Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge model gts22wcmbrww cools fridge to ~40', and freezer to ~28'. the evaporator fam runs almost all the time. the compressor runs alot. the evaporator coils get a complete coating of frost when the compressor runs then thaws on the off cycle. the oms values of the thermistors are 6.3, 6.5 & 8.5. what is the appropriate values for the thermistors. what is causing the poor operation? dave
SOURCE: Refrigerator warm, freezer too cold
I had this same problem. You need to totally empty the fridge and freezer and allow it to defrost for 24 hours. Then put it back on and it will work. This happens if someone leaves the freezer door open and then it gets closed. The defrosted water freezes in the pipes and doesn't allow the cold air to move up into the fridge so the freezer gets even colder. This has happened to me twice!
Posted on Aug 16, 2008
Thanks, problem solved.
Posted on Dec 29, 2008
SOURCE: ge side by side not cooling
it could be two things your compressor is shot .check what date you bought it if less than one year you call the store you got it from or G.E but the store you got from sholud replace with a new one dont let them send a service tech out
Posted on May 29, 2009
SOURCE: GE Monogram side by side not cooling
I had the same problem. GE Man said that since the unit had been allowed to warm so much, we needed to empty it, unplug it, and totally leave it alone for 24 hours for any excess water to drain out. Then, we needed to plug it in and let it run with NO ITEMS INSIDE AND NO OPENING OF THE DOORS AT ALL for 48 hours. After that, we started using it again and it was Perfect!! I thought it was a lost cause, so this worked and didn't cost me a dime!!
Posted on Jun 24, 2009
  • 1304 Answers
SOURCE: freezer is 0 degrees frige side only 40 degrees
that would be a valid check
but with this model i would look more twords you thermister in the refer, if its maintiaing a constant temp, but just outta temp, its more than likely you thermistor is going bad
Posted on Oct 14, 2009
Testimonial: "it seems that even if I set the control to the coldest is dosen't affect the temps range"
Fridge not getting cold, ice maker not making ice
It sounds like it is doing some cooling. Check to see if your evaporator fan is running and there is not ice buildup on your evaporator (indicating a defrost issue, common on ge refrigerators, usually heater goes bad), you would either see ice on the back wall of freezer or if you take off the back wall you will see lots of frost. Also check if your condensor fan is running and clean the condensor. The compressor is running since it is getting down to 27 but if it is not being cooled it will shut down. Another common problem on the ge refrigerator is the main board contacts going bad and not running the compressor. If your compressor is running the whole time and none of the other conditions exist it sounds like you have a leak or restriction in the refrigerant or sealed system.
Dec 13, 2009 | GE Profile PSC25PSWSS Stainless Steel...
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
Freezer is 0 degrees frige side only 40 degrees
Oct 14, 2009 | GE Monogram ZISS480DRSS Stainless Steel
PTS25 Top Freezer Model- Fridge & Freezer won't cool
If the compressor is still good your hard start relay might be bad.
Aug 05, 2009 | GE Profile Arctica Stainless Steel Top...
Freezer not freezing
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 11, 2009 | GE Refrigerators
Fridge not cooling or freezing
Work on the fridge problem first and the freezer may be fixed by that.
1/Thermostats lose sensitivity over time. The thermostat or sensor may be defective.
2/ You have lost some of your refrigerant and it is undercharged. It does evaporate very slowly but a pinhole would lose it in minutes.
Do not continue to run it or your compressor may overheat and fail. The sides of the fridge are probably quite warm from this happening already.
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a GE model: sts221cmbrww fridge/freezer with ice maker. I quit cooling suddenly. The freezer runs but doesn't cool and the fridge doesn't even run. Where do I start?
Could be the compressor has failed - time to replace the compressor, if the price is right, else you need a new one. Or, you have a leak in the freon, and it needs a re-charge.
Jun 19, 2008 | GE Refrigerators
Refrigerator/freezer gets warm intermittently
sounds like your thermostat is faulty
the thermostat reads the temperature of the cabinet and controls the temperature
the 1 thing to check on the uprights is the evaporator is in the freezer and that makes the cool then there is a fan that blows the air around the fridge and freezer to freeze things
now there is a cycle that hapens to cycle usualy every 12 hours and that is the defrost cycle
this cycle turns off the compressor and fan turns on an defrost element on the evaporator and heats up the coils to get rid of the ice
the ice turns to water and runs through a drain to a evaporator tray and when the cycle is finished the fridge stars up again and goes into the cooling state again
when the thermostat decides that the fridge is cold enough it turns of the compressor and so on it goes through the cycles as required
if the drai is blocked or the defrost system is not working the evaporator will get choked with ice and the fan will not beable to let air through to cool things off
Jan 25, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
203 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
