We have 14 X DMTECH LT26DTY some of the TV are in Hotel Mode how do you switch this off and can the TV be set back to factory settings. Many Thanks Steve
  • 2187 Answers
SOURCE: My Phillips 32pw8759 TV screen is Permanently blank
There might have been a power surge that had damaged the two units. For the reset, having the tv unplugged overnight should do it. If it does not work you may want to check the power supply of the tv for leaking capacitors or burned resistors or loose solders.
Posted on Aug 15, 2009
Testimonial: "Thank you for your advice I will try your suggestion to reset the TV & let you know the outcome."
SOURCE: We have a DMTECH lve22x who is gone into
we solved it by chance, just push "i"(display) and then digit 1 twice(11) and then the line switch(AV), then the factory setting comes up. Then you can scroll down to the hotel mode and make it "off". Finish by pressing "i" again, then the window closes and you are back in normal operation
Posted on Oct 08, 2009
hattonhall
  • 349 Answers
SOURCE: hotel lock, not available but im sure there is another way
Not all sets have a hotel lock.....key in for a google search on the model and get a free download of the user manual.
Posted on Oct 19, 2009
  • 144 Answers
SOURCE: how do i reset my tv to factory settings
Your particular TV does not appear to have a "reset" mode to return to default (factory) settings. I can only assume that you are trying to get the picture back to "normal".
To do this grab your remote, press the "menu" button then select "picture' using the up and down buttons. Then press "enter" again and select "mode" this is where you can change the size, aspect ratio and etc. of your picture. Use the up and down buttons to select 16 by 9 format or "standard" if it says that in the menu. The image I have is too small for me to read exactly which setting it should be at. At least this is where you change those options I am pretty sure you will know which setting by checking the video. If it's still wrong then try some of the other "modes" and check again.
Zashiban
Posted on May 31, 2010
  • 11800 Answers
SOURCE: i am at a hotel
No, not a remote problem: the tv can't get out of the Hotel mode because the control processor is no longer capable of loading the correct data from the firmware. The only way to fix that is to reload the firmware, something you can't do since the tv isn't yours.
There's nothing you can do, sorry - just ask them to replace the tv and don't attempt to mess with the next one, the owners of the hotel might take it badly and make you pay for the repair.
Posted on Nov 05, 2010
How do I set a Hotel LG TV back to Default Settings?
To release the Hotel mode; you have to enter its service mode option. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name and type (TV, VCR, DVD player etc:) of your device, in the search box [at the top right] of the home page. It will make surf easy.
Jul 07, 2015 | LG Televison & Video
Remove hotel lock
You have to get into its Service Menu option to unlock Hotel Mode. Contact any service technician. They only can do it, as entering into service mode, and adjust data values there; without any knowledge about it; might make the TV irreparable.
Jul 30, 2012 | Sanyo 21MT4 21" TV
I need the code that will tske my samsung 40" out off hotel mode
hello,
To switch off hotel ode on samsung, enter:
1. On standby press info-menu-mute-power or,
2. press mute-1-8-2
After service mode appear, Choose option block,
Fine Hotel mode, change to off.
If in option block you can't fine it, try open other block.
Good luck.
Apr 16, 2011 | Televison & Video
Dmtech 20 lt20xtv stuck in "Hotel Mode" how do i reset it back to nomal thanx kev
remove the circuits installed for hotel operation this most likely is a modification that needs to be resored
Jan 23, 2010 | Televison & Video
We have a DMTECH lve22x who is gone into ''hotel Mode'' so we cannot enter the menu of the flatscreen. This is a big problem as we are very happy for the product and has updated our cable tv, so we need to...
Oct 07, 2009 | Televison & Video
Akai TV - Stuck in Hotel Mode
M (menu) 7935 (regular menu appears), them press 4725 (menu service appears), then search HTLSRC (position 090), then set value 032 (this value disables Hotel Mode) - TV. Now Hotel Mode is deactivated. It is verified!
M 7935 4725, go to HTLSRC (090), fix 032 - press TV. Good luck!
Jul 28, 2009 | Akai Televison & Video
CANNOT RETUNE THIS TV BUSH TV DVD COMBO LY2211WCW
Press menu button then press 7935, if like me you bought a display model it will be set to hotel mode, this hides all the menus, once accessed switch hotel mode off, job done x
Jun 11, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
32lc5dc lg tv stuck in hotel mode
it is quite possible, if you bought this set from a hotel liquidation, it might still have it's lodgenet card. If it does, then it may be stuck on the channels the hotel had lined up. If there is a lodgenet card (where the cable jack is on the back) you can remove the 2 screws and just pull the card out an inch (leaving it attached to the black cable). Once that card is out, the tv should fall back to normal use. You might need to do a facotry reset to unlock TV options at that point. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active.
Jan 17, 2009 | Philips RC2573 Remote Control
DMTECH TV IN HOTEL MODE
Did you get any solution on this problem? I have the same.... Just out of warranty :(
Please contact me on:
jonas AT teknikbolaget DOT com
Best regards,
Jonas Persson
Sweden
Dec 27, 2008 | Televison & Video
Bush 22" LCD TV
Hi.
What is the TV model number ?
Nov 29, 2007 | Bush 5693D 24" TV
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
