Question about Hotpoint RB525BC Electric Kitchen Range
HOTPOINT OVEN DD771 LIGHT STAYS ON EVEN WHEN COOKER NOT WORKING AFTER REPLACING WITH NEW BULB
5 Suggested Answers
Richie_asg1
  • 1036 Answers
SOURCE: were in ireland can i
Hi there!
It would probably be easier to order by post for this.
Try these sites -
Domestic Spares.co.uk
ESpares
If you describe the model I could find the exact part, or you can enter the information in the boxes directly.
If this provides a solution, Please rate as Fixya. Thanks.
Posted on Jun 26, 2008
jtbjtb
  • 135 Answers
SOURCE: shorted out oven light while replaceing bulb.
Try resetting the house breaker.
Posted on Jan 05, 2009
SOURCE: oven light
Turn the power off to the oven. Spray around the bulb base / socket with Pam or similar spray cooking oil. Will take several applications. Bulb should free up -- may take a couple of hours for oil to seep into socket far enough to loosen it. Use oil liberally.
Posted on Apr 30, 2009
SOURCE: Hotpoint BU72 Cooker - Oven not getting to temprature
Lower oven has new element but still not reaching correct temperature.
Posted on Jan 07, 2010
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
My Hotpoint SY36 oven has started making a clicking noise behind the control panel. The temperature light does not come on although the oven does heat up still.
If you have a problem with your hotpoint cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Dec 11, 2014 | Hotpoint SY36 Style Line Stainless Steel...
Oven not heating
Hello.
If the fan is working, but there is no heat, then it is the fan oven element that needs to be replaced.
It has nothing to do with timer on this occasion.
Remove panel at rear of oven compartment, there you will see the round element.
Undo fixing screws,and remove element, disconnect leads and fit onto new element, refit new elemrnt, replace cover, and job done!!!
Please leave a fixya rating for my solution.
Thankyou
Feb 04, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Neff cooker model b1422nogb bulb replace
Unscrew glass cover anti-clockise, likewise unscrew bulb, and replace.
Apr 28, 2008 | Neff B1421 Electric Single Oven
Mar 16, 2008 | Hotpoint Kitchen Ranges
EG73 Hotpoint Oven heating when switched off
sounds just like hotpoint customer service "fob off"
your fault sounds more like the selector swich shorting out going by prev repairs i would isolate the cooker straight away and investigate.
ps. would not leave cooker powered up if not in use until fault repaired
Feb 28, 2008 | Ovens
My oven has completely stopped working
hi there as long as your supply to the cooker is ok the problem can only be one of two things the mains terminal block burnt out or the overheat cutout has blown at the back of the cooker
Nov 30, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint RVM1425BA-003 Microwave Oven Stovetop Light Does Not Work
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 14, 2007 | Hotpoint RVM1425 Microwave Oven
Hotpoint electric cooker sy36
it sounds like you have had bad insalltion caused by your element becoming open circit try replacing and this should solve your problem regards jason
Sep 13, 2007 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint RB525BC Electric Kitchen Range Logo
214 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
