Question about Lisle Ball Joint / Truck Brake Anchor Pin / U Joint Press le43620
Looking for a wiring diagram for a 60 tonne Hydrabend Brake Press Serial No 1695
Where does the pink praking brake wire go on 2003 cadillac deville go
Where are you seeing this pink wire ? I'm looking at a wiring diagram and I see a pink wire at the (RIM) rear integration module . It goes to the park brake relay A ,control side . The RIM supply's a ground on that circuit energizing the park brake relay A . There is another park brake relay - B . Are you familiar with the RIM module .
The park brake system is a mechanical and electrical system which operates on the rear disc brakes. The system is activated by depressing a foot pedal lever assembly, which sets the rear brake caliper via cables. The park brake is released by shifting the vehicle out of park or activating the manual release.
Park Brake Release
The rear integration module (RIM) controls the operation of the electric release park brake. The RIM uses serial data messages to determine if the correct conditions exist to release the park brake. The park brake is released under the following conditions:
• The engine is ON.
• The gear shift lever is not in Park or Neutral.
• The park brake switch is closed.
When all of the above conditions exist, the RIM releases the park brake by simultaneously activating the 2 park brake solenoids. After 2 seconds, the RIM deactivates solenoid A. The RIM continues to activate solenoid B while the above conditions exist, which prevents the park brake from being set.
Dec 23, 2016 | Cadillac DeVille Cars & Trucks
I need a wiring diagram for a generac 6551 model
Please provide the serial number of the unit and what diagram you are looking for as there are many. I will email you the diagram
Feb 25, 2015 | Generac Electrical Supplies
Get a wiring diagram for a saturn sc1 2001'
The wiring diagrams for this vehicle are about 60 individual pages. Which diagram are you looking for?
Feb 14, 2015 | 2001 Saturn SC
Looking for wiring diagram hr7 rotisserie
need tech(trouble shooting) manual HR7 and wiring diagram
any help?
Sep 04, 2012 | Hobart Hr7 Double Rotisserie Oven 208v 1...
My 1999 Mazda miada brake lights will not go on light bulbs and fuses are good
In most cases you are looking at a faulty brake light switch. I don't have a diagram or picture of its exact location but if you look up the shaft of the brake pedal, you should be able to see it. Below is a picture of the one for your vehicle if you do not have cruise control. If you do have cruise control it will look a little different but basically the same. If you have a test light you can check by going into the back of the connector where the wire goes in. You should have power at all time at the white & green wire and if you press the brake down and the "buttton/switch opens up you should have power coming out of the other wire which I believe is green. If you have power going in but no power going out when the brake is pressed then you are looking at a faulty brake light switch. The one for your vehicle is under 20 dollars and if you are mechanically inclinde, you should be able to replace it easy. If you have no power at all then you are looking at a power supply problem which would be in the wiring. Hope this helps you....
Jul 22, 2012 | Cars & Trucks
How many tonnes does this air conditioner have?
First digit after 38CKC_0_ is the seer rating this is a 10 Seer unit.the next two digits are BTU's of cooling to the thousands. For every 12,000 BTU's you have 1 ton of air conditioning.38CKCO_36_ would be a 3 ton unit.
Serial number first two digits are the week the second two are the year24 would be 24th week. 02 would be 2002
Jul 08, 2012 | Carrier 38CKC036 Air Conditioner
Cavalier
When you press on your brake pedal does it make any "squishy noises" "snorts" "mouse squeeky noises" "vacuum noise". Your brake booster (60$ or so used) may need replacing. The vacuum pump from your booster takes a lot of power from your engine if not working properly. When the the brake booster is not working properly, say having a torn diaphragm, your car will idle very poorly; when you press on the brake you may even get high revs; and because there is too much energy loss, your engine will sputter and shut off when you leave it idling.
Look into it. It's an easy fix. Remember to move your brake pipes gentlyyyyy though.
I am looking for a wiring diagram so I can install a remote car starter. If you have anything for me let me know.
lithium333@hotmail.com
Tom
Jan 01, 2009 | 1999 Chevrolet Cavalier
Wiring diagrams
I am not aware of the schematics being available for free for this model, What is the problem you are trying to resolve? Perhaps the diagram is not needed.
Keep us posted.
Dan
Jun 02, 2008 | Philips Televison & Video
Lisle Ball Joint / Truck Brake Anchor Pin / U Joint Press le43620 Logo
96 people viewed this question
Top Lisle Drills Experts
Are you a Lisle Drill Expert? Answer questions, earn points and help others
