Question about Horizon Exercise & Fitness
Horizon T71 won't start. Seems like the start button is defective. Can this be replaced? Can I do it myself?
2 Suggested Answers
SOURCE: tredmill error code
Moat likely a problem with the motor control board. See treadmilldoctor.com
Posted on Nov 17, 2008
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
Incline - Button not working, and also Stop Button not pausing
RUN the software calibration INMEDIATELY, for diagnose, troubleshooting and fix it.
sincerely. God bless you
Apr 19, 2012 | Horizon Quantum II Upper Control Board
My treadmill will light up an make a beeping nose when a button is pushed. The treadmill is pluged up and the red cord magnet is on when the buttons are pushed. However it just does the same beep for...
If the screen is lit and the screen shows that the belt is moving then it’s the motor controller. If the screen does not show that the belt is moving then it’s the console.
Oct 20, 2017 | Horizon Fitness T82 Treadmill
Trying to start car I get instant draw-down of battery and car won't start
Looks like the battery has lost the capacity to provide current for the starter motor.
Need to replace the battery or jump start from another vehicle.
Jun 28, 2011 | 1990 Plymouth Horizon
I have a T71 treadmill the motor will shut off fairly quickly after starting. It seems to happen as it is accelerating. The time and other treadmill elements will keep going as if the treadmill is...
take hood off and take the wires from the motor. the ones that power go through, and test with a fully charged cordless drill one at least 18volt that should run your motor . not fast but it will cycle.if motor runs then its the controller board
Mar 18, 2011 | Exercise & Fitness
Standard horizon 155c not acquiring signal
If the signal is good statement seems to imply that it is working, perhaps this is my misinterpretation of what you mean by this.
Signal refers to the abi;ity to connect to satellites
4 are requied for triangulation.
If the unit is fully charged and not connecting , then it is quite possible that the unit has a damaged SIIRF chip or whatever chip was used in your model to acquire satellite connection. The cost of repair is costly, it means total replacement of the M/Board.
Never start car with the unit connected into DC car power, spikes will damage the chip
Jun 30, 2009 | Standard Horizon CP-150 WAAS GPS Receiver
Tredmill error code
Apr 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Power cord
I called standard horizon myself and bought the power cord for $25. The # 714-827-7600
Nov 12, 2007 | Standard Horizon CP150 GPS Receiver
Exercise & Fitness Logo
53 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
