Question about Miller Spectrum 375 Cutmate Plasma Cutter 903891
Hobart airforce 250 plasma cutter - Miller Spectrum 375 Cutmate Plasma Cutter 903891
  • 13 Answers
SOURCE: hobart 250 a keeps cutting off the flame
If you have a bad air supply then the moisture in the air will cause the torch to cut off and the cut quality depends also on air supply,speed,metal thickness and condition of your consumables,meaning your electrode and other related parts in the torch tip.Hope this helps
Posted on Jan 06, 2009
co7196
  • 3433 Answers
SOURCE: Need to know how to
Do you prefer a hobart? This is one reason not to buy one. They are hard to get service for also.I've owned and used extensively several plasma cutters and the best in my opinion is the thermal dynamic 3/8
Its easy on consumables and can sliver stainless to 1/32 . Hobarts are home depot grade. that is probably the best place to find one. good luck
Posted on Jun 24, 2009
buffalonyman
  • 1865 Answers
SOURCE: Plasma cutter only cuts for only a few seconds
The unit needs to be tested.
You're welcome to ship the unit to me for diagnostic testing and repair. info@taeckertindustries.com
Posted on Nov 07, 2009
  • 5 Answers
SOURCE: hobart airforce 250 ci has power but will not operate
make sure that there is air to the plasma and set at the proper psi. Make sure that the contact tip and nozzle is in the cutting head correct.
Posted on Dec 18, 2009
  • 7 Answers
SOURCE: My Hobart 250 airforce doesn't start
On the main circuit board for the power supply, there is usually a thermal fuse installed, its a sealed unit and is not servicible, look for a black epoxied case,approx 3/8x3/4 long, with 2 leads coming out of it. Inside is a set of bi-metal contact points which serves as an over voltage/over current protection. These contacts deform/corode over time and it sounds like there not contacting properly. As soon as you try to load the machine, the current passing through this high resistance heats these contacts up, and shuts off power to the unit. I am not familiar with the guts of a hypertherm, but have extensive experiance repairing inverter based plasma cutting equipment, and i have encountered this before. I assume hypertherm must have some equivelent to this thermal switch inside the power supply.....Good luck..
Posted on Jan 18, 2010
Why dont i have any power to my hobart plazma cutter
Maybe blew a fuse . maybe malfuncttion. i would contact company for proper assistance.
Customer Service Hobart Welders
Mar 03, 2016 | Hobart Airforce 250ci Light Weight Plasma...
Hobart 400 plasma cutter. when i hit the trigger nothing but one short blast of air.
Make sure you have a good ground. If ground is good, make sure you are holding the tip level to the work and right up close.
Aug 31, 2011 | Hobart Plasma Cutter - Airforce 400
Would you purchase the 400 hobart or go to 500 hobart plasma they seem to cut the same thickness on the metal chart..
It's all about duration. How much metal do you need to cut continuously. Although the 400 will cut a similar spec it won't hold out as long. So if it;s lots of short cuts the 400 is fine, if you need to cut thicker gauge for longer period go 500.
Aug 16, 2011 | Airforce HOBART AIRFORCE 400 PLASMA CUTTER...
Hobart airforce 250 ci has power but will not operate
Dec 18, 2009 | Hobart Airforce 250ci Plasma Cutter 12...
Need manual for hobart g-250 welder
Go to this page on the Hobart website....you can enter your model and the serial and it will allow you to download the manual...
Click here
May 25, 2009 | Hobart Airforce 250ci Plasma Cutter 12...
Need to know how to
Any authorised dealer that sell Hobart should be able to order one for you for a minimal charge.
Try Googling it.
eg: hobart dealer distributor city state
or hobart dealer miami fl
May 02, 2009 | Miller Hobart AirForce 250A Plasma Cutter ...
Hobart 250 has power to unit, but will not run.none of the lights come on.
Sounds like you have more than one problem. Check all fuses. Bringing it to a welder repair shop might be a good idea. Welding suppy houses may be able to help you in your area, and maybe recommend someone.
May 01, 2009 | Hobart Airforce 250ci Light Weight Plasma...
Hobart 250 a keeps cutting off the flame
Jan 05, 2009 | Miller Hobart AirForce 250A Plasma Cutter ...
Miller Spectrum 375 Cutmate Plasma Cutter 903891 Logo
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
