Question about Samsung DLP HL-P5663W 56" TV
Pc mode blocked
In my setup my pc mode and my home theater pc is highlighted in gray, i can't unlock them, how do i do this so i can get my pc to work on my tv?
I did that an it still shows to be locked up.
Posted on May 26, 2008
Clayboy these highlights will only become selectable if you are
actually plugged in to the pc port (aka vga) this is the blue
female socket .if your running hdmi through your computer to tv
it will defaolt and pc options wont be available. also if you
use this vga/pc connection be sure to use the remote and set
tv input to pc .
hope this helps
Posted on May 22, 2008
My LG HT503 is locked in Bypass, I can not choose other setups as I could before. Can someone give me an advice?
When the theatre is in the standby mode press and hold STOP button on the panel (not the remote) for some time - it should UNlock
Dec 31, 2012 | LG HT503TH Theater System
Plasma tv/home theater
Is your Panasonic set to monitor the HDMI input? Just like selecting a mode input on the Tv you must also select the mode input on the surround system.
Bill
Dec 07, 2007 | Televison & Video
Forgot my password lg bluray
Go to setup-->select Lock--> HIGHLIGHT password (do not select it)-->type on your remote the numbers "210499"--> make sure that now it says None instead of Change
Jul 23, 2012 | LG LHB335 Theater System
I am usin the components port to connect my Sony home theatre DAV-DX250 to my TV Sony Wega, and it doesn ot work, I just get static. Any idea what the problem is? thanks in advacne
You need to turn On Progressive Scan mode in home theater system to get video output in component video out ports so tv can show its picture.
Progressive Scan mode can be turned On by going into setup menu of home theater, details are available in user manual.
Thanks.
Nov 29, 2010 | Sony DAV-DX250 System
Rear speakers don't work on my Samsung home theater
Check the setup. The rear speakers may be turned off or it may be set to 3 speaker mode.
Mar 10, 2010 | Samsung Audio Players & Recorders
Turn demo mode off on Sony Bravia home theater
On your remote;
Press the Home button
Scroll left to settings
System settings
Auto-start up - go through setup and select "Home" (not store)
Sorted
Dec 06, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
I have a T4061F. Iv'e been useing it as a monitor for over one year with no problems. Now when I switch to PC it search's for signal-then reads Not supported mode. I hooked the laptop to another monitor...
Hi Kirk,
Please try lowering the PC resolution on a regular monitor using the display properties tab to no higher than 1024x768 or even 800x600
then save the setting.
Then connect it back to the TV
the not supported mode is most likely from a change in the PC resolution.
Best of luck
Nov 30, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Is there a way to unlock my panasonic scpt660 Five-DVD Home Theater System? please help.
The following is what "Panasonic" recommends:
While stopped and “DVD/CD” is the source, press and hold [∫] (Stop) on the main unit and [S10]
on the remote control until “INITIALIZED” disappears from the TV. Turn the unit off and on again.
All settings will return to the default values.
(This does not work during program and random modes, or when setup menu or START menu is
displayed.)
You can access this PDF at www.static.tigerdirect.com/pdf/panaconic-SC-PT660-manual.pdf
Scribd.com suggests the following: Open the dvd drawer, press 9,8,1,7 on the remote. Press enter until it shows region 9 then press RETURN.
Hope this helped!
May 29, 2009 | Televison & Video
Panasonic home theater
take it apart via the screws on the side and back and then there is a white lever you can pull to unlock it. make sure you are wearing shoes because you dont wanna short the system
Sep 09, 2007 | Panasonic sa-ht930 Home Theater Audio...
My home theater got stuck in progressive scan mode
I had this problem, it's a real pain. You need to turn the system on and goto Setup Mode, then count the number of tiems you would need to scroll down and reset it. You will see no picture, so you ahve to actually cound the number of clicks down and over, you are doing it blind, but it will work.
Sep 07, 2006 | Zenith DVT412 System
Samsung DLP HL-P5663W 56" TV Logo
61 people viewed this question
Jerry Greenberg
Jerry Greenberg
