Question about Kitchen Ranges
Manual for victa tilt-a-cut 2 stroke 160cc - Kitchen Ranges
SOURCE: i would like to get a manual foe a victa tilt a
where can i by parts for a Victa Line Trimmer????? The coil snapped.
Posted on Oct 07, 2009
SOURCE: Victa 2 stroke starts OK then stops
After much mucking about, discovered that the washer on the fuel cap is missing. When the fuel cap is tightened it seals the fuel tank. Eventually the motor is starved.
It then starts and runs for progressively shorter periods.
Posted on Oct 08, 2009
jdlipscomb41
  • 157 Answers
SOURCE: I need a picture of a Victa 2 stroke carboretta -
check ebay randys engine repair
Posted on Oct 26, 2009
  • 16 Answers
SOURCE: i am after a victa mower 2 stroke repair manual
I have a victa workshop manual covering some of the older models which i would be willing to copy the relevent pagesfor you. or might be able to give you soom tips, what model do you have and can you discribe the carburettor, soom victa's use a very odd carb made of plastic
Posted on Nov 28, 2009
SOURCE: Victa 2 stroke mower will not start
Hi ...i have a Victa 2 stroke mower, just replaced plug and replaced aircleaner, engin still won't start. Can you help me
Thank You
Ivan
Posted on Sep 14, 2010
WHAT PLUG SIZE DO I USE ON A VICTA TILTACUT 160CC
check with the engine manufacturer .or Google manual for same .
Jan 15, 2017 | Garden
What is the victa lawn mower 35 classic a two stroke or a four stroke please.
search on a victa 35 classic makes it 4 stroke
its a brigs and stratton 3.5 engine on aluminum frame + plastic rear catcher
Sep 03, 2016 | Garden
Victa2stroke cuts out after about 4 minutes of cutting grass
check the carb is clean and the spark plug is in good condition, also the air filters block up quite easily on those so remove it and blow it out. of course being a 2 stroke it could be that the piston /rings are scored up but you would need to remove the exhaust to inspect.
Feb 26, 2015 | Garden
How to change cord victa corvette 160cc 2stroke electronic ignition
On assuming its fitted with a victa 2 stroke engine in which case unscrew the 3 cross head screws on the top plastic cover and remove it. You should then see the top of the engine and the recoil starter. Undo and remove the 3 bolts holding the starter to the engine. Remove the starter housing gently as there will be a large o ring under the stater. Once the starter is off you can undo the centre bolt and remove the recoil pulley and spring. When refitting starter smear a little oil on the large o ring to stop it from being damaged
Oct 11, 2014 | Garden
Is a Victa Sunbeam 160 Special a 2 stroke or 4 stroke? Wondering what additive to use with fuel. Thanks so much for your help.
hi there tanyajames88
your victa is a 2 stroke vc160 these units sare stated to run 25:1 fuel / oil ratio
that is 40 mils of 2 stroke for every 1.0 litre of petrol that mix
so if mixing 2 litres - 1st put in 80 mils of good quality 2 stroke oil then put in 2 litres of petrol , give good shake and fill up your mower tank
2 stroke oil that you would use for sthil chainsaw would be ok its hi quality
you could use some fuel stabilizer additive to hekp stop mix from going stale too soon
if wish but most times just mix enoyugh mix to het job done , then mix more if need it
that way mix is always fresh
vheers pauly46
May 29, 2011 | Garden
How do i tell a victa 2 stroke from a 4 stroke?
two stroke mowers will have a picture of a oil can on the fuel cap,if it doesn't it is most likely a four stroke.
four stroke mowers will have a fuel cap and a oil cap as well.
Dec 12, 2010 | Honda Garden
Burns out spark plugs during every mow(victa vantage 2 stroke)
you are using too much oil in the gas oil mix, cut back to 50:1 ratio
Jun 25, 2010 | Garden
I am after a victa mower 2 stroke repair manual
Nov 21, 2009 | Garden
I would like to get a manual foe a victa tilt a cut
Sep 11, 2009 | Garden
It may have a blown crankcase seal. How did you check the plug for spark?
you can remove the carbi and spray 2 stroke fuel directly into the chamber and try to start it.
If it starts you have a problem with the carbi or the fuel supply.
Take out the air filter as it may be blocked and restricting the air supply.
The float in the carbi may be full of fuel due to a hole in it or the fine fuel filter in the carbi may be blocked
Apr 04, 2009 | Garden
Kitchen Ranges Logo
165 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
