Question about IBM NetVista PC Desktop
Check media no operating system found - IBM NetVista PC Desktop
    President:
  • 1,851 Answers
This means that your pc didn't found operating system in the drives that tried to boot from. To make it simpler:
1. Your hard disk isn't accesible by the system (solution: check the bios settings)
2. You haven't installed (or it's disconnected) a hard disk (solution: install one or check the connections)
3. You're trying to boot with a non bootable cd (solution: use a bootable one)
4. Your cd/dvd rom is not accessed by the system (solution: check the bios settings)
There are some more minnor cases but I don't have enough details for your case and I don't want to make you in panic.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 03, 2010
  • 75 Answers
Check the mouse and keyboard cables.as if not properly inserted it will show such an error.
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: PXE-E61: MEDIA TEST FAILURE, CHECK CABLE
The PXE-X61 error means that the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
Posted on May 14, 2009
Operating system not found dell inspiron
There are some possibilities:
1. There is a bootable device (such as USB flash drive) attached to this laptop, but the device does not have proper operating system,
2. There is a media in the DVD drive, and it does not contain proper bootable system,
3. The hard drive is dead, so the laptop does not find any bootable device,
4. The hdd boot sector is damaged,
5. The required boot files are missing or damaged.
You can check:
- 1 & 2: check the laptop and the dvd tray,
- 3, 4 & 5: Check using DVD reinstallation media. It will check and try to install an operating system, so it will detect the previous operating system. There is an option to repair the previous operating system, so you need to read the available options. If you have valuable data in this hard drive, then you need to take out the hard drive and copy the data to the other data storage.
Mar 01, 2014 | Computers & Internet
No operating system found
The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB...
Remove the hard drive and reseat (reconnect). Check BIOS. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Oct 13, 2012 | Computers & Internet
Went to shut down comp. and screen said, and still is. broadcom undi pxe-2.1 v11.4.1 copyright [c] 2000-2008 broadcom corporation copyright [c] 1997-2000 intel corporation all rights reserved. ...
A "media test failure, check cable" means your hard disk failed. The bios can not locate the boot sector of the hard disk to begin loading the operating system.
"Operating system not found" means windows can't load because the Bios can not find the operating system (because the hard disk failed).
This is pretty much an unrecoverable error in terms of fast fixes. You can take the hard disk to a data recovery service if you need to retrieve important data or files.
Dec 05, 2010 | Acer Aspire 5610-2328 Notebook
Computer wont boot error msg says media test failure check cable operating system not found
problem in your boot device.check your HDD is properly connected and working properly.
if HDD is good,you must install your operating system again.
Hope this will helpful..
Nov 22, 2010 | Computers & Internet
Operating System not found
first checkout that your harddisk is detecting on startup or not.
May 08, 2010 | Acer Aspire One PC Notebook
PXE-E61:MEDIA TEST FAILURE PXE-M0F:EXITING BROADCOME PXE ROM
hello, sounds like bad hard drive. here is what you can try, go in to BIOS and reset it factory default save and exit, let the system start again go back in BIOS and check to see if you see your hard drive there, also this time disable Boot from Network option. seeif your system actually starts up... or you get "no operating system found", if you saw the HDD in BIOS and get no operating system found, you can try reinstalling windows.
if you still media test failure and it loops, you need a new hard drive.
let me know if it helps...
good luck
Amar Sondhi
Dec 03, 2009 | Dell Inspiron 1501 Notebook
Media test failure,check cable, exiting bordcom pxe rom os not found
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
Char S.
May 24, 2009 | Computers & Internet
Operating system not found? I have got Windows Boot Genius to fix problem safely!
Jan 08, 2008 | Sony VAIO PCG-K25 Notebook
Problem in PC
Operating system not found: Hard Drive is disconnected or broken.
You can't open what?
Nov 18, 2007 | Computers & Internet
IBM NetVista PC Desktop Logo
100 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
