Question about Wahl 9877-500 Beard Trimmer
Hi, I have broken a Wahl model 9880L through dropping it. the blades now do not work properly, could you tell me where I can get a replacement please? Thanks, Naomi
geokohler
  • 304 Answers
SOURCE: wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
George
Posted on Jul 25, 2008
  • 3 Answers
SOURCE: wahl 9765-301
sounds like you have very dull blades and need to replace or sharpen them also your blades may not be tight enough or your screws may be stripped enough as to not tighten down properly. does your clipper sound like the motor wants to slow down when you try using them for an extended time? if so replace the clippers. did you take apart the clipper housing and make sure it is free from all hair? sometimes hair will get into the motor area and cause the blades not to work properly.
Posted on Oct 14, 2008
billymasseur
  • 9 Answers
SOURCE: HOW TO PUT BACK BLADES ON WAHL FLAIR 8745 MODEL
you should place the moving blade first on the stable blade,then screw the 2 blades to the clipper
Posted on Nov 02, 2009
  • 61 Answers
SOURCE: wahl clippers stop cutting. i spray wahl lubricant
adjust power screw slightly to right
Posted on Jan 05, 2010
askmannyssha
  • 76 Answers
SOURCE: does the Wahl Model AC Trimmer have an adjustment
Wahl has two type of blades for this AC trimmer, some come with a fix blade no adjustment,the other type of blade has adjustable blade. Wahl dose market the blade as adjustable or non adjustable. But mannyssharpening.com has the adjustable blade type were they can adjust the blade for a close cut.
Posted on Mar 30, 2010
How do reassemble the blade for Wahl 8552
I had the same problem with the Wahl Pro Series Rechargeable model 8552, and called Wahl service. Here is what I learned:
Never unscrew the screws on a Wahl blade (they use those funky nonstandard screws to deter you) -- that's the main thing. The whole blade assembly is supposed to come off by pulling it up and off from the teeth.
But, if you did it (as I did), you can put it back together this way:
1. Place the large blade down on the table (Wahl logo down), and place the small blade on top of it (if you look carefully, you will see how it lines up).
2. Insert the spring points into the two holes of the white plastic part (on mine, the spring kept slipping out and I finally used a drop of superglue on each hole until it would stay in long enough to complete the assembly). Place that piece on top of the small blade (see photo).
3. The bent metal piece with the two screw holes then gets placed on top of the large blade, with the center ridge of the bent piece over the straight center portion of the spring -- so that you have to hold it in your hand and push it together against the spring in order to align the holes of the entire thing. As you are holding that, put the screws in from below and tighten. It's awkward and if you are like me, it will take several tries before you can get it all lined up correctly and tightened. The photo below is what the final assembly looks like before snapping it onto the clipper.
3. Clip it in: At the top of the assembly in the photo below, notice the small bent metal piece that will fit into the back of your clipper in the hole. Once you fit that properly, push the whole assembly down onto the clipper until it snaps into place.
Aug 03, 2010 | Wahl Health & Beauty
Wahl KM-SS pet shaver motor runs but cutters dont move
it seem that shunt arm that move the cutter blade is broken or off it's guide without look at it it's hard to tell what wrong, try Contact mannyssharpening@yahoo.com they are a Wahl Dealer they have all the parts for Wahl clippers. they can help.
Mar 05, 2010 | Wahl 8892-002 Kennel Pro Clipper Kit
Does the Wahl Model AC Trimmer have an adjustment for the blades? There is only a plastic insert between the blades
Feb 22, 2010 | Wahl AC Trimmer Hair Trimmer
I lost my instruction manual. How do you oil the Wahl beard and mustache trimmer model 99180? Thanks, DJ.
Oiling the trimmer is very simple. It is only necessary to apply oil to the blades. Simply apply one or two drops of oil directly to the blades while running. This should be done before each use.
You should have gotten a bottle of the blade oil with your clipper. If you have also lost this, you can buy a bottle of Wahl clipper oil from shaveroutlet.com. see link below
http://shaveroutlet.com/wahl-4oz-squeeze-bottle-clipper-oil-p-584.html
Jan 24, 2010 | Wahl 9916-800 Groomsman Beard Trimmer
I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Jun 08, 2009 | Wahl 8550
Reassmbling wahl product
Q. How do I align my blades? faq1.jpg A. ALIGNING BLADES
  1. The bottom blade holes are larger than the shanks of the blade screws. When the blade screws are loosened the bottom blade can be aligned with the top blade. Tighten the screws after the blsde is aligned and ensure that they are kept tight.
  2. The end of the top blade teeth should be aligned 1/32" to 1/16"(.79mm to 1.59m") back from and parallel to the bottom blade. It is important to align your blade properly to ensure that the clipper does not cut too close and to prevent the moving cutter from touching the skin.
  3. faq2.jpgThe extreme left hand tooth of the top blade must be covering or be to the left of the first small tooth of the bottom blade.
  4. The extreme right hand tooth of the top blade must be touching the big tooth of the bottom blade.
Q. My clipper/trimmer is making a loud "clunking" sound, is it broken? A. No, the unit is not broken. Rather, it is not properly tuned and as such it is not operating at maximum power. To adjust power (tune), turn the power screw in a clockwise direction until you hear a noise. Then, slowly turn the power screw out (counter-clockwise) until the noise stops. This is maximum power.
Sep 03, 2008 | Wahl 9765-301
Wahl 9765-301
if you put oil on the blades does it help if you remove the blade you should see the pivot what make the blades moves hair preventthe blades from moving freely after if it still weak motor is weak not mush to do with that pricewise better by andnother one cheers
Jan 30, 2008 | Wahl 9765-301
Wahl 9877-500 Beard Trimmer Logo
177 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
