Question about Ricoh Aficio 1013F Copier
I have a Nashua sc550 Aficio 1013. Its displaying error SC550. message displayed is "Functional problems, turn off main power switch then on again. If error reoccur, call service" Best regards
  • 1,110 Answers
Your question is somewhat confusing as to the model. There is no Nashua SC550 as that seems to be the service code you have an issue with. There is a model 1013F but there is no SC550 code for that machine. That being said I will tell you what an SC550 code means on most all Ricoh, Gestetner,Nashuatec machines. The SC550 means your fuser oil/cleaning web life is over. The solution for this is to replace the web and then reset the counter which requires entry into the service mode. Both of these are going to require a service technician to complete.
Good Luck and Thank You for using Fixya.
Posted on Sep 03, 2010
  • nisar ahmed Jul 28, 2013
    i have same problems in ricoh 1013
The Ricoh Mp 2000 copier displays "Error occured Sc:545 Functional problem"
It's a fuser overheat error enter service mode to clear, if it comes back service call ( push in sequence clear modes(yellow) 1 0 7 hold down stop for 5 or so seconds, screen will change, power down, red switch. -Carl
Jan 30, 2014 | Ricoh Aficio MP 2000 Black and White...
Sc550
That service code SC550 normaly is a fuser web end error, you must replace the web and reset the % in 1.902 to "0". But i dont think the Ricoh aficio 450 have a fuser web. does this SC550 coming from your Aficio 450?
Sep 18, 2011 | Ricoh Aficio 450 Copier
Ricohaficio2060sperror code sc550
After replacing the canvas with a new one, you must
SP1902 perform -001 (Display / setting area used linen
fusion) to reset the counter to zero consumption.
The SP code should be performed to remove SC550.
Jun 20, 2011 | Ricoh Office Equipment & Supplies
I have nashua aficio mp161spf and it display the message sc500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
Nov 08, 2010 | Ricoh Aficio 1013F Copier
Erro SC550 Aficio 1060
• Web end (requires replacement)
• Web end sensor defective
Note: After replacing the web with a new
one, reset SP1902 turn the value to 0%
Jul 09, 2009 | Quasar SP-3235 32" TV
Am having ricoh 1013 photocopier, and its giving an error message that "functional error,switch off mainpower and on"!
Low fusing temperature. Either the thermistor is bad or power supply board (unlikely). Service code can only be reset in service mode by a technician after problem is fixed
Mar 24, 2009 | Ricoh Aficio 1013F Copier
Error code sc550
Ricoh jp 5500 Copier Error code sc550
Sep 18, 2008 | Ricoh Aficio 450 Copier
Aficio 1060 - SC550
• Web end (requires replacement) fusing unit
one, reset SP1902 001 to 0 to
release SC550.
Jun 28, 2008 | Quasar SP-3235 32" TV
Ricoh photocopier 1075 code sc541
Ok, its a firmware bug, but you should be able to reset it. Press clear modes, 1, 0, 7, and press and hold clear/stop. Press 1 for copy sp. Scroll down to 7, (data log) press 7. scroll to 7807, and reset it. exit all the way out, and recycle the power.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
1,367 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
