Alarm sounds freezer display shows 2 dashes instead of freezer temp if i silence the alarm and leave it eventually the display reads ok ,this is becoming more frequent any ideas please
Thanks
Tony
Have you cleaned the condenser grill and made sure you have plenty of air flow around the unit? It might also be time to take the food out and completely defrost your freezer! Since you do have an ice build up on your evaporator grill.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Check the coil at the back of the freezer for ice buildup. Should there be ice build up, have it defrosted and cleaned. If that does not solve it check out the thermistor, also located at the back at a panel. It may have gone bad.
Hi, you have a common problem with your control boards; there is a cheap fix if you can use a soldering iron or you can have your modules repaired. Let me know
It means the compartment temperatures are increased then allowed limit.Generally in some appliances the maximum temperature is indicated at the display with an alarm after the electric cutoff.If the temp is high in the compartments
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
You Said, I have a Whirlpool upright freezer AFG 371/H there is a digital display
and lights and buttons, on/off temp alarm etc running across the top of
the freezer. None of this works but the freezer is still freezing. i
have no idea what the temp is.
I think you should try unplugging it for 5 minutes and then try restarting it and see if it reset.
Sounds like a blocked defrost drain. By "American" I presume you mean side-by-side.
I had a similar problem with a freezer-on-top style Samsung. The solution to that was to defrost the freezer, remove the false backing plate in the freezer (required removal of the ice cube tray. the panel just pops out with a bit of pulling). The drain hole beneath the freezer coils was blocked with ice. This drain passes down into the fridge and then out the back of the fridge into the evaporation pan next to the motor. There is a collector pan under the freezer coils, this and the drain hole were filled with ice. When the freezer goes into its self-defrost cycle the water collects here and then overflows into the fridge.
I removed the ice with hot water/vinegar mixture (so it doesn't re-freeze immediately) and simultaneosuly used a bit of chiselling with a screwdriver to clear the drain plug. I did this from inside the fridge working up the drain hole into the freezer. The whole job took about an hour.
my freezer works fine except for it beeps allthe time
