Question about Kenmore 63942 Dryer
My dryer is not throwing heat just cold air,everything else is working properly
  • Kenmore Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
2 Suggested Answers
  • 220 Answers
SOURCE: hi this is Erik, my
Your/The heating element needs to be replaced. You can repair it yourself...copy serial number and model type down and order element. Sears, Lowes, and Home Depot carry appliance parts for many names. You will have to order it. Relatively simple job...30-60 min job.
Posted on Apr 27, 2011
This question for Sanyo PTAC HVAC for Hotel-Motel style unit.Hi, We have Sanyo PTAC STW 1223C2P,in real cold night, heat stripe in not working proper, on left side blow cold air, in center throw hot a
If you are saying this happens on a really cold night, the assumption is that on milder nights, it seems to work adequately.....If that's the case, there is a possibility that it is marginally sized in capacity to heat the space in which it is installed. If it has a "fresh air" damper setting, make sure that is closed completely, because that is air directly from outside the structure that is being brought in through the blower and adds more load to the space and makes the discharge air feel colder.
Dec 08, 2014 | Dryers
It does not heat up, it just throws cold air, do i need to buy a new dryer?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 30, 2011 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
My amana electric dryer model number "NED7200TW" wont heat up. Everything else works it just don't heat it just puts out cold air. The exhaust was somewhat clogged outside but even after...
heatman101.,./
Jul 27, 2011 | Dryers
Hi this is Erik, my problem is that my dryer wont heat up it works but it doesnt heat up throws cold air
Apr 27, 2011 | Frigidaire GLEQ2152ES Electric Dryer
My dryer doesn't seem to function properly, it's just blowing cold air. I had it on for over one hour, my clothes are still wet and the air is still cold. The dryer model is LG Tromm DLG 3788W. The...
heatman101
Dec 24, 2010 | LG Dryers
The dryer is blowing cold air. Everything else seems to be working properly.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 28, 2010 | Whirlpool Dryers
My dryer turns on but throughs out cold air
In most cases, a failure to heat is caused by a blown thermal fuse or high limit thermostat. Usually it is the fuse, but the fuse may be blown due to a defective thermostat. To find the location on yourspecific machine (and purchase the parts) try www.appliancepartspros.com To test the fuse, WITH THE MACHINEUNPLUGGED, put an ohmmeter or continuity tester across the fuse with it's wires unhooked. It should have continuity. If it is open, replace it. If the thermal fuse blows, it is fairly common to find the dryer vent partially blocked as well. Make sure it is clear. Thermal fuses are fairly cheap, but you don't want to have to replace it every other week.
Jan 03, 2010 | Washing Machines
Dryer doesn't throw hot air
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Sep 12, 2009 | Speed Queen AGS68AWF Gas Dryers
The tumble dryer is work but is only blowing cold air
sounds like a heating element. not to hard. remove the back and its is right there.
Jun 07, 2009 | Zanussi TC7102W Electric Dryer
Blows only cold air
Check connection to heating elements. My have bad heating elements
Jan 19, 2009 | Maytag Neptune MDE6800 Electric Dryer
Kenmore 63942 Dryer Logo
216 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
