Question about Texas Instruments TI-5630 Calculator
Unable to load paper - Texas Instruments TI-5630 Calculator
I am getting a "fax output error" message on my printer/fax/scanner. It seems to be asking for paper. However, I see only one place to put paper in.
I've been having this same problem for months now and have been unable to find a solution. At some point in the past it failed to print a fax transmission report, and now it keeps insisting periodically for me to load paper so it can print. However, paper is loaded but the fax mode seems unable to feed it. I've unplugged the printer for a week and then reconnected it, but the error reappears periodically.
Sep 15, 2010 | Canon MX700 Office All-In-One InkJet...
Unable to print on network it is showing offline or load letter. How to resolve?
I can help you with your HP Laserjet 4 printer problem.
Ensure the paper is loading correctly from the paper tray by reloading paper and printing locally.
If the printer prints locally, then paper loading is not the problem. Select your printer from the Control Panel > Printers list, right click and choose Sharing to re-setup printer sharing.
I hope that helps.
Aug 30, 2010 | HP LaserJet 4 plus Printer
Epson Photo PX710W Unable to print on photo glossy paper. Always a paper jam message. Will print fine on ordinary paper. (Will print 6x4 size on upper tray). Help!! Geraint.
Im having the same problem, will print on normal paper but when I try to print onto Glossy paper it comes up with paper jam,or paper not loaded properly is anyone else hjaving this problem? Please help!!
Caroline.
Aug 25, 2010 | Epson Office Equipment & Supplies
Print unable 4F
nandkjwatson,
Good day!red light flashing causes some problems on your printer.Like empty inks,no paper,hardware error.Be sure to check all ink cartridges if its full and if all chips are good.Be sure to have paper loaded.
Regards,
Mastergani
Jul 06, 2010 | Brother DCP 130C All-In-One InkJet Printer
We are unable to load the paper on our Sharp UX-266 as the paper jam sign comes on every time we try it .
Unplug the machine open all covers and check for paper jams, remove the paper draw check for paper behind the draw. load paper before pluging in
Aug 15, 2009 | Sharp Office Equipment & Supplies
Can't load paper on a brother EM-530
try using the paper release lever and putting the paper in it could be that a sticky lable is stuck in there
Dec 04, 2008 | Brother EM-530 Typewriter
Loading legal-size paper
:) it should load in the same tray as the letter size, you may need to adjust the tray adjustments to accomidate it, the paper setting are located in the print settings are you click print.
Oct 13, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Loading paper
is the tray going up when you put the paper in and close it? is the sensor there? there has to be a lever that is free floating in the tray, when you put paper it goes up and shows has paper, when out it goes down for add paper.
Jan 14, 2008 | Canon FAX-L1000 Plain Paper Laser
Texas Instruments TI-5630 Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
