Question about Maytag Refrigerators
WATER IN BOTTOM OF REFREGERATOR - Maytag Refrigerators
  • Maytag Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 03, 2010
Top refregerator not working
look for ice in back wall of freezer . this is a no frost and that means no frost .. you may have a defrost system failure .. mm
Jul 04, 2010 | Amana 22.6 cu. ft. Side-By-Side...
WATER IS NOT ENTERING THE ICE MAKER TO MAKE ANY ICE & WE ARE GETTING TAP TEMP WATER OUT OF THE WATER DISPENSER
The Water Inlet Valve probably need replaced.
Valve located in back - bottom right of refregerator.
Jun 04, 2010 | Refrigerators
Icemaker draining alot of water
if you mean that the water is not rurning off going into the ice maker then its likely a bad solonoid ... there are two such solonoids (one for water and one for ice) located usually at the bottom behind rthe refregerator .. they can be found where the water is hooked up to the refrigerator ... the electrically operated solonoids are valves that turn water on and off ... if they get deposits inside they may quit working .. replaceing them is usually not hard (make sure to unplug first) ...
Apr 15, 2010 | Vacuums
How do you get to the drain pan?
the pan is still at the bottom next to or below the compressor. access is from the back of the frig. but you might find it to be dry due to evaporation.[heat from the compressor] if you have water on the floor and have an ice maker, than that is your problem. a water line leak [possibly]!!!!!!
Nov 09, 2009 | Kenmore 53642 / 53644 Side by Side...
My refregerator has water at bottom shelves and I have continously dry it out
Make? Model?
Sounds like a clogged defrrost drain
Affordable Appliance Repair
Orange County, CA
Aug 22, 2009 | Refrigerators
GE refregerator
this is a drain issue..check to see if you have a plastic drain trap going into back of refrig . its located about middle of rear of box. this is where your water drains out of and down to drain pan. this gets filled with food particles and such and stops up flow of water..remove by twisting and pulling out slightly..clean out and re=install...if you do not have this..go and remove freezer back wall..you will need to open drain and clean out trough under evaporator..use hot water and continue until water flows down into the pan..
Jul 11, 2009 | GE Refrigerators
Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Jan 28, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Refrigerators Logo
44 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
