SOURCE: I have a fridge freezer
check if there is a gulley on the back wall of the fridge with a drain hole in the middle. if so, this drain may be blocked. poke something flexible down the drain till water flows away freely
SOURCE: Bosch KGU40124 water leaking from freezer
remove freezer back panel and you will see a tray at the bottom with a drain hole in the middle and it is this which is blocked. if blocked with ice, clear with some hot water and make sure drain is free and water flows away
SOURCE: bosch fridge KSU 44 leaking water from bottom of fridge
Check the hose or the drain hole in the back of the freezer make sure hose is connect and the drain hole is not plugged
SOURCE: bosch fridge leaking water
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
I have the same problem,warranty just ran out but its been
leaking on and off for ages,must be this model.This much Ive figured out,what
happens is the drain hole gets blocked from ice freezing over the hole at the
back of freezer, the drain water has to go somewhere, since it cant leak out of
the drain hole where it suppose to it ends up pooling under the vege
compartment before ending up on the kitchen floor.Now if this is your only
problem,someone suggested to me to run a piece of copper wire from the
defrost heater to the drain hole so no ice can build up there,hence no more
leakage.To do this you'll have to take the back panel off and see for
yourself,I did this and Im a novice.Make sure you turn off and unplug the
fridge first and wait for it to defrost.
Now I think I have other things wrong with mine,after leakage problem the
refrigeration compartment wont cool anymore but the freezer part remains
working as usual.Ive nailed this down to one of the following not working...
Thermostat / timer / defrost heater.So one or more of these needs replacing.Im
just trying to look for a manual which shows the nuts and bolts or the
refrigerator (not the "How to use" type manual which I have).
SOURCE: bosch fridge freezer - ice build up and water leak from freezer
This is most likely a blocked drain pipe - blocked with ice that is.
Remove all the drawers in the freezer - and stack them up.
With the unit switched off and unplugged, undo the fixings on the rear pannel in the freezer (behind the drawers)
Remove it to see the evaporator coils etc.
At the base there should be a channel - and a hole leading to the drain pipe. This needs unblocking wih a thin flexible cable. -net curtain support wire is ideal, and cheap. or use a short length of insulated cable.
Check it comes out at the rear of the unit onto the evaporator container - situated on top ofthe compressor.
Replace everything and switch on.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
