Question about LG enV Touch VX11000 Cell Phone
Touch screen not working only allowing me to access one item on the front screen and the inside screen is cut in half
  • 677 Answers
Hi, the problem might be from different areas, like the touch screen or from the flex of the phone.
due to the cut half display,might has affected the touch pad. You will need to replace the cut half screen to see if the screen is attached to the touch pad.
Also the phones touch screen might not be working because there might be a problem with the flex of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
Have a nice day.
Posted on Sep 03, 2010
Why won't my shredder microcut items placed in the credit card/cd/dvd slot? It will only cut the item in half.
You can check with Dynex regarding this issue, but your shredder may only be capable of cutting those items in half.
Aug 01, 2014 | Dynex - 10-Sheet Microcut Paper Shredder
My Samsung SGH-a877 touch screen does not respond to "touch" nor "tapping". The touch screen has always been flakey. Now the screen is totally dead. The slide out keyboard &...
Usually when touch screens don't work, it is due to water damage. You can bring your phone to your carrier's nearest store and ask someone that works there to check if your phone suffered water damage. They'll check the inside of your phone. If that's the case, you'll probably have to buy a new one. If you're insured this shouldnt be TOO expensive. But if you bring it to the store and it's NOT water damage (perhaps a software issue), they should replace the phone for free!
Hope this helped
Please rate my solution!
- Frankie
May 02, 2011 | Samsung SGH-A877 Impression Cell Phone
Does not work on the edges, can not access start by touching. when the screen is touched the arrow appears about half an inch away
Sounds like the calibration for the touchscreen needs to be reset. If you check in the control panel, there should be a ELO shortcut that allows you to calibrate/test the touchscreen. Try running through the calibration and see if the touchscreen behavior improves. If the calibration doesn't fix it, then you may have an issue with the touchscreen itself.
Mar 07, 2011 | Elo CarrollTouch touch-screen Monitor
Archos 3 cam vision, i am unable to use the touch screen for half of my screen. it doesnt respond. tried resetting. im unable to click on all options on half the touch screen does this mp3 player have a...
I had the exact same problem on one of my phones. The problem was that half of the small ribbon cable was cut in half, so part of the touchscreen digitizer worked and the other half didn't. I had to either replace the digitizer or get a new phone.
Feb 28, 2011 | Archos 3 Vision Digital Media Player
My lg chocolate touch's screen went half black
your screen has broken and LCD also has broken that's why your half screen is working and half is black. you have to change your screen and then use your phone again like before
May 17, 2017 | LG Cell Phones
Television half picture what causes this?
Sorry to let you know that your picture tube might be going out. Is your picture cut in half, or is your picture just using half of the screen. If is using just half the screen you might be able to adjust this with your horizontal control. If your picture is cut in half you might be able to adjust this on the inside back of the TV. Only problem with this the TV has to fully discharge from static as this static if you touch the inside picture tube can kill you. There are additional controls on the picture tube housing but should be done by an expert. Only problem with this, if this does not work you paid a service charge you could put towards another TV. Check out craigslist. Some great deals there. Let me know if I can help you with anything else.
JimmyC
Sep 25, 2009 | RCA Universal Remote Control
Can you tell me how to access the front touch-screen full-keypad?
You can only have the front screen touch keypad when you touch twice (double click) in the area where you want to type. (for example when you browse on the internet, text messaging or adding contacts). If you can't use the touch keypad the phone will tell you (for example in MSN messenger, you have to work with the keypad inside the phone).
Apr 25, 2009 | LG VOYAGER VX10000 Cellular Phone
Front screen
Hi, much easier to access the front screens (there are 2 sandwiched together) by removing the top back cover, be prepared for lots of screws and when you get down to the last 2-3 screws get some help, on the inside of the back cover is a large mirror, some are made of mylar, do NOT clean or even touch a mylar mirror, the others are made of real glass and the back will be much heavier than you think (and very expensive if you break it)once the back is removed you should have access to the bug, good luck, video-tek
Feb 03, 2009 | RCA P52926 52" Rear Projection Television
Broken ts
yes you can take the glass out but leave the plastic that protects the screen. but remember your touch screen wont work if the glass is not replaced which can be a bit expensive
Dec 23, 2008 | HP Pavilion TX1000Z 12.1" Touch Screen...
Aspire 5100 Kepad and touchpad not working
have k/b and touch pad been disabled in BIOS?
Oct 30, 2008 | Acer Aspire 5100 Notebook
LG enV Touch VX11000 Cell Phone Logo
229 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
