Grundig SD Digital Set Top Box
Greetings we have the above, it was turned off then turned back on now it will not load when we attempted to put the pin number, unchanged from 8888 it will not accept it .is there a factory reset switch to allow return to factory settings with out having to use the in number first
Paul at
pauluisa@yahoo.com.au
The pass word is factory default 888888,seems someone was able to reset it by pushing one to many buttons,so I hve locked the adjustment to a password and not locked the channels or you have to put a password in every time you want to change channels
Posted on May 12, 2008
The filter fell off my grundig wk5040 kettle how do I put it back on
The above suggestion to call Breville is of no use as they do not carry parts for a "Grundig".
Aug 10, 2012 | Kitchen Appliances - Others
Will the Panasonic DMR-E30 DVD Recorder replace my STB to receive the digital free to air stations on my tv?
Only if it has a built in digital tuner, and, if it does, the digital is only SD (standard definition). If not, you would still need the set top box to receive HD (you could connect the box to the DVD recorder (for HD and/or SD) as required if you wish to record channels). Most set top boxes have both SD and HD channels in their tuners, so it would most likely be the next best option if your DVD recorder does not have a built in digital tuner. You can check your DVD recorder's on screen setup menu to see if digital services exist within it. Either way, keep your set top box just in case.
Oct 06, 2011 | Panasonic DMR-E30 DVD Recorder
When putting music or pictures on pny 4gb mirco sd card from my hp pavillion dv7-1247d lap top than put card in my samsung sch-r451c phone it shows up on memory but can not see or play music. yes I first...
I dont have a solution, but my aunt purchased this phone and a new SD card, and I have put pictures and music for ringtones from my computer to the SD Card, and when I put it back into her phone (Samsung R451C) I can not bring any of the pictures up and I can bring the music for the ringtones, but I cannot set it as a ringtone. I am sure if I was able to bring the pictures up, that I probably would not be able to set them as a wallpaper or nothing also...So I kind of have the same problem with setting my aunt's pictures and music with the same phone too...
Jun 14, 2010 | PNY 4GB Secure Digital High Capacity...
Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Feb 07, 2010 | Panasonic Televison & Video
I have a set top box GUDSTB2000 but I can't get sound from TV
hi had same problem with my digi-box
simply unplug box from mains & re-connect.
it worked for me.
cheers russell
Sep 30, 2009 | Televison & Video
Reception upgrade or what ?
Older sets are fitted with analogue tuners which can't handle digital signals. The only way round the problem is if the TV can be used as a monitor via a scart input. The external freesat or digital set top box contain digital tuners which can then display the required digital information on the TV. These external units have scart output sockets at the back, specifically for this purpose. So it's a scart lead from your external digital device to the scart input socket at the back of the TV. The remote control for your external box is then used to select the required programmes
Oct 24, 2008 | Panasonic Televison & Video
Set top box installation
Dear FixYa,
We have installed a Grundig STB but cannot figure out how to use our VCR or DVD Player.
Do we need extra sockets ? Of is there a simple solution we have missed.
Sincerely
Suzann T.
Jun 22, 2008 | Televison & Video
Kenmore Elite Oasis TL washer, stubborn Sd code
Found the problem. After removing the back panel, found some garments in the bottom of the surrounding clear plastic tub. These must have been periodically blocking the outflow area and triggering the Sd error code. Fixed it by opening the top components of the washer so I could see down into the surrounding tub from above. Fished out the garments with clothes hangar. Put everything back together and have done six loads with zero problems.
Mar 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Grundig colour tv lost digital channels
I'm sorry, but I have not worked with Grundig TV's, radios yes, TV's no. However, The menu shouldn't be hidden. The first thing I would try would be to UNPLUG the set from the wall, wait about a minute and plug it in again. This action should reboot the micro processor. On some sets, there are two levels of menus, main and advanced. You would want "channel setup" and /or channel scan. You may also look in the back of the manual and see if it list some service dealers that you could call for help. I hope this helps.
Electrode
Mar 03, 2008 | Televison & Video
Televison & Video Logo
205 people viewed this question
Top Televison & Video Experts
