Hi there My washing machine Hoover A6590 has not been used for 7 years. I have been trying to start using again but unsuccesfully. The 'hot water hose' is not conected as I do not need hot water. My question is : Is 'hot water connection ie hot water pressure condition for machine to start operation ??? Thank You very much for your time and efforts Michael
  • 75 Answers
No,hot water connection is not the problem.the problem is of the machinery as it must have been jamed as it ws not used for so long.
Posted on Sep 03, 2010
My hoover commodore A6590 is not allowing cold water entre the machine
Possible that the inlet valve is choked , clogged or faulty. You need to check the power to the valve when the washer is switched on, if there is no power the control panel is faulty and if there is power and no flow inwards then the valve must be removed and cleaned. If there is no result the valve must be replaced.
check this link: inlet valve.
Oct 03, 2013 | Washing Machines
Very slow filling of cold water. Hoover 5 Kg
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
May 23, 2011 | Hoover Washing Machines
Have been given Hoover HC6-110 (fitted with hot
This machine does not have a heater. You could use a Y connector or just cap off the hot and only use the cold settings.
Feb 24, 2010 | Hoover HC6 110M Front Load Washer
Hoover HNL 662. 'Delay start' light comes on and stops machine
my hoover nextra hnl 662 want wash or spin and the delay staart light flashes 5 times please help iv only had the machine a year and had nothing but trouble with it wouldnt recomend one of these washing machines to anyone jakki
Feb 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
Samsung Washer,less than year old. Not every load and not every item but periodically something will come out with stains not previously on the item.
This is common, if the machine does predominantly COLD washes.
Over a period of time, there is a build up of soap scum (washing powder/fabric softener etc) inside the machine, caused by using excess soap powder/detergent.
To recitfy this, fill the empty bowl (no clothes) with a solution of HOT water & CITRIC ACID (found in the baking isle of your grocery shop) on HI Water level. Set the machine to wash cycle, then drain.
Fill again with same solution, but leave solution inside the bowl overnight.
Drain next day, then follow with 1 single HOT wash (no clothes) on HI water level again.
The scum should be gone...
The hot flush should be done at least every 6 months, but this can be dramatically reduced if you use less soap powder (Samsung machines do not require as much powder, as do other machines)
"If this has helped you, please rate this solution"
Nov 29, 2009 | Samsung Washing Machines
HOOVER 500M0AUS WASHING MACHINE
I have a Second Hoover HTC243 , I don't have the user manual . I don't know how to use it , can u tell me how to use it
Aug 15, 2008 | Hoover HTC243 Top Load Washer
Hoover 550 MA Top Loading Washing Machine
if if spins the belt is ok,may have timer fault or timer module ( next to timer) if fitted will be faulty
Mar 24, 2008 | Washing Machines
WASHES BUT WILL NOT SPIN
if it,s 7 years old. you,ve had your moneys worth. Scrap it and buy a new one.
as a repair solution, Check that the machine is emptying.
And that the pump has,nt got a coin/badge or anything else wedged in it.
Mike @ Compurepair.
Feb 25, 2008 | Washing Machines
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
