Question about Maytag Refrigerators
I own a maytag ref. that is not working.The front panel does not come on to control the temps.I also cannot get my ice maker connected because of this. What can I do to get these things to work?
  • jevelyn_kenn Sep 03, 2010
    The solution would have been helpful if I had given more detail abuot my problem,the refrigerator works, but I can't get the controls on the front panel to work.None of the lights on the front panel have ever come on from the time of purchase.What I need to know is how to get this to work in order to have my ice maker hooked up as well as control the temps.I will get back to you on Tuesday with the model # and any other identifiers that I find
    Brigadier General:
  • 3,917 Answers
Samsung Refrigirator RS2545SH: Installing my ice maker when I heard several clicking sounds, I realize I forgot to unplug my refrigerator before installing my new ice maker. After plugging back my Ref I...
First lets check the wiring plug under the top left hinge cover to insure the connection is firm and then check connections at the motherboard. Let me know what happens, Thanks Sea Breeze
Samsung Refrigerator Familiarization
Dec 13, 2012 | Samsung Refrigerators
Maytag MSD2651HEW only sends cubed ice - won't send crushed. Also problem with ice maker spilling water - are these problems related?
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Oct 02, 2011 | Maytag MSD2651 HE Side by Side...
Ice maker will not make ice. Water will not come into ice maker. There is water at the water dispenser.
NOTE: This
Leo Ponder
imufo2
Sep 15, 2011 | Maytag Refrigerators
MSD2754GSW Side By Side Maytag refridge, seems like since I changed the filter the water flow in both the ice maker and the water dispenser has slooooooooooowwwwwed way down, tlll a trickle. Now the ice...
NOTE: This
First I would check the fan in the freezer. Listen to see if it is running
Leo Ponder
imufo2
Sep 09, 2011 | Maytag MSD2454G Side by Side Refrigerator
Have a maytag MFI2568A side by side refrig. Water comes through the door, ice maker makes no ice. Ice tray not filling up with water.
NOTE: This
http://www.applianceaid.com/procedures.html
I'm
Leo Ponder
imufo2
Sep 05, 2011 | Maytag MFI2568A Side by Side French Door...
I have a Maytag side by side model #RSW-24-EOCAE thats leaking inside when the ice maker fills. What can I do to stop the leak. Thanks for your help, Ronnie
NOTE: This
I'm
Leo Ponder
imufo2
Aug 29, 2011 | Maytag Refrigerators
Maytag MFI2568AES Ice maker is not making ice. I am getting water through the door, but the ice maker is not filling up with water.
NOTE: This
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
Aug 11, 2011 | Refrigerators
Ice maker and water and ice dispensor not working
NOTE: This
Leo Ponder
imufo2
Aug 11, 2011 | Maytag MSD2652K
Got a new filter for our maytag refridgerator and now it shoots out water very slow and the ice maker is no longer making ice
NOTE: This
Leo Ponder
imufo2
Aug 11, 2011 | Maytag MZD2766GES Side by Side...
I HAVE A MODEL MFI2568AES MAYTAG THE ICE MAKER DOES NOT MAKE ICE. THE WATER DISPENSER DOES WORK.
NOTE: This
Leo Ponder
imufo2
Aug 10, 2011 | Maytag MSD2651 HE Side by Side...
Refrigerators Logo
70 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
