Question about Cameras
S2Pro camera not switching on have replaced batteries checked contacts all clean
  • 3,083 Answers
If the contacts are clean, and the batteries good, then it can still be other factors not allowing the camera to come on. Read the following blog- it has some suggestions of things to try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Here's a blog you should also check out, an interesting situation with the batteries:
http://www.fmount.com/forums/archive/index.php/t-3622.html
And another spoke of a switch inside the battery lid:
http://forums.dpreview.com/forums/readflat.asp?forum=1020&message=10613819&changemode=1
Another person cleaned his battery terminals inside the camera and got it working again. Even if they look clean, they can still be slightly oxidized.
Not many other reports on the net about this problem, and most are related to the battery issues. In case you can't get it working, run it by a good camera repair shop and see if they can spot what's going on, and give you an estimate for repair.
Good luck, thanks for using FixYa, and hope this helps.
Posted on Sep 03, 2010
I have a Fujifilm Fine pix S2900 which will not switch on correctly. It comes on and 5 seconds later switches off. I have replaced the batteries.
Often the battery contacts can get dirty. My Kodak does the same thing. When the camera tests the battery for power, the poor contacts make the camera think the battery is nearly empty so it shuts down. Give the contacts a good clean with alcohol and check they are correctly aligned. Clean the batteries too.
Jul 14, 2016 | FUJIFILM Cameras
My batteries seem to need replaced quite often. Should I use a special brand
Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power.
Jan 03, 2015 | Kodak EasyShare C875 Digital Camera
My fujifilm finepix s8500 will not turn on and the light flashes red when i try to turn it on
Always be sure the battery is charged and suited for your camera.
Check contacts of the battery and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth, Or a cotton swap. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the battery before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
When, while shutting down, the lens got stuck, the camera won't see it on the correct place when switched on.
When you are sure you have good and charged batteries with clean contacts, reinsert the batteries and switch on again.
If that does not solve the problem, switch the camera off and feel if al slight pressure on the lens barrel, will help the lens go in. Never use force, because you can damage the lens motor or the gears.
May 26, 2014 | Cameras
Camera wont turn on after charging battery
If you have a multi meter, you can check your battery. After charging the voltage should be higher (few tenths of a volt) than the voltage printed on the battery.
If the voltage is slightly lower, you know there will be not enough left when the battery needs to deliver some power.
May 20, 2014 | Panasonic Lumix DMC-FZ7 Digital Camera
I have tried two different batteries and niether of my cameras will work. DSC-W80
Check contacts of the battery and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
If the voltage is slightly lower, you know thee will be not enough left when the battery needs to deliver some power.
Jan 27, 2014 | Sony Cyber-Shot DSC-F707 Digital Camera
Pentax k200d
Stan,
If not the batteries, then you have to look close into the battery holder. All contacts should be clean and shiny. Eventual you can clean contacts with a dry cloth. Never use a sharp tool.
But still.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Always be sure the battery is charged and suited for your camera. Check contacts of the battery and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Jan 19, 2014 | Cameras
No coming on when battery installed
Jan 09, 2014 | Canon IXUS 80 IS Digital Camera
My nikon s2pro doesn't turn on. the batteries are full it just doesn't want to turn on. any tips
Make sure the flash batteries are good. I put new ones in and it started to work.
Apr 15, 2010 | Fuji FinePix S2 Pro Digital Camera
Can't turn Kodak Z885 camera back on
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jun 20, 2009 | Kodak EasyShare Z885 Digital Camera
My Fuji Finepix S2pro wont turn on
try getting new batteries.. sometimes the rechargable ones just lose the charge.. instead of rechargables try using throw aways. you can try and contact fuji but like myself and others they will just give you 5 differant numbers to call and the problem will not be solved
May 30, 2009 | Fuji FinePix S2 Pro Digital Camera
Cameras Logo
20 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
