Question about Dishwashers
Dishes aren't getting clean possible clog need manual please help
    Genius:
  • 1,073 Answers
What is the model number
Posted on May 11, 2008
Dishes on top shelf not getting clean
Check your upper wash arm.... check the holes, especially the ones at the end of the arm. Are they possibly clogged with debris or hard water? This is the usual cause of dishes on the top rack not getting clean. The holes at the end of the wash arm are angled to eject the water at an angle to use the reaction to push the wash arm around. If those holes are clogged, then the arm won't rotate, and only those few dishes or glasses right under the arm will get clean, and the remaining 80% of the dishes on the upper rack won't get clean!
Sep 13, 2014 | GE Dishwashers
I have a Haier HDW300SS dishwasher. The top half is cleaning the dishes normally but the bottom dishes aren't being cleaned at all. I've cleaned out the sump and checked the bottom spray arm i
Dear Sir:
See the diagrams attached and proceed according with the common sense.You can use the instruction manual in section troubleshooting.if you do no have go for free download: www. fitness. manualsonline.com or www. retrevo.com
May 07, 2012 | Stoves 27 in. DW60 Built-in Dishwasher
I have a Kenmore 16059 and dishes aren't rinsing clean. Seems like the spinner arms are moving and water is draining but dishes are wet with gunk in them.
Possible that the pressure of the pump for the spraying arm is very low or is absent. Check for power to the pump when the CYCLE is ON. If there is no power then the controller is faulty If there is power then the pump is faulty. Also check for clogging on the spraying arm, it must be able to rotate with power or the pump action is low or there is dirt within the system. If so remove and clean using a jet wash and reset.
Oct 23, 2011 | Kenmore 24 in. 16059 Built-in Dishwasher
My dishwasher doesn't seem to be washing the
Hello
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Aug 09, 2011 | Viking 24 in. Professional Series VUD040...
Dishwasher does not clean dishes. Some soap remains in soap dish. Have tried on the enrgy saver cycle and 1 hour cycle.
Hi jerry1413,
Firstly, make sure you are using powdered soap, and not the 3 in 1 tablets. The 3 in 1 Tablets only release certain parts of itself on certain temperatures, and because all dishwashers aren't alike, they won't have the best of results on all makes & models. Cycles aren't run the same way on every Make, and don't follow the same order either. Trust Me ;-) , stick to Powder.
Furthermore, check the following link for some advice and suggestions on getting your dishwasher to clean properly again:
WHAT TO DO IF YOUR DISHWASHER ISN'T CLEANING WELL ANYMORE...
Kind Regards :-)
* If you found this solution helpful, please rate it?
Jun 18, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
I have a ge quietpower 3 dishwasher. Lately it has stopped cleaning the dishes. Sometimes the dispenser tray doesn't open. Sometimes it does open and the soap pac hasn't disolved.
Make sure your water temperature is hot enough to dissolve the soap. Generally, the water temp. should be 140 degrees. Run some hot water at the tap before you turn on the dishwasher. This will assure that hot water is in the dishwasher as soon as you start it. Be certain that there aren't any large pieces in front of the dispenser tray. Sometimes casserole dishes, frying pans or baking pans can block the door and prevent it from opening.
Also, the sprayer arms might be clogged with bone fragments, peelings, bits of paper, etc. If this is the case, you'll need to remove the sprayer arm, flush and then check the jets. If you see "stuff" in the jets, they can be remove with tweezers.
Finally, make sure the upper sprayer arm hose is securely seated with the tube in the back of the dishwasher that carries the water up to the sprayer arm hose. If these two are not seated correctly, the water will not travel into the sprayer arm hose, the sprayer arm will not turn and your dishes will not get clean! I hope this helps. If it does, please come back to Fixya and rate my advice.
Jun 10, 2011 | Maytag Dishwasher
Kitchenaid, new dishwasher, stopped cleaning top rack dishes
The problem most people encounter with dishwashers is a simple inability to get the dishes clean. There might be stuck-on food or residue from the detergent. A water pressure problem may be the culprit. You may need to replace the water intake valve. Another common problem is mineral build-up. If your house has hard water, the mineral build-up can clog the water jets. Clear each jet with a wire or pin, and run an empty load with some vinegar in the detergent dispenser about once a month.
Sometimes, the dishwasher has problems draining properly. There could be a clog in the drain hose, or a problem with the pump. It's also possible that the dishwater is getting too sudsy, and sensors in the washer aren't detecting the soap foam as water. This causes it to shut down the drain cycle too early. Just use less detergent.
Feb 02, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
GE Built in Dishwasher
You possibly have several problems. The plunger is broken to the dispenser. You will have to disassemble the door to check the dispenser. Your water not draining is why the dishes aren't getting clean. Check to see if your drain hose is clogged. It may drain at a disposal or through a siphon gap which is mounted to the rear of your sink. Sometimes the siphon gap gets clogged and will cause drainage problems. It sometimes is located at the right or left rear of the sink and has a cap that sits about 3 to 5 inches high. Take the cap off and make sure there is no clog.
Dec 21, 2007 | Dishwashers
Dishwasher kenmore 16789
It sounds like your wash pump impeller might be clogged. The first symptom of this problem is poor cleaning capabilities and food left on dishes. You will need to remove the spray arm assembly to access the reservoir below the spray arm. More than likely, you will find debris clogging the the wash pump impeller area. As a general rule of thumb, you should not put anything into dishwasher that still has to be chewed. You don't have to prewash your dishes, just scrape them real well. Most detergents still need to oils and residue from food to activate the cleaning agents. If you prewash, you simply defeat this purpose. Some things that should NOT go into a dishwasher are lemon seeds, orange seeds, pistachio seeds, popcorn kernels, chunks of meat, bacon, tooth picks, chicken bones, match sticks, bottle cap liners, jar labels, etc. These are a small example of SOME of the things I have personally found in the wash pump. It doesn't take much to clog the pump, and the chopper assembly is not to be considered a disposal. I hope this helps you. Let me know if you need any further assistance.
Jul 25, 2007 | Kenmore 16879 Built-in Dishwasher
Filter clogging continually!
Hi Dolly, If this is the only problem you have with your dishwaser, no need to move to a new one !!!! You will face the same phenomena with the new machine, so why to waste money. Good luck with your children's dishes cleaning course.
Jun 09, 2006 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
93 people viewed this question
Top Dishwashers Experts
