Question about Gestetner Office Equipment & Supplies
How do i replace the gestetner DSm618 print drum?
  • 17,970 Answers
1. Open the front cover of the machine.
2. Lift the green lever.
3. Push the green lever, and then gently pull out the holder.
4. Press the toner bottle back to
Make sure the printer is ON when you open the front door, remove the old cartridge, and put the new one in. To reset the machine, follow the next procedure:
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover
Other details can find in the Gestetner DSm618 - Operational Guide
Hope helps.
Posted on Sep 03, 2010
MP2000 not loading toner
please check if the toner is not lumpy cos this can also cause that.
or also check the buttom of the toner bottle since the moto and the bottle may not have the same format .
May 22, 2014 | Ricoh Gestetner DSM615/ DSM616/ DSM618/...
Dsm618 driver
You did not state the problem.
Nov 03, 2013 | Gestetner DSm618 All-In-One Printer
Nashuatec dsm618 drver
The driver can be found here on Ricoh website.
Feb 06, 2013 | Gestetner DSm618 All-In-One Printer
I need drivers for gestetner dsm618
Hi, you can download the DSM618 drivers here:
http://support.aficio.com/bb/html/dr_ut_e/ges/model/x2015_18/x2015_18en.htm
Just pick your operating system and the specific driver(s) you want to download!
Aug 20, 2010 | Gestetner DSm618 All-In-One Printer
My Gestetner copier # 3225 prints blank pages.
it sounds like you may have a part of the unit that is out of alignment. If everything isn't securely fit back into the machine, it won't image properly.
If it will neither print (if it has the option installed) NOR copy images, NOR will it print a test page from its memory, then the places I would look first would be:
1: The connector on the transfer belt which is the brown, flat thing found on the door of the machine...sometimes the connector is bent and doesn't make good contact, which prevents toner from transfering to the belt from the drum.
2:The drum unit may not be secured well to the back of the machine and the Charge Strip above it may not be in place. I can't recall immediately if it has a grid or just a wire, but the hair thick wire can break, which can cause exactly your problem, though you should be able see the wire easily with a flashlight.
Unfortunately, when the office "Mr. Fixit" tries to remove a jam and save the company an easy 100 bucks it often can cause other problems...I've worked with copiers since 2001 and I'd safely say that at least 1 in 10 routine calls revealed complications from someone unqualified who tried a little too hard to fix the unit.
But check on those two things and if it still doesn't work then let me know and I'll try to help you more. :-)
Jun 10, 2009 | Gestetner DSm618 All-In-One Printer
Scanner driver
you can download the driver from www.gestetner.co.za
May 24, 2008 | Gestetner DSm618 All-In-One Printer
How to scan a doc on Gestetner Copier
You can install the Twain scanning driver which is provided on the Printer driver CD. Insert this CD and select to install the Twain driver only.
After installation od this driver, please open Word document and click on Insert, Picture and select from Scanner or Camera. Check and choose your twain scanner driver and click on insert.
Beforehand you must put the original on the exposure glass.
Try this or you can use scan to email but you need more setup details.
Hope you good luck.
Dec 27, 2007 | Gestetner DSm618 All-In-One Printer
Gestetner 3225
Ax060267,This is the part number of the polygon mirror motor , it is worn out , your machine propably makes a high reving noise aswell when it starts to print , you can go to your nearest rico or gestetner outlet and get a new motor , it sits right in the middle of the machine , sometomes it helps to remove the motor and oil it with a very thin oil , but in mostcases it is beond repair .
Oct 24, 2007 | Gestetner DSm618 All-In-One Printer
Dsm618 scanner
You must register as sender in the address book.
Aug 11, 2007 | Gestetner DSm618 All-In-One Printer
110 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
