Question about Smeg 18 in. DWD409SS Built-in Dishwasher
How do you resolve error E9 "Water Level limitation system has tripped"?
  • Smeg Master
  • 3,247 Answers
I looked at the user manual for your model. E9 code shows a different description. Your description refers to E2 code. Please confirm if this is correct.
Assuming there is no water overflow in the dishwasher, the likely problem is the float switch at the base might be stuck.
It will look like this located in the base. You will need to push it a few times to check if it is stuck.
If no difference then it needs to be replaced.
Hope this helps fix the problem.
Posted on Sep 08, 2010
  • 3,740 Answers
Check the float sensor. Some are a finger looking thing in the bottom of the dishwasher. Others are a circular or retangular plastic device. Food particle sometimes build up on these and the either don't move up and down with the water level changes or.. in the case of finger sensors.. some of the holes are clogged so it fills up with water but does not drain out so the machine thinks it is still filled with water.
Look for a water level sensor or float.
Sensor... Clean the holes. (finger like)
Float Clean the float stem area as best you can with a thin rag. It should make a microswitch click as you gently lift it to the full up position and again as you lower it.
If you still get the E9 error after doing this then either the sensor is bad or the float switch has failed.
I think you can resolve this yourself. Give it a go.
Thanks for choosing FixYa.
Kelly
Posted on Sep 03, 2010
  • Kelly
    Kelly Sep 03, 2010
    There is a remote possibility that you could have a drain problem. In other words the unit did not drain out due to a motpr pump impeller problem / drain hose / air- gap / garbage disposal / sink port blockage. It is possible but, I would think that if this were the case you would have mentioned that also did not drain well or did not at all.
    Kelly
Error 8 light on. I think all lights flash, then far right light stays on. Recently had issues with it. Not emptying properly. How do I fix it??
6. Troubleshooting
In case of a malfunction, the dishwasher will identify the program by switching on a combination of lights.
When an alrm is present, all the PROGRAMS lights (4) come on, while the PROGRAM PHASES lights (7) identify the error code:
E2
The system which limits the water level inside the dishwasher (safety unit) has been tripped.
E3
The appliance is not able to pump out the water.
E4
Temperature sensor disconnected.
E5
The appliance is not able to take in water.
E6
The appliance is not able to pump out the water from the tank.
E7
The appliance is not able to measure the amount of water loaded accurately (on models with turbine flow-regulator only).
E8
Anomaly in the system which distributes water to the basket (where installed).
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
The anti-flooding system (if installed) has been tripped.
The maximum level of water for loading has been exceeded (on models
Jun 02, 2015 | Smeg 18 in. DWD409SS Built-in Dishwasher
Error 8 . How do I rectify it?
6. Troubleshooting
E2
E3
E4
E5
E6
E7
E8
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
Thjere is something wrong with the distribution. Check for blockages.
E9 message and machine stops
Jayshree, E9 error, pressure sensor error/water sensor error.
Replace water level sensor. The error display disappears if power button is turned off and on.This is what the service manual states.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Daewoo DWD M103 Service Manual Page 15 of 16
Daewoo CV701PC Service Manual Page 26 of 52
Daewoo Washing Machine Error Fault Codes
Washing Machine pressure switch
Apr 20, 2014 | Daewoo DWD M1031
Bosch GWH 16-2 GNG E9 temperature limiter has tripped
Try descaling the heat exchanger, and also clearing the fins of any soot that has formed
Aug 04, 2013 | Bosch Water Heaters
E9 E2 ERROR
Message = E2
Error = OVERFLOW ERROR
Cause & Solution =
The water is supplied continuously due to an defective inlet valve. Change the valve inlet.
The valve inlet is normal, but the water level sensor Change the water level sensor
(sensor pressure) is low. (sensor pressure).
The drain motor does not work - Test and if faulty change the drain pump
Message = E9
Error = SENSOR PRESSURE ERROR
Cause & Solution = The water level sensor is faulty. Change the water level sensor. (remove pressure tube and blow through it to make sure it is clear first)
Mar 10, 2012 | Daewoo Washing Machines
My Videocon Fully automatic top load washing machine (Digi Dolphin Dlx 7 kg) gives E9 error and stop functioning
Hi
E9 means the water level sensor is defective or the pipe connected to it is faulty.Generally error E9 means a problem with your water pressure sensor. do you have water in the tub? Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 02, 2011 | Washing Machines
Keeps showing check water
As you know E9 is linked to the water inlet problem.
There are two scenarios here - 1) Are you using the Aqua-Stop safety system? If this is trigerring then it can shut the inlet water. The reason it can trigger is if the flood device located at the base of the dishwasher under the tub is seeing water. Now it is possible the 2 weeks wait for the technician caused the water to dry out and the dishwasher worked on his arrival. But the leak could have started again when it worked once again. So you could have a leaky hose or the door gasket.
2) going by the description of the error codes in this smeg document, I can foresee the error E9 is linked to the water level system which is not able to detect the level required for the dishwasher to start wash cycle. Possible cause is gunk around the sensor that detects the water level in the tub.
Refer a possible solution reported at this forum site.
What I am not clear is why is the dishwasher not doing anything now when you press the start button. Maybe try one thing at a time.
Please post a comment to confirm which way it progressed.
Mar 20, 2011 | Smeg STX2 Dishwashers
Error code E9
High pitched noise is from a very high CO2 level. Adjust the gas pressure to stay above 11" w.c. and have a gas technician with a calibrated CO2 analyzer adjust the CO2 levels.
Apr 21, 2010 | Bosch AquaStar 2400ES-NG
Washe machine problem
The sound become beet? We need a little more detail. Look in the owner's manual and tell us what is error e9.
Feb 26, 2007 | Daewoo DW500M Top Load Washer
Smeg 18 in. DWD409SS Built-in Dishwasher Logo
220 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
