Question about Refrigerators
I think I need to unclog/unfreeze the drain tube--where is it located and how do I get to it? Water freezes in the freezer [on top] and drips/collects in the fridge
    Genius:
  • 1,073 Answers
Replve the rear freezer panel and unthaw the obstruction
Posted on May 11, 2008
Tip
Water Leaking Inside Refrigerator
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself. My 26 year old fridge was leaking
and I fixed it completely. It is a Kenmore
top freezer, bottom refrigerator model.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assembly, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
With lot of patience (I mean lots of it) you should be saving hundreds
of dollars. Attached are some pictures I took. Call me before you dig !
on Mar 01, 2010 | Refrigerators
Show a picture of the drain tube so I can access it with the back of the refrigerator off
There should be a tube, that leads to a defrost pan, under the box. Follow it up to the freezer. If the freezer is still freezing, you may never get it unclogged.
Sep 07, 2014 | Refrigerators
Top freezer whirlpool refrigerator condensation water leaking/dripping
there is a drain in the freezer that sum time get Clogged the drain is located below the evaporator coil you have to remove the evaporator cover to unclog it make sure the refrigerator is unplugged before trying this you can't unclog the freezer drain without removing parts
Sep 10, 2013 | Refrigerators
Water in the bottom of the freezer that freezes, then the water goes out the door and is messing up my floor. My fridge is a Frigidaire side by side model MRS26LGJ. Yesterday, I cleaned out the freezer and...
The defrost drain located behind the freezer back panel has gotten clogged. You will need to remove the panel to gain proper access to the defrost drain. After removing the ice build up you will have to also clear the tube using boiling water alittle at a time poured into the drain opening. this will open the tube up and gain proper flow again.
Sep 22, 2010 | Frigidaire Refrigerators
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
it yourself.
To get to the connector assemble, you need to unscrew and
the light bulb fixture. Once you take the take the cover off (you will
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
Water buildup on the middle rear top shelf of refrigerator
you need to use a turkey baster/ hot water and force it down the drain . this will help . but it will freeze again . so stop bu your appl parts dist and pick up a defrost tube heater kit pt # 819043 . "heat probe .add - on to stop tube ice-ing..) and wa-la your problem is over . make sure the prob is attached to the heater good or it will not trans the heat to the drain properly . mm hope this helped ,mm / feed back pls ..
Feb 03, 2010 | Refrigerators
Water leaks inside,cant seem to locate drain. Water freezes in bottom of freezer,then runs down to the bottom of frig. I SEE a drain in the back right of bottom of frig but it sits up like a knob with...
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer
Nov 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Thin layer of ice on the floor of my whirlpool top mounted freeze
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 12, 2009 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
Frigidaire FRT18IL6D
Hi thanks for your question. to unclog. pull fridge away from the wall. remove back cover , clean all coils. let fridge thaw for at least 24 hrs. get small plastic hose to push up the drain tube from the back. blow up yhr drain tube to clear the tube. thanks the appliance doc. please rte my answer, thanks.
Oct 12, 2008 | Frigidaire FRT18B4A Top Freezer...
Refrigerators Logo
144 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
