Question about Cycling
I have bought a new folding bike and its seat at its lowest level is slightly too high. Is it OK to cut 1 inch off the stem?
  • 186 Answers
YES.AS LONG AS THERE IS AT LEAST 3 TO 4 INCHES OF SEAT POST IN THE FRAME
Posted on Sep 14, 2010
Lower seat height
More info required ... what bike? Pedal bike? loosen the bolt on the tube under the seat and adjust the seat stem downward until it will go no more. If it is already in the lowest position, you will have to wait for your daughter to grow a little.
Jun 06, 2013 | Motorcycles
Bike to high
If the big is really too big, then it's not safe to ride, and blocks on the pedals are not a good idea. On the other hand, if you can straddle the frame of the bike with your feet nearly flat on the ground, then the bike is not too big. You can lower the seat, and many seats can also be adjusted forward and back an inch or two. The optimum seat height is when you put one pedal all of the way down, with the heel of your foot on the pedal, then you should be able to lift your weight off of the seat. You can also bring the handlebars closer if the handlebar stem you have has a typical length offset (if you picture the handle bar stem as an inverted hockey stick, the the offset is the length of the hockey stick blade) - if so, you can replace it with a stem with a smaller offset. If the stem already has a very small offset, you can turn it backwards, but don't do this if the offset is more than 1 inch.
Good luck.
Jun 20, 2012 | Schwinn Cycling
Dropped the seat post into the seat tube need help removinging it. What do I have to do?
I asume you tried turning the bike upside down?
If you have, try a double hook like this
1) cut a coat hanger to get some stiff wire (or wire if you have)
2)straighten it out, then bend it till you have a narrow U (wire is folded back on itself)
3) bend the ends to make little hooks, slightly smaller than the inside of the seat post, they should be bent opposite each other (pointing in opposite directions), and be bent over more than 90 degrees (pointing back towards you if you are holding the u)
4) insert the hooked ends in, push them down past the seatpost, then pull back,they should catch
5) pull it out
Hope that works!
Jul 09, 2011 | Huffy 24" Ladies Granite Bike
Can handlebar for ccm vandal xc 26" bicylce be raised? It seems as if stem is confined by top and bottom bearings. Doesn't make sense that seat can be raised but not handlebars.
The threadless stem style you have pre-supposes you chose the right height and reach when you bought the bike. As the steerer tube to which it clamps has to be below flush with the top surface to accomodate the top adjustment cap, the steerer had to be cut to a final length that can't be made longer. The stem CAN be flipped upside down to provide a different rise and reach, but most likely it would be lower and farther away.
One option is to replace the stem with one with an angle and length that would work for you. Have a bicycle shop asist you in choosing one as there are 4 parameters that must be considered.
Another is to get a threadless stem riser which effectively makes the steerer tube taller. Google "threadless stem riser".
Here's one on eBay...
http://cgi.ebay.com/New-SATORI-HEADS-UP-Threadless-Stem-Riser-Adapter-1-1-8-/300530665912?pt=Cycling_Parts_Accessories&hash=item45f90609b8
Mar 18, 2011 | Cycling
I bought a used older model It is a huffy aerocruiser bicycle trailer. has no instructions on how to assemble them onto your existing bike.where does it get attached to and what hardware do you newed to...
While I am no expert, I have a huffy aerocruiser. I also purchase mine second hand, but the woman who sold it to me was excellent on giving instructions at pick-up time! There should have been a peice that fits over the stem of your bike seat and and arm type thing that runs from bike seat piece to the stroller itself. There should also be two clips, a wheel, and a handle. To assemble for bike use, remove your bike seat and place the bike seat adapter piece on the stem of the bike seat then replace bike seat. Use one clip to attach arm to bike seat adapter thing. Use the other clip to attach the arm to the stroller (where the front wheel would go, wheel removed). The bike seat adapter thing remains on the stem of your seat and you just remove the clip that holds the arm to the bike seat when not using the trailer.
To use for jogging, remove the arm and replace the wheel. Slide handle into place and use two clips to hold handle on.
If this requires clarification, please let me know! I may not have made it that clear. I would be happy to take some pictures if it would help!
Best of luck and enjoy your new stroller!
Aug 29, 2010 | Huffy Cycling
Back ache, can handlebars be raised? - How?
The stem can only raised safely within the steerer tube end to a line etched on its quill. There are stem extenders or even fixed-angle higher stems.
The sccret to getting a quill stem to move is to loosen the center (vertical bolt a few turns and then rap it down with a mallet to unseat the expander wedge inside the steerer tube.
It's possible your frame is sized improperly for you and your preferred riding position.
I would recommend you go to a real Bicycle Shop for those assessments.
Apr 02, 2010 | Schwinn Scwhinn 26 Inch Womens Coronado...
Dahon Vitesse: i have tried to tighten my folding mechanism in
Here is one manual:http://files.dahon.com/support/manuals/2009/2009_16inch_20inch_fold_unfold_guide.pdf Here is a much more detailed manual:http://files.dahon.com/support/manuals/2009/2009_dahon_user_manual_en.pdf It looks to me as if the handle bar stem has to be up high enough so that the end of the stem will clear the fold when you fold it down. Otherwise the stem will be down inside the bike and it won't be able to fold. If that makes any sense.The better manual has good pictures and diagrams and explains the locking mechanisms a lot better. Please rate me if this helps.
Nov 22, 2009 | Dahon 7 Speed Folding Bike
Seat height seems high according to specs ; vtx1100c2 2004
you could try a little bit smaller rear tire. cheaper than the shocks maybe
Jun 07, 2009 | 2004 Honda VT 1100 C2 Shadow Sabre
Laying Down and Folding Maclaren Triumph Stroller
Folding takes some getting used to, broke the first one I had because I used force. Here are some step by step instructions...http://www.strollerreviewguide.com/how_to_unfold_and_fold_maclaren_stroller_step_by_step
-Good Luck!
Feb 10, 2009 | Maclaren Triumph W0806063 - Navy Umbrella...
Harley Rdkng FLHPI police seat air suspension mechanism removal.
There are two screws below the rubber stem fixed it to the frame. You can hardly see them from any angle but can reach them through the two round openings next to the stem. Use a small wrench, through the openings, to access and remove the screws, then you can remove the stem. However, keep the entire police seat assembly since you might want to put it back like what I am doing now. I tried serveral Harley and other brands seat, high or low profile, and found the police seat is the most interesting seat to ride with.
Dec 10, 2008 | 2006 Harley Davidson FLHR Road king
Cycling Logo
26 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
