MFD 250VDC rating. Replace both of them. If there is volatge, say 200VDC or so, check whether this voltage comes to the CRT base board or not, If not, check the conducting wire, serial resistors; if used for open. There is no chance of transistor shortage at this time as the raster we see is white. If raser we see have a specific colour predominent, that is green, blue or red, check the revalent video out transistors and replace it. It is best to replace all the three video output transisors at the same time with same batch and number.
on Apr 18, 2011 | Televison & Video
Retrace green, relay on/off..when turn on the screen is green and after a few seconds it turns off by itself
Oh dear ! I fear my answer may not be what you want hear but my advise is free. Bright green raster with Flyback (retrace) lines may indicate a heater cathode short in the tube (crt) this causes a sharp increase in beam current and the power supply shuts down into standby mode. To prove the point isolate the red and green cathode pins on the tube base and cross couple the red video output stage to the green cathode pin and the green output to red cathode pin using wire links. If set now comes on with bright red raster the fault is in the green video output stage and not the tube. If still bright green then tube is most likely cause. Gently tapping the tube neck may prove the point, but take care the tube neck is thin glass and if hit too hard will break compounding your problems. WARNING if you do not feel totaly confident to attempt this level of repair there is no shame in seeking the advice of your local service technician. Safety first always
Mar 04, 2010 | Sanyo 21MT4 21" TV
IM A TV TECH. I HAVE A SONY LCD KP-60XBR800 I HAVE NO RASTER. POWER OK, MENU OK BUT NO RASTER ON TUNER, TUNER VOLTS OK,CAN YOU HELP ME PLEASE. THANKS my email sergioaguirre0182@hotmail.com
check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is seen.no raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a few.an open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from www.radioshack.com or from www.partstore.com or from www.shopjimmy.com --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 06, 2009 | Televison & Video
Lines at top of screen
I have seen issues with complaints of raster with vertical retrace lines at the top of the picture and capacitor 2494 needs to be removed.
Jul 23, 2008 | Philips 27MT3305 27" TV
Mitsubishi proyection tv
what model mitsubishi do you have. It has to be video related not deflection or you wouldnt have the menu screen. Do you have snow, retrace lines or black screen? Let me know your model.
Jan 19, 2008 | Televison & Video
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
May 29, 2007 | Philips 9P5544C 55" Rear Projection...
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
Electro Med Services...
