Question about HP Office Equipment & Supplies
Printer's light is flashing were it says check print cartridge but new cartriges are installed properly
  • 13 more comments
  • Anonymous May 20, 2008
    Removed paper jam and now "E" appears on display and light blinking next to "check print cartridges".
  • MonkeyDogStu Jun 12, 2008
    Same here. Printer was working just fine. Suddenly the check cartridge light starts blinking and the E light comes on, and I can't get anything to print. It was the same black ink cartridge I had been using for months, but now I get an error that it's not compatible. So I tried a BRAND NEW HP 56 like it says on the inside panel, but again I get a message that it's not compatible. Couldn't even get a "self-test" page to print like it said to try on the HP support site. Have unplugged and replugged and downloaded printer software. I got 1 page to print, but then I get caught in Error-World again. I'm using a Mac PowerPC G3 with OS 10.4.11. Any ideas on how to resolve this? Thanks.
  • Anonymous Jun 21, 2008
    Check cartridge light blinks even after changing and installin correctly. Error blinking also.
  • jacqfry Jun 28, 2008
    Inserted new printer cartridge (black ink only), and I get the 'E' and a flashing red light. Do you need to have a colour cartridge installed too? I thought that just having the black one would be OK.
  • prwshopping Jul 21, 2008
    Same problem - light syas 'cartridge not installed properly' changed for new cartridge but light continues flashing. (PS theres a lot of black gunk in the ink overflow)
  • Anonymous Aug 20, 2008
    tried changing the cartridge still flashing check print cartridge
  • Anonymous Sep 01, 2008
    check print cartridge light keeps blinking and will not let me print
  • ashleyangel Sep 05, 2008
    I guess I'm having the same problem as everyone else. Just installed a new catridge, and light is on and won't let me print.
  • guywallace Oct 04, 2008
    Check printer cartridge light comes flashes and an e is displayed. Cartridges have been changed and installed properly.
  • Anonymous Oct 05, 2008
    Paper advances about 1/2 sheet, then stops with E displayed on the printer and an error message ' The print cartridge carriage is stalled ' . The paper is then jamed and needs to be pulled out. New Cartridge were recently installed.
  • Anonymous Oct 14, 2008
    my problem is color ink catridgewhen i try copy not coming check pri-catrige button is blinking
  • annienic Dec 07, 2008
    I have pressed the scan button and now I have the red E light on and the print cartridge light flashing. I have no idea how to fix this. I have checked the catridges and there is no fault there. Any ideas?
  • kaylajo152 Feb 08, 2009
    the check print cartridge light keeps blinking and ive changed the ink and ist still not working. It keeps on blinking. how do i get it to stop and start to print.
  • himanshumitt Feb 20, 2009
    The red light keeps blnking next to CHECK PRINT CARTRIDGE.
    help me...
  • Anonymous Mar 11, 2009
    cartridge is installed correctly still the light keeps flashing
Had the same problem, I took out both cartridges and then where the cartridges set when they are parking in pushed down on the rubber in wells. Placed cartridges back in and everything is working ok
Posted on Aug 09, 2008
Printer says offline and cartrige light is flashing
Check whether the ink cartridges are properly installed.If installed incorrectly they can cause the printer to go offline.Install them correctly.
Also check whether you're running low on cartridges ink and replace if need be.
Sep 27, 2011 | HP Deskjet 6940 InkJet Printer
Colour Printing on a Samsung clp 500
Try unplugging printer from the power and connecting it back.
Try also extracting all toners and putting toners back.
Oct 30, 2008 | Samsung CLP-500 Laser Printer
My printer HP Officejet J4580 All in one, does not print, It reports "Entering sleep mode". Put new ink cartriges in, paper not jammed and no lights flashing and I printed a test page on the printer to...
Hi.
Try the following in order:
Disconnect printer power cord.
Turn off computer.
Disconnect computer power cord. (if laptop also remove battery)
Restart first computer than printer.
(this may look stupid, but it drains power that can jam USB ports and cause malfunction).
Clean the metal plate contacts in the ink carriage using cotton and isopropyl alcohol or cleaning solution.
Try turning off printer and performing a new cartridge installation. Use the HP software cartridge replacement procedure, do not simply swap cartridges.
Disconnect printer USB, reinstall printer software, connect printer back when prompted by setup wizard. Updated software for this model available at Software & Driver Downloads.
If you have spare cartridges, test them, the problem may be caused by a defective cartridge chip. Non original or refurbished cartridges commonly cause similar problems.
Sep 14, 2010 | HP Office Equipment & Supplies
Wont print lights flashing even after new hp ink installed - what now?
I had this psc and usually the ink was leaking or the cartrige head needed cleaning, or the cartridge was not installed properly. Just check these 3 things and you will find the problem.
Apr 07, 2010 | HP PSC 1315 All-In-One InkJet Printer
I have installed a new black ink cartridge. "Ink is out" comes up when I try to print. It is properly installed and is the second new black ink cartridge this has happened with. The "On" and 'Ink" lights...
I have installed all new cartridges. "Ink is out" comes up when I try to print. It is properly installed and is the second set of ink cartridge this has happened with. The "On" and 'Ink" lights do not stop flashing. The printer does not see the new cartridges.
Jan 04, 2010 | Epson Stylus CX4800 All-In-One InkJet...
New Cartridge - Black showing no ink
u check ur head is working properly i think this main error of head where u insert balck vartrige if u have same printer then u have check replace the black cartrige find out it work properly then sure ur balck head is damage
Nov 04, 2008 | HP Business Inkjet 1000 - Printer - colour...
Check Printer Cartrige
my printer is
HP PSC 1410 ALL IN ONE PRINTER
ERROR MESSAGE
1. CHECK PRINT CARTRIDGES
I AM REMOVE THE OLD CARTRIDGES
THEN NEW ADDED 21,22 CARTRIDGES
THEN NEXT ERROR MESSAGE
HOW TO SOLVE THE PROBLEMS
Jul 09, 2008 | HP PSC 1410 All-In-One InkJet Printer
Top light on HP 6122 ink jetprinter keeps blinking
This light will blink when the top cover is not properly shut, so the easy first step is to check that the cover is closed properly.
If that does not help, then one of the cartridges is not being recognized. See here to determine which cartrdge is the issue.
You can then remove and reseat that cartridge, also try cleaning the cartridge contacts as shown here.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 14, 2008 | HP DeskJet 6122 InkJet Printer
Print Cartrige Error
they probably are dried up if they were in storage
Mar 16, 2007 | HP PSC 1510 All-In-One InkJet Printer
776 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
