Question about RSA Security RSA SecurID Appliance (SIDAPPLIANCE50BU) Firewall
Need default username and password for rsa securId appliance
How to setup VPN on iPod?
connect to WiFi.
Tap General>Network>VPN>
you can try these settings I've used before:
Add VPN Connection. chose PPTP.
Give it a name under description.
Encryption Level:Auto
Send all traffic: ON
Proxy: Off
RSA SecurID: OFF
Here's the part that differs from the VPN I personally set up.
Server: enter the IP address of the VPN Server. this is specific to you, as to what server you want.
Account: Enter username and password to log in. If this VPN is for school, it would be your school username and school password you normally use.
The VPN at my school worked when I connected to their wifi and then turned on the VPN. for added information.
Jan 21, 2015 | Apple iPod Audio Players & Recorders
Hmm
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 08, 2011 | Belkin (F5D8231-4) Wireless Router...
Help me with my wep key please
Sep 07, 2011 | Belkin F5D8236-4 Router
Wanted to set password om my linksys
192.168.2.1
192.168.1.1
Sep 07, 2011 | Computers & Internet
New password wifi
Sep 07, 2011 | Encore 802.11G WIRELESS LAN ROUTER...
How 2 put the password?
Sep 07, 2011 | SMC Barricade N Wireless Broadband Router...
Forgot my password and cannot reset?
Sep 06, 2011 | Computers & Internet
Usb RSA securID when plug into the usb port, windows 7 says "finding drivers and then errors out with "Unable to find smart card driver"
This pop up only occurs with older versions of the RSA software. Customers should download the latest version of RSA Authentication Client from RSA.com. bres can obtain the SD800 smart card driver -- which is Windows 7 certified -- directly from RSA, but it is not available through Windows Update.
The SecurID "token" from RSA, the security division of EMC, is a two-factor strong authentication mechanism (something you know, plus something you hold). In tandem with a RSA authentication server, a SecurID is used to ID trusted users for firewalls and other restricted networked applications. (It is not itself a firewall.)
RSA's SD800 is a hybrid hand-held authenticator. The SD800 displays a series of one-time passwords, which change every 60 seconds, on a small LCD, but it also has a USB plug that allows it to directly connect to an accessible USB port to offer the full functionality of a smartcard. These include an automated SecurID exchange, cert-based authentication, an array of classic PKI crypto functions, and supplementary key and credential storage.
These are complex services, and they require a sophisticated setup.
The SD800 is intended for Enterprise rather than consumer use. Since the driver must be properly configured by an Enterprise to work in its environment, the SD800 is designed to be installed manually or pushed out by an Enterprise using SMS (along with its complementary GPOs, group policy objects).
The quick solution here is for an Enterprise admin to go back to the vendor, RSA, for the right stuff.
_Vin
Jan 12, 2011 | RSA Security RSA SecurID Appliance...
Batteries in keyfob are dead got new ones,how do you reset for a citreon saxo
From what I understand of the RSA Secure log on is that when the unit goes "dead", the connection to the server is lost. In order to restore the connection you will have to call a Helpdesk and have them refresh the server to "find" your keyfob.
Dec 08, 2009 | RSA Security RSA SecurID Keyfobs Full...
My rsa securid shows no code to input for access the only number on the screen is a small no 3 in the right hand botton corner
This means the device is about the expire. Your SecurID has a expiration date stamped on the back.
Oct 10, 2008 | Computers & Internet
Computers & Internet Logo
1,451 people viewed this question
Top RSA Security Computers & Internet Experts
David Payne
David Payne
Are you a RSA Security Computer and Internet Expert? Answer questions, earn points and help others
