Question about Teac P-55 Thermal Printer
TEAC p55 Printer Vertical alignment of CYMK is fine. Horizontal alignment of Cyan Magenta and Black Yellow are fine on the left side but bad on the right end of CD. Is this a mechanical adjustment? Is there a descripton on haw to do it?
  • lupo1804 Sep 03, 2010
    The alignment procedure only aligns the CYM to K Vertically and NOT horizontally. I have differences horizontally.
  • 3,083 Answers
This could be an adjustment, or a worn part, hard to say. It can even be a slightly loose ribbon connector. Unfortunately, it would take a service manual on the unit to troubleshoot it, and those are 1. hard to come by and 2. often expensive. and limited to qualified technicians, or authorized dealers. If the unit's out of warranty, you can take it apart and see if there's a ribbon connector, and if you can reseat it. If that doesn't help, a guide rod could be bent, or some part worn. You might inquire to Teac about the problem, and their suggested course of action. Here's their web support site:
http://www.teac.com/support/
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 04, 2010
  • Teac Master
  • 19,396 Answers
Click maintenance tab and perform full alignment procedure, as from pages 39/40 in manual. That will align both orizonthally and vertically.
Here the manual.
Posted on Sep 03, 2010
Printer is not printing yellow, Light Cyan, Cyan, blue lines through Light Magenta & Magenta, What could be causing this and it is also leaking black ink out of the bottom of printer.
Is it under warranty, are you re-filling the cartridges? If yes to first and no to the other two, send it back under warranty. If you use copy cartridges or refill old ones the warranty is vod. This means you need to replace the printer. To be honest, you'd be better off buying an Epson all in one. Even the wireless model start @ sound 40gbp and you can buy good copy cartridges from choicestationery.com
Nov 17, 2014 | HP Photosmart C8180 All-in-one -...
White vertical band in Cyan and Black
try to clean the laserwindows of the printer.
Mar 25, 2013 | Xerox Phaser 6125 Laser Printer
Horizontal lines. Xerox 6505DN
clean the print heads and align them
Sep 10, 2012 | Xerox 6505N AllInOne Printer
My printer is reading check alignment, is it because my color cartridge is out of ink?
No, that's not what it means.
If printer heads are not aligned, CMYK colors (Cyan, Magenta, Yellow and blacK - the usual colours in a printer) will not print in the correct place.
Assume a dark grey dot is to be printed. For this C, M and Y colored dots have to be placed exactly on the same spot. But if heads are not aligned, the three color dots will not be exactly in the same place. Therefore you will see Cyan, magenta and Yellow dots adjacent to each other instead of one dark grey dot.
It is always a good idea to align the print heads every time a new cartridge is installed.
Sep 23, 2011 | Lexmark X3650 Printer
Vertical lines on output
If the are yellow replace the yellow cart Cyan replace the cyan Magenta replace the magenta. Thank you, Steven 808-520-3003
Jul 26, 2010 | HP Color LaserJet 2600n Printer
My out of warranty l7680 will not print or photocopy in colour. Printhead status says Refilled supply Detected in printhead Black No/Yellow Yes Magenta Yes/Cyan Yes Detected in Printer Black No/Yellow Yes...
The error states that you are using non-HP cartridges for all colours. If black prints fine then you should replace the colour cartridges with genuine HP colour carts. You should be able to get a refund on the refills since they clearly do not work as intended.
May 25, 2010 | HP Officejet Pro L7680 All-In-One Printer
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
CYAN AND YELLOW CARTRIDGES ARE NEW OEM BUT WILL NOT PRINT, I GET BLACK AND MAGENTA BUT NOT CYAN OR YELLOW
Clean everything w/ slightly alcohol dampened q-tips. Run Cleaning program on printer. Align cartridges.
Oct 01, 2009 | HP Officejet Pro L7680 All-In-One Printer
Teac P-55 Thermal Printer Logo
250 people viewed this question
Top Teac Office Equipment & Supplies Experts
k24674
Are you a Teac Office Equipment and Supply Expert? Answer questions, earn points and help others
