My LG front loader washing machine has a fault code come up of the door is open and it is closed! I have replaced the door switch but the same fault is there? Does this mean i need to replace the main control unit?
Yep, or check for connections with contact spray
Posted on May 11, 2008
My lg front loader I close door push start get clicking noise at door switch and code de door error is it the door switch it fell off truck on to door face.
Error code 'DE' means a problem to lock the door.
Check that the door hook goes properly into the hole.
Check that you didn't put a lot of clothes in and these are pushing the door glass (maybe a test without clothes would be best).
Check that the door closes good and there are no broken pieces from the door.
If the problem insists, probably you need to change the electric door lock. Here is a video for your help. Generally, it is a cheap part. If you cannot do it yourself, you need to call an engineer.
LG Washer Front Load Door Switch Repair DE code
Mar 01, 2017 | LG Washing Machines
The door on my lg washing machine will not open even when indicator light goes out
top loader or front loader
faulty door lock safety switch
unplug from wall .. if no luck
going to have to force it and replace the damaged parts
Jan 22, 2017 | LG Washing Machines
The door on my LG front loader washing machine is sagging and when closed the hook on the door misses the opening when trying to close. How can I adjust it to be in alighment?
sounds like someone was hanging on the door. i would take top off, then take front off and look at door hinge arrangement on inside of door. check out repairclinic.com, appliancepartspros.com or youtube.com for videos showing how to take door off in a step by step method. good luck.
Mar 25, 2015 | LG Washing Machines
Lg problem
problem with door switch bi metal,,,kindly replace door swich,
Apr 19, 2014 | LG Washing Machines
I have an LG front loader washing maching, model# WM2277H* I have changed both the hot/cold water value and the washer is still leaking.
Common causes
door gasket damaged(torn)
Dispenser fault
Lint filter door not fully closed
It sounds like you might have a damaged outer bowl, broken by a foreign object(coin, wire,screw)
Mar 25, 2011 | LG WM-2277HW Front Load Washer
Have DE progamme fault...
dE - Door (Front Loader) or Lid (Top Loader) Open Error = Close Door / lid
If error persists, check:
  1. Make sure the load is not too large - try taking some laundry out and see if the error persists.
  2. Wiring harness
  3. Door / lid switch assembly
  4. Unbalance switch
  5. Circuit board for defects.
  6. Check Drum retainer springs are situated correctly and are correctly tensioned.
  7. Make Sure Drum stabiliser struts are not misaligned or broken.
Repair / Replace faulty part.
Nov 06, 2009 | Samsung Washing Machines
LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Sep 11, 2009 | LG Washing Machines
LG INTELLOWASHER DD 7KG
You may need to have the door switch replaced but before that should be done, make sure the wire connector is securely in place.
Sep 02, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
