Question about Cameras
My still digital camera is Sony DSC W210. I am remove the external battery 3-4 days and open again aftre 3-4 days, display lost the set date and time. this problem is Internal battery or external battery.
  • 37 Answers
That is the internal battery you cant replaced whit out opening the camera cassing and its very touchy you will need a tech to do so
hope that will help you
regarsd Allan
Posted on Sep 03, 2010
When i ON my digi camera its asking date n time every time???
You may continue using the camera without replacing the CMOS battery. You'll have to put up with the opening screen, and the photos you take won't have the proper date/time information if you don't set the clock, but otherwise the camera will operate fine.
May 21, 2012 | Sony DSC-W210 Digital Camera
How to set frame per seconds rate in a camera (sony dsc w210)
The DSC-W210 shoots video at 30 frames per second.
Apr 27, 2012 | Sony Cameras
SONY DSC-W220/B My camera is displaying a message E:91:01 and will not flash. What do I do?
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
If this does not work do this:
THE MASTER RESET
(1) remove the battery pack
(2) press and hold the power button for 30 sec
(3) after put the battery back do not turn it on for 1 min
(4) turn on
May 27, 2011 | Sony Cyber-Shot DSC-W220/B Digital Camera
How do i get the date and time displayed on the fotos (print) Model DSC-W210
The date and time are stored with every picture when you take it. To print it, please refer to the documentation for whatever program you're using. Depending on the program and printer, you may put the date on the image, in the margins, or on the back.
Feb 13, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
I HAVE A SONY CYBER SHOT DCS W210 WHIT ERROR E:91:01 IN DISPLAY TANK YOU hOLA TENGO UNA CAMARA SONY CYBER SHOT DCS W210 CON EL ERROR E:91:01 HAY ALGUNA FORMA DE SOLUCIONARLO? GRACIAS
Follow the procedures given below to have a perfect fix for your problem.
  • Press Menu button.
  • Toggle across from REC Mode to setup
  • Toggle down thrice from camera to setup 1
  • Toggle across into sub menu
  • Toggle down from four times to Initialize
  • Toggle across again to the sub-menu
  • Toggle up from cancel to OK
  • Press center button to accept the OK choice
  • Screen changes and so press okay again
  • It should restart the camera
  • Opening on the 'Clock Set' screen
Toggle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function. If it is still not working dont worry follow the steps again two or three more times, As this is related to a software error message and not a hardware malfunction. If it is working then don't forget to set your Clock.
Thank you !!
Aug 18, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
I have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing...
Perform the following troubleshooting steps to check whether the issue is resolved.
1. Remove the battery from the Camera for 1 minute. Re-insert the battery in the Camera and check if the issue is resolved.
2. If the issue is not resolved, then try initializing the Camera.
The Initialize option is listed in Setup or Settings option in the Camera.
Aug 06, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
i have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing its takin pictures as normal just without the flash it wont let me change the settings of the flash at all
Jun 14, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
Sony DSC-W50 camera Error msg E:91:01
Please follow the instructions given below
1. Turn OFF cam
Second step:
1)at setup do a initialize.
2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again )
by now E91:01 will never appear.you can use it like normal,be sure not to turn on your flash again or go to night mode.if not you need to perform step 1 & 2 again.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 07, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Date / Time Display Problem.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Jul 03, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Cameras Logo
51 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
